MUM Europe 2020
rado3105
MB+CPU which you recommend for RouterOS? With power like core i3, 2,5ghz?
Fri Oct 30, 2015 7:27 pm
MB+CPU which you recommend for RouterOS? With power like core i3, 2,5ghz? ideal low power consumption, 12-24V power supply... /like jetaway boards/
jarda
Fri Oct 30, 2015 7:58 pm
Oh. I would expect you described your expectations at least.
kiler129
Re: MB+CPU which you recommend for RouterOS? With power like core i3, 2,5ghz?
Fri Oct 30, 2015 9:36 pm
Often RouterBoard will be cheaper (after adding price of decent LAN ifaces), more powerful in routing and less power hungry than x86 platform ;)
Just my 2¢.
chechito
Fri Oct 30, 2015 9:55 pm
you have a very complicated requirements
i think the only reason to use x86 is for using a high end cpu to process full bgp feeds
x86 has no low power consumption (30-80watt on idle is normal) unless you use laptop components.
an x86 system cost at least 400us including L4 license but powered with 110-250AC and at least 30 watt idle power consumption
with that budget you are close to buy a ccr1009 and avoid a lot of headaches with 15w idle power that can be powered by 24vDC
hegars
Sat Oct 31, 2015 5:28 am
chechito
Sat Oct 31, 2015 11:40 am
nice interfaces gigagit integrated
216us motherboard
29us shipping
125us Intel Core i3-3220T 35w
25us 2x2gb ddr3 total 4gb ram
20us 160gb hard drive
35us 80 plus 300w power supply seasonic
20us generic atx computer case
50us router os licence level 4
prices from newegg
total 520 us
rfauske
Sun Nov 01, 2015 11:00 am
Look at the supermicro mini itx boards, they support 12v and has low idle power usage.
Sent fra min HM 1SW via Tapatalk
rado3105
Sun Nov 01, 2015 3:31 pm
I use now this one:
Jetaway JNC9T-1037
power consumption max. 15W (with transcend ssd 512MB module), meanwell power supply, no casing needed, dual ethernet intel pci express card (from ebay for 40Eur). So full price aroung 200Eur.
Works like a charm for one year.
But it will need replacement for something more powerfull. That chinesse board looks intereting. What is the power consumption with some lower earting CPU?
kiler129
Sun Nov 01, 2015 9:32 pm
@rado3105: It also depends on what you're trying to archive. I will never use crappy built-in network interfaces. Something like Intel I350-T4 is a reasonable minimum for high availability, but that entry-level card costs like $150 alone.
I had DIY server-router on Linux for circa 3 years - it was horrible experience ;) I also used x86 as edge-router for some time - it was a pain. After switching to CCR you could almost forget you have a router.
rado3105
Wed Nov 04, 2015 9:35 am
I have no problem with my x86 system, just planning to upgrade it...
This mb has 50w power consumption: http://www.aliexpress.com/store/product ... 69834.html
is that possible?
mobilexpert
Sat Nov 21, 2015 7:14 pm
Just curious, what was that "pain" ?
I just packed up Celeron dual cpu, socket 1150, x86 system, integrated lan + 3 pci-e lan + 3 pci lan
which takes 500+ mbps input traffic, with firewall, queues, and cpu 10-20%,
so what is the pain ?
except those pci lan cards, which a bit hogs up the cpu, everything else works cool n' quiet.
b.r.
francisuk24
Sat Nov 21, 2015 8:25 pm
Don't mean to be rude but why would you need something like a core i3 for routeros? When i had my dell optiplex mini tower single core 1.66ghz with a 4 port intel lan card and used the on broad lan for the WAN gateway, From when i can remember maxing out my 152mb dl it was hitting 41% cpu with the default rules setup and i also added a nat rule to open my xbox 360.
RouterBoard RB750R2, RouterOS Level 4
ISP: Zen Internet via VDSL 2 > 74.68Mb Down / 17.84Mb Up
kiler129
Sun Nov 22, 2015 12:15 am
First of all network interfaces drivers are stable in the lab - if you go on production a lot of things can go wild :) 500Mb/s is not that much, if you're dealing with 2-3Gb/s a lot of strange things stars happening (random crashed, lost packets etc.).
CloudFlare as I remember described some of them long time ago on it's blog. Standard Linux kernel networking works good for server scenario - if you try to use it as a router you better go for dedicated solution like RouterOS.
...and I didn't mention kernel upgrade stability - even stable releases can break things very very easy - once a time I upgraded kernel from one stable release to another and suddenly load increased 1.5x (but it was hard to debug since it was present only above 800k pps).
gogusrl
Tue Nov 24, 2015 3:50 pm
I'm running RouterOS in a VM for gigabit routing at home. Running on 1 vcpu under ESXI on a i5-2520m, 80% max cpu load at 1 gbps.
eternal0
Wed Nov 25, 2015 3:12 pm
1037U or J1900 + 1GB RAM + 4GB Flash + 8 or 4 GBE + RouterOS L4 only cost less than 200us.
What is the performance compared with RB850Gx2, RB1100AHx2, CCR1009 and the new RB3011?
Zorro
Long time Member
Long time Member
Mon Nov 30, 2015 3:00 am
i think OP imply something more quiet and less power-hungry, like sceond generation of Brasswell D chips or new AM1 chips from AMD or newer board with soldered CPU too.
as for external DC power source - its remain uncommon, sadly, even for low-power platform to my surprice, despite being Very practical and reliable to use. so far - only two brands made motherboards with among popular. personally i prefer Zotac-branded, usually, but thats depends local market.
but generally using ROS on x86 someone missed whole Point of Routerboard, whether that was cute routers like HAP or super-duper fast CCR routers.
power of x86 is aisde cheap and replairable hardware is opennes and ability to Choose something to install and use and mainline distros remain quite common(just walked across router with gentoo within, for example, occasionally) or specialized ones, like VyOS or alikes(nearly ~10 most popular or so).
rado3105
Mon Nov 30, 2015 10:13 pm
Zorro can you post some boards with that brasswel? I can find any, thanks
Users browsing this forum: metricmoose and 39 guests
