pe1chl
Re: Mikrotik VDSL / DSL Modem?
Tue Nov 13, 2018 7:34 pm
Using 1500-byte MTU with PPPoE is only possible when the ISP and the modem supports RFC4638.
When one of them doesn't, the router reverts to the safe MTU of 1480. However when manually configuring it should be
possible to get MTU 1492, when the modem at least supports VLAN tagging. When not, maybe 1488.
You cannot force the matter by setting higher values without the support. It will not work and/or it will crash the modem.
(in case of an AVM FritzBox in bridge mode it does that)
dohmniq
Tue Nov 13, 2018 8:41 pm
The ISP definitely supports RFC4638 as using the TG589 for VDSL+PPPoE allows non-fragmented 1500-byte pings. (I say "ISP" but it's probably true for any ISP using OpenReach network).
RouterOS allegedly has RFC4638 support since version 6.33, albeit with some bug-fixes since then!
But you have given me an idea to test:
Maybe with the TG589 in "bridge mode", doing only VDSL (and VLAN tagging) but not PPPoE, the TG589's ethernet port's MTU is only 1500?
This could mean that although everything is set up OK in RouterOS, the PPPoE negotiation fails somehow.
Should be easy enough to test next time I have some spare hours to rearrange everything again.
rendrag
Tue Nov 13, 2018 9:14 pm
Couple of thoughts..
1) Re the TG589: make sure you have also increased the MTU on the TG589, or you're simply not going to be able to use packets larger than 1500 with it. You can't JUST increase packet size on the Mikrotik side.. :)
2) Whoever said turning off autonegotiate was the way to go with the SFP's gave you a bum steer. I've never had this work. The only way I can get the 180-T SFP's to work on my CRS-109's, is to power the CRS109 on, wait for it to boot, THEN insert the 180-T. If the 180T is installed when the Mikrotik boots, it will never pass traffic even after the sync light goes solid green.
Cheers,
DG
pe1chl
Tue Nov 13, 2018 10:58 pm
To have MTU of 1500 on PPPoE you need to have MTU at least 1512 on ethernet (or in case VLAN tags are not counted at least 1508).
When it is not possible to raise MTU on ethernet (both on router and modem) to this value the RFC4638 protocol will detect this and the MTU of the PPPoE link will be lower.
I have had working MTU 1500 connection both with the SFP discussed in this thread and with Draytek Vigor 130 external VDSL2 modem which supports RFC4638.
Apparently your modem does not support RFC4638 and it will fail.
You are lucky that it just lowers the MTU (the RFC4638 does a ping of a large packet and it does not receive the reply), when doing the same with an AVM Fritzbox the large
packets just crash the modem and it will reboot and re-train. Likely some buffer overflow somewhere.
dohmniq
Wed Nov 14, 2018 2:37 pm
Update: online!
Probably the most critical aspect was this gem by rendrag:
If you turn OFF auto-negotiate then you will see the "R" running flag but no packets are ever received from the SFP interface.
If you turn ON auto-negotiate, and maybe set advertise=1000M-full as needed, then the next time you insert the modem into the SFP cage it will work!
It's not enough to set advertise and auto-negotiate=on with the device already in place, it needs to be re-inserted after these settings have been changed.
Also, with my hAP ac running 6.43.4 the SFP interface will not work after a reboot, it will again need to be re-inserted.
(I'm about to raise a support ticket for that with supouts)
On the PPPoE front, I set the SFP interface's MTU to 1598 (easily enough for PPPoE + VLAN overhead) and the vlan's MTU to 1560 (easily enough for PPPoE overhead).
The other pppoe-client settings were max-mtu=1500 max-mru=1500, leaving mrru=disabled.
Really glad I don't have to use the locked-down TG589 as a glorified modem.
pe1chl
Wed Nov 14, 2018 3:55 pm
O that is interesting, that must be some bug/feature introduced in RouterOS recently!
When I first received my SFP, it worked fine with auto-negotiate off. I had 1500 byte MTU all working (same as how you wrote above) and the only problem was I did not get my expected line speed and there is no way to monitor why.
Recently I tried the SFP again and same problem as you write: nothing received. I feared I had damaged the SFP somehow and put it aside.
Now I will try again with what you describe.
rendrag
Thu Nov 15, 2018 12:37 am
Oh that could be - You had yours quite some time before I finally got mine, and I think I was on a newer RouterOS version than you at the time, and didn't want to roll back to test it.
it's quite annoying though, as when the SFP does finally stop working (it was every 6 weeks like clockwork for a while, but it's just gone 3 months without a failure until last week..), it means I have to power cycle the CRS109 it lives in, and remove the SFP while it gets power cycled, which means I have to be at home to do it, or talk the missus through it..
timothy77
Mon Feb 18, 2019 12:56 pm
any news from mikrotik support?
dohmniq
Mon Feb 18, 2019 4:40 pm
No reply. I can't even find any "support tickets" section when I log into my Mikrotik account. I guess it's not a priority for them.
On the bright side, uptime now at 13 weeks although I did have to disable/re-enable the pppoe-client entry after being away for a week but everything SFP-wise seems stable.
yacsap
Wed May 01, 2019 12:17 am
Hi everyone,
these are the xDSL ATM settings of the modems mentioned above:
Hi Milotop,
How/where can we configure the VPI setting?
A screenshot from your Inbox with VPI setting would be helpful.
Many thanks,
b.L
[ IMikroTik ] >
pe1chl
Wed May 01, 2019 10:13 am
You cannot configure it. You can only select a VPI/VCI setting from the above list.
You do that by accessing the link via a VLAN as in the last column of the table.
So to use VPI/VCI setting 8/36 you use VLAN 7.
VPI/VCI setting not in the table? -> you cannot use this modem.
yacsap
Wed May 22, 2019 2:44 am
I just used VLAN10 as the ISP has recommended me and it works like charm.
[ IMikroTik ] >
pe1chl
Wed May 22, 2019 10:51 am
So it likely is VDSL, not ADSL, so you do not have ATM and no VPI/VCI settings.
In that case this limitation does not occur.
Do you get the expected speed (same as a ISP supplied modem)?
It still is unfortunate that MikroTik does not add the display of the line parameters for these modems...
Solear
Tue Jun 18, 2019 6:33 pm
I can recommend https://www.mikrotik-shop.de/Interfaces ... :2192.html
I got mine 2 days ago and it works great on a O2 VDSL 50/10 MBit connection.
But it does not work with Dt. Telekom (T-COM) VDSL connections. That should change during 2018.
With my O2 VDSL I got 49.7 MBit down and 9.4 MBit uplink.
1. After inserting the module, it was directly recognized (sfp1).
2. I switched off autonegotiation on the sfp device.
3. I created VLAN7 (vlan7) and connected it to the sfp device(sfp1).
4. Then I created a PPPoE Client, connected it to Interface vlan7 and configured the dial-out setting with my O2 credentials.
Then finally I switched off my FB. :)
That's it ... Really great stuff!
Step 5: /Interfaces/Interface List => WAN => Switch to Interface SFP.
Can confirm. T-Online. Works great, but slower than a Draytek Vigor 130.
VDSL 100/50:
Vigor 130: 91/28
SFP: 75/25.
Thank you all for your inputs :)
Rockyboa
Wed Oct 09, 2019 6:20 pm
Anybody tested any of those SFP modem in north america?
Rock
vortex
Sat Apr 04, 2020 7:27 pm
In the future??? Is DSL the future, I thing PON and SFP is the future!
Swisscom has been offering 500 Mbps G.fast since 2016 and continues working with Huawei on 5 Gbps NG.fast since 2017, even if they keep on rolling out FTTH. Universal FTTP is a more distant future.
There are already G.fast SFP modems.
mada3k
Sat Apr 04, 2020 10:02 pm
How far does 500Mbps VDSL G.fast reach.. 30 meters? :)
Manages some CCR's, RB750Gr3, RB922 and wAP's
vortex
Sat Apr 04, 2020 10:48 pm
Swisscom:
FTTC: up to 550m away, up to 100 Mbps.
FTTS: up to 220m away, between 300-500 Mbps if they installed G.fast, otherwise up to 100 Mbps.
FTTB: up to 500 Mbps
FTTP: up to 1 Gbps (10 Gbps was supposed to start in March).
pe1chl
Sun Apr 05, 2020 12:05 pm
It appears that MikroTik operates in a quite narrow band between "oldfashioned" and "too new".
They have no interest at all in supporting DSL, not even via support of SFP VDSL modems from other sources (i.e. integrate some way to monitor the modem into RouterOS) "because today everyone has fiber and VDSL is the technology of the past and is going away" (that was already their opinion 4 years ago when this topic was started, and likely also before).
Of course quite unrealistic, it is happening in some countries but in many other countries the technology today is still VDSL from streetcabinets with ever faster rates.
But on the other hand, there is almost no support for IPv6 "because our customers do not yet ask for it". (which is even the reply when you ask for it!)
Strange that those countries that supposedly do everything using fiber to the premises, do not use IPv6 yet.
msatter
Sun Apr 05, 2020 12:17 pm
In the Netherlands we have now free router/modem choice. The KPN which is the biggest provider on telephone lines, I can't recommend any Mikrotik router to whom is asking me due to no decent VDSL support.
Many people are looking now for a better router than the one they are hiring right now from their provider.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
vortex
Sun Apr 05, 2020 5:57 pm
There are too many random people clamoring for FTTH when G.fast would be enough for most.
mada3k
Sun Apr 05, 2020 8:32 pm
Personally I think it's insane to keep investing in new advanced equipment for the old copper pairs, Especially when the range is only in a couple of hundreds of meters. When I had ADSL once we had a couple of kilometers to the exchange, then it had it's purpose.
vortex
Sun Apr 05, 2020 8:57 pm
Not every country has cheap labour, and it is quicker to replace a box than laying FTTH. Very few people need 10 Gbps at home.
This "NG.fast" is made for up to 100 meters, so it would be mostly for FTTB (or right outside).
volkirik
Sun Apr 05, 2020 9:04 pm
modems will be ready from broadcom soon:
https://www.broadcom.com/company/news/p ... ases/52671
https://en.wikipedia.org/wiki/G.fast#G.mgfast_(XG-fast)
pe1chl
Sun Apr 05, 2020 9:28 pm
When we are looking for "VDSL support in MikroTik routers" what we realistically mean is "SFP modules working with MikroTik routers".
I once bought such a module and while it "worked" with my router, it did not achieve the speed a regular modem would, and there was no way to check the values in the modem to see why that was.
So what we would need is some way to check the values (like for a fiber SFP) of line attenuation, SNR, max and effective bitrate, etc.
In all these years, MikroTik has not come up with that, so for now we should just take it for granted that they are not interested in helping us.
I am using an external Draytek 130 VDSL modem running in mode 17A for 100/30 Mbps. But should I want to go higher in speed, e.g. using bundling or G.fast, there would be another challenge.
I could get a Draytek 165. But I really would like to get rid of yet another box with yet another power supply and taking up an ethernet port.
Alas, it is not going to change. Just as there is no advance in IPv6 support. "customers are not asking for it" (is being told to all customers that ask for it)
vortex
Sun Apr 05, 2020 9:31 pm
If the "NG.fast" project was supposed to result in a slower product, maybe it is now abandoned.
mada3k
Mon Apr 06, 2020 4:36 pm
Then they should cut the old copper pair and drag an cheap fibre instead. Or at least to the basement of the apartment building. It's not about bandwidth, it's about getting rid of legacy technology. This solutions is like keeping the old phone wires on respirator.
It should be mandatory to provide IPv6 as well.
pe1chl
Mon Apr 06, 2020 5:22 pm
In countries with cheap labor, fiber can be laid to every house at little extra cost.
In completely socialist countries, the cost of the government installing fiber everywhere can be paid by everyone via their taxes.
But in countries somewhere in between, there is nobody paying for the work and so it is not going to happen.
Here in the Netherlands we are right in between: some municipalities have paid for fiber to every home and in other places, housing associations have done the same thing.
But in general, fiber to the home is not available and instead we have either internet-over-cable (cable TV companies' coax) or fiber to street cabinets supplying VDSL over telephone pairs.
(in the past, telephone pairs were installed everywhere in the socialist way)
This situation is not going to change soon.
vortex
Mon Apr 06, 2020 6:37 pm
Why should they remove the copper if it's working well?
They ARE also rolling out FTTH, but they don't have unlimited funds or time.
Swisscom also lays 4 fibres per home (2 for themselves and 2 for other operators).
It is not clear if they will replace the FTTB boxes or directly the copper in the future (in general).
It seems they may lay FTTB and convert the building to FTTH when someone places the first order.
volkirik
Thu Apr 09, 2020 4:49 pm
It is not abandoned.. "NG.fast" and "XG.fast" will be named as "G.mgfast"..
I wish mikrotik make 35b/G.fast/G.mgfast SFP/+ modules. To decrease the price on the market.
vortex
Thu Apr 09, 2020 4:56 pm
But the "NG.fast" prototype was only 5 Gbps. Maybe Swisscom would only be interested in 10 Gbps now.
pe1chl
Thu Apr 09, 2020 6:26 pm
Most important, we do not require any modules from MikroTik when they think it is not worthwile to produce them.
We only need support from MikroTik so that parameters of the line can be viewed and possibly tweaked when such a module is plugged into a MikroTik router.
Similar to what is now possible for fiber modules but with values as usual for DSL.
Of course it would be helpful when there is some standard for that, which does not seem to be the case. So it relies on agreements with a couple of manufacturers.
But still that should be less trouble than design, manufacture and sell a module.
vortex
Thu Apr 09, 2020 6:35 pm
And there is TDSL on the horizon, which targets 10 Gbps @ 500m .
Telecom Italia just activated 200 Mbps FTTC in over 700 localities.
vortex
Fri Apr 10, 2020 12:50 am
I imagine many times putting an SFP modem in Mikrotik would not be considered because of the lack of FXS ports in their routers.
pe1chl
Fri Apr 10, 2020 1:22 am
Why? FXS ports and DSL are totally unrelated.
vortex
Fri Apr 10, 2020 1:28 am
Some phone companies shut down POTS already.
And DOCSIS SFP modems could also exist.
pe1chl
Fri Apr 10, 2020 11:26 am
And so?
Would you want a HDMI connection on your router as well, for the IPtv that most DSL providers have? (at least, here)
I don't see why an FXS port is required on a router more than any other "application" connection.
Most people use their mobile phones also at home here. I do have a cheap VoIP phone on the LAN. External ATAs are
available for like 20 euro.
vortex
Fri Apr 10, 2020 1:14 pm
Many providers give a separate box for TV, including some that previously gave only one for everything. There's little point in replacing an ISP modem router with a VOIP box, which would also cost more than 2 FXS ports in Mikrotik. And you would also have to pay for the SFP, without really reducing clutter.
An ISP could thus provide the usual 2 boxes with Mikrotik (plus an SFP) instead of 3. Or SFP plus TV box (I don't know any "pure" TV box with FXS ports). I doubt they will consider using Mikrotik if it does not have these ports.
Why should people throw away their analog phones?
It does not matter if many people only use mobile phones.
pe1chl
Fri Apr 10, 2020 4:58 pm
I see even LESS point in equipping every router with FXS ports that 99% of the time are completely useless.
Apparently you see a router as a telecom device that should replace an existing telephone line, but in the many MikroTik installations that I have I see only ONE single place where that would be anywhere near useful (my home installation) and I do not need it because I already bought a VoIP phone for the previous router I had which also did not have FXS ports.
All other installs are nowhere near a telephone.
So what? They will not consider MikroTik for such markets anyway!
They already have suitable boxes from many other manufacturers, that they can fully manage using their TR-069 systems and that their helpdesk can support.
They do not need an "advanced router for techie users that still want to connect last centuries phones".
Why should they throw away their AM radios or their record players?
The technology moves on, the way devices are used moves on. They are not forced to throw them away, but they should accept that support will decrease all the time.
Well, of course this matters when a device is being designed. Today most people want WiFi. And high speeds. Not FXS ports.
vortex
Fri Apr 10, 2020 5:05 pm
I did not say all Mikrotik routers should have FXS, but some should. That is the kind of routers ISPs give.
e-waste is bad. No point in replacing an analog phone for VOIP just to make regular calls.
It is bad to have to throw away radios/systems because they switch off FM.
It is bad to make cars which do not have standard stereos.
It is bad to switch off DTT when it is most needed for mobile use.
It is bad to make laptops with non-replaceable RAM, storage, or battery.
It is bad to make hard to upgrade desktops.
It is bad to make smartphones/tablets with non-replaceable batteries or without card storage.
It is bad to make game consoles with hard to replace or without standard storage.
mada3k
Fri Apr 10, 2020 6:38 pm
The big ISPs and telco's will keep using shitty boxes that fits their need and compliance. They have no use for RouterOS features at all.
With that said, I not saying that Mikrotik shouldn't have a xDSL-media-converter like product. Most xDSL-routers are horrible in general.
vortex
Fri Apr 10, 2020 7:16 pm
But I would not replace my cable modem/router for SFP if I have to add an ATA box even if I could.
What about small ISPs that also offer more than just internet?
Alestrix
Fri Apr 10, 2020 7:43 pm
Reading this got my hopes high and I plugged in a GPON ONU that I recently bought to play around with (I don't even have GPON here ;-) ) into my CSS326. I know almost nothing about GPON but AFAIK one needs to set a user-id and/or password in the module. Turns out, my MikroTik does not have the ability to tweak that aspect of the fibre (GPON's fiber, too, right :-P ) module.
I guess what I want to say here: Lets add this to the MikroTik SFP port capability wish list!
Alex
vortex
Fri Apr 10, 2020 7:44 pm
If they want people to switch to digital radio they have to make it better than FM.
Alestrix
Fri Apr 10, 2020 7:48 pm
Don't most people that prefer a "real" router (Cisco, MikroTik, Ubiquiti, Juniper, ...) use a separate modem? The moment you switch the ISP's CPE into modem/bridge mode, the telephony capability of the box is usually lost anyway. So why not use a small SFP modem instead?
EDIT: And as routers and switches often reside in the cellar, attic, or some other "hidden" place, that's a pretty sh#tty place for a phone jack anyway.
vortex
Fri Apr 10, 2020 8:47 pm
If it is impossible to replace the modem router the ISP provides you're stuck with it. Even stuck in NAT mode.
You may be allowed to replace their box but you have to accept a VOIP liability, so I would not.
It is not true that most modems and routers are hidden in a home.
volkirik
Fri Apr 10, 2020 9:18 pm
G.mgfast (multi-gigabit fast) will be supporting both 5Gbps and 10Gbps profiles.
vortex
Fri Apr 10, 2020 9:25 pm
But I assume NG means 5 Gbps. Swisscom's goal could always have been 10.
vortex
Sat Apr 11, 2020 2:36 am
Even listening to the radio on DVB-C can't touch streaming at a proper quality level.
Alestrix
Sun Apr 12, 2020 2:38 am
What do you mean with "VoIP liability"? I received the SIP credentials from my ISP, so I was able to use my own hardware for everything - DSL modem (DGA4132), router (Ubiquiti ER-X), SIP-Client-DECT-Combo (FritzBox).
vortex
Sun Apr 12, 2020 3:03 am
Some ISP will release the SIP credentials if you ask for them, but then if a criminal makes calls with them from anywhere in the world you have to pay.
vortex
Sun Apr 12, 2020 11:10 pm
There's already something better than DAB+: DVB-T2 Lite.
pe1chl
Mon Apr 13, 2020 1:41 pm
Hey vortex,
Can you please take your wildly offtopic discussion to a different topic?
In this topic we try to discuss the possibility of having a VDSL-capable MikroTik router, e.g. by having a VDSL modem as an SFP module added to an SFP-equipped MikroTik router, and supported in RouterOS so it can be monitored and configured.
I could see the tangent of having a DOCSIS SFP perform a similar task and similarly supported as being valid in this topic, as it would require similar RouterOS support, but it doesn't exist and it does not seem to be planned by anyone.
However, all that babble that you started about having to support FXS and SIP for you to accept that as an alternative (noting that it is not even viable because there IS no DOCSIS SFP module) and now even wandering off into audio/video broadcast technology really isn't to the point anymore.
vortex
Mon Apr 13, 2020 2:48 pm
Just to make it full circle that this DAB story looks like ISDN and minitel.
Is anybody still using ISDN?
The BBC does for audio.
vortex
Tue Apr 14, 2020 1:52 am
I looked at a study and one would need 192 kbps DAB+ (172 kbps of pure AAC audio) to equal FM.
Perceptual transparency would supposedly be attained by 284 kbps (DVB T2 cannot do it either).
volkirik
Tue Apr 14, 2020 5:21 am
unfortunately Mikrotik xDSL modem is not going to be produced.. They focus on active fiber and GPON.. the response from mikrotik was:
xDSL and G.fast are old technologies. Big chip makers quited that market long time ago. Intel, Qualcomm, Marvell... they sold or closed their xDSL and G.fast groups.
vortex
Fri Apr 17, 2020 6:59 pm
I just thought of something I don't want to keep hanging:
If you keep FM, people will not need to throw away their DAB+ radios when it is replaced by T2 Lite.
volkirik
Sat Apr 18, 2020 12:54 pm
pe1chl
Sat Apr 18, 2020 1:27 pm
MikroTik does not need to produce a DSL modem, they only have to support DSL SFP modules that other manufacturers already produce and can be used in MikroTik routers that have SFP.
Similar to supporting USB sticks for mobile telecom (4G etc).
Of course it would not be a good idea to produce a router model with DSL builtin. It would cost a lot of money to develop such routers in every performance category.
nz_monkey
Mon Apr 20, 2020 2:10 pm
I disagree. The SFP VDSL modules run hot, e.g. around 80degrees Celcius. This might be OK in your country, but in Australia they are too hot and unreliable.
Mikrotik could easily make use of ODM design services from the chipset manufacturers or their partners. This is no different to the big name SOHO router manufacturers using the likes of Compex to design the PCB's in their routers.
ADSL/VDSL are still mainstream and current technologies in a lot of countries for better or worse.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
vortex
Mon Apr 20, 2020 4:17 pm
If Mikrotik made a DOCSIS SFP modem, people could use them in some countries.
pe1chl
Mon Apr 20, 2020 5:09 pm
But they are not interested in that. This has been te response to several people making this query, I also tried that years ago and even then they were not interested.
Here we run in the problem that MikroTik is from a country that joined the western society later than others, and where the "disadvantage of being first" does not apply so much.
Over here the majority of internet connections is DSL and cable, fiber to the home is only a small segment. But apparently in Latvia and other countries everything is fiber.
Good for them, but not very useful for us. We would have to wait until every home and business is connected to fiber, and there is no such initiative currently going on.
I agree with you that SFPs run too hot, kind of a generic problem with SFPs, they are just designed too small. A device supporting SFP should have a fan that blows air out
through the SFP. When I would use my 180-T (which I can't, because RouterOS does not support it well enough) I would probably try to apply some heatsinking.
vortex
Mon Apr 20, 2020 8:35 pm
If no one has made a DOCSIS SFP modem it would be a very interesting product, even if it cannot be used by everybody.
vortex
Fri May 08, 2020 3:53 am
I hope DVB-I will get rid of TV boxes in most countries.
Availability of DOCSIS SFP will be more important.
mada3k
Sun May 10, 2020 8:35 pm
I don't think it's possible to fit a DOCSIS frontend in a regular SFP. DOCSIS also needs a fair bit of power for the RF-stuff.
Possible in a QSFP, but that would be ridiculous.
vortex
Sun May 10, 2020 9:19 pm
What about FD-SOI ?
But maybe it is not powerful enough for the front end.
antiknock
Mon Jun 29, 2020 12:03 pm
Howdy ho!
I just thought about acquiring such a tiny SFP VDSL2 thingie, just to get rid of another device that needs to be plugged into a wall socket, wasting space... Altough this is not down under but Central Europe, temperature issues are issues to me and so not wanted. At least 80°C sounds like a serious temperature issue.
Anyone else has issues with the temperature? Are there any differences when it comes to different makers?
Thanks!
Regards
anTIKnock
It's a hard knock life...
Users browsing this forum: No registered users and 18 guests
