G2Dolphin
RB3011UiAS-2HnD + Third-party Wi-Fi
Tue Dec 08, 2015 7:33 pm
I'm just an average MikroTik user, but quite interested in new 802.11ac devices incoming -- hAP AC and RB3011 models. Seems like hAP AC is still doing it own way to market, but we already have a rackmount version of RB3011, so, I assume, desktop 2HnD is incoming.
Because of useful miniPCI-e slot, I have an important (it is, yes?) question — will it work with third-party WiFi modules, especially the dualband 802.11ac ones? Intel 7260HMW, for example. Or can you advice some compatible 802.11ac dualband modules, if they exist? Because if it will be upgradable like this, I will definitely add some $$$ and buy more powerful RB3011.
Home: RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, GrooveA-52HPn, hEX (r3), hAP lite, RB951G-2HnD
Work: RB2011UiAS-RM / UiAS-2HnD-IN, RB951G-2HnD, hEX (r3), CRS125-24G-1S-2HnD-IN, CCR1009-8G-1S-1S+
pablomancan
Re: RB3011UiAS-2HnD + Third-party Wi-Fi
Tue Dec 08, 2015 9:13 pm
> Intel 7260HMW
Just a fun fact, but that specific Intel card has its firmware lockdown the channels it can emit radiation on, specifically ALL of the 5GHz channels (No 80211ac AP support with that card, sorry).
InoX
Wed Dec 09, 2015 1:52 am
What's the use of a dual band router that is not dual radio? Dual band card's are for "stations".
Eliminates the need of 2 wireless cards.
I don't think will work any radio except atheros/qualcomm, like always.
jarda
Wed Dec 09, 2015 7:41 am
I would rather see possibility to run two separate radios in 3011 at once than to be able to select one or another radio, even if it could be dual band.
G2Dolphin
Re:
Wed Dec 09, 2015 9:27 am
Yes, that's what I meant too -- 2.4 and 5 Ghz at the one time wit some miniPCI-e card. Just like hAP AC (lite) models -- wlan0 is 2.4Ghz radio, wlan1 is 5Ghz.
I meant "dual radio", of course, sorry. :)
kiler129
Wed Dec 09, 2015 12:22 pm
Mikrotik supports only Atheros-based cards. 7260HMW is an dual-band (not dual-radio) card, so you can choose to use 2.4Ghz OR 5Ghz but not both at the same time.
I haven't seen dual-radio mPCIe card, so I think dual-radio RB3011 is impossible.
G2Dolphin
Wed Dec 09, 2015 1:43 pm
Well yes, that example wasn't very good, okay. :)
So... what about more hardcore variant named "FG-MCV02A-1"? :D
honzam
Wed Dec 09, 2015 3:36 pm
Perhaps in the future we will see dual-radio card :)
it would be a solution...
LAN, FTTx, Wireless. ISP operator
kiler129
Wed Dec 09, 2015 6:18 pm
I wish.... :D
@G2Dolphin: Is it even available in mPCIe form factor? Anyway I don't think it's gonna work due to PCIe2.0 requirement.
Zorro
Long time Member
Long time Member
Thu Dec 10, 2015 5:34 am
or maybe MikroTik design and manufacture one - special for their devices ? just like how they created 4x PCIe card ;-)
technically Atheros(Qualcomm (tM) brand now ;)chipsets/SDK allow it to do on Recent SoC pretty nicely)
chechito
Thu Dec 10, 2015 5:43 am
maybe something like this adapted to mini pci express
http://i.mt.lv/routerboard/files/RB14e-131021162825.pdf
kiler129
Sat Dec 12, 2015 12:57 am
Apart from us trying to solve that brain teaser I'm puzzled why MikroTik lacks devices like Aerohive AP370?
While hAP AC will be nice (if released in 2016 at least :P) it's not an perfect solution for enterprise environment. I currently work in a company which is not in IT business, but we have 802.11n @ 2.4G + 802.11ac 3x3 deployed for 1.5y now. Besides that it works in full roaming mode where devices just use one SSID and the best mode is chosen based on conditions & history of usage (so, power-users are bound to "ac" group while cell phones are always in 2.4G network).
I wish to do something similar using MTs devices only...
InoX
Sat Dec 12, 2015 1:18 am
Mikrotik is a small company from a small country and maybe it lacks research facilities that other huge company have.
Also they tend to have low prices compared to other professional products. I even consider hap lite an professional product because of the excelent software, good hardware and no need to reboot, ever.
kiler129
Sat Dec 12, 2015 2:06 am
@InoX: maybe you're partially right, but look at their devices like CCR1072 - it's not an simple SOHO device ;)
They have very competitive offer in wired market, but there're few gaps in wireless market.
chechito
Sat Dec 12, 2015 2:52 am
i think maybe with some collective effort using api can fe developed a open source solution like that to use on mikrotik hardware
unfortunately mi coding skills are very low
kiler129
Sat Dec 12, 2015 3:10 am
I wish I have more time...
It's for sure doable, but is it currently possible to make single SSID for two frequencies and multiple APs to provide users seamless experience across large open space office?
chechito
Sat Dec 12, 2015 4:24 am
i have tested using ping and voip on a laptop windows 7 with intel 7260n chipset and lost only one ping and udp voip call lost about 3-5 seconds of audio when roaming
if i am using youtube you have a momentary drop on troughput but if video is buffered no problem on video.
but
on a old thrive android toshiba tablet when roaming it stops youtube inmediatly
on a motorola razr i on android the roaming takes 5-15 seconds
on my experience roaming its very client dependent
Users browsing this forum: MSN [Bot] and 35 guests
