It is not available! it will be available in february next year. hopefully. and then it will have to be tested.I speak about the sfp what would be already available
That's what I want them for as well. I used a few Draytek 120's for ADSL clients, until they started breaking and I replaced them with TP-Link TD-8817s. Makes me a bit nervous of using the 130. I've only used one so far, and it worked fine, but that's not a very scientific test.Now that the Abbott/Turnbull government has decimated the NBN here in 'Srayamate and turned it into last century's VDSL2+ (with Vectoring) network, having a MikroTik-compatible (and preferably MikroTik-provided) VDSL2+ GBIC module would be awesome for our Not Broadband Network deployments here. It will save us buying Draytek 130 units for every site, running them in Bridge Mode and then having a suitable MikroTik router behind them.
Sorry had only just seen this.That is nice for using on a PC platform.My proxmox host running the CHR has a Draytek vigornic 132 in bridge mode for modem (It's essentially a vigor 130 on a PCI-E card)
How does it appear in the host system? As an ethernet card? Which driver?
I think the "EBM program" is the same as "Ethernet Boot and Management" mentioned further down in the spec sheet. I wonder if it's simply accessible via a default IP address where you can configure the VPI / VCI for the EoA bridge.There is some mention of a configuration program (probably only for Windows), but not how it accesses the module.
You can search for it in this patent doc...I think the "EBM program" is the same as "Ethernet Boot and Management" mentioned further down in the spec sheet. I wonder if it's simply accessible via a default IP address where you can configure the VPI / VCI for the EoA bridge.There is some mention of a configuration program (probably only for Windows), but not how it accesses the module.
That would be nice, but when it can be accessed using a (temporary) bridge between the SFP slot and an ethernet port,If so, this needs to be accessible remotely, ie through the usual RouterOS management tools.
It's February now, any news?it will be available in february next year. hopefully. and then it will have to be tested.
Why is that? Is this something that MikroTik could handle in RouterOS?A lot of the Metanoia re-sellers will program these to look like a ZX module, and the Mikrotik will NOT let this work.
Did you follow this and other threads about VDSL? That will not happen. And I can understand it, it would require new expertise+1 for RB-951Ui-2HnD and RB952Ui-5ac2nD-TC with built in VDSL port.
That is unlikely. With SFP you can use various things and vdsl 2 SFP modules are already available for use though not sure if mikrotik sells them. SFP and ethernet together make for a very good router as it gives you a lot of flexibility and allowing routerOS to directly handle the interface. The other point is that modems arent on the WAN side so you can secure things better.Did you follow this and other threads about VDSL? That will not happen. And I can understand it, it would require new expertise+1 for RB-951Ui-2HnD and RB952Ui-5ac2nD-TC with built in VDSL port.
and after making 2 such routers the people would ask "please a 3011 with VDSL", "please a CCR with VDSL" etc etc.
What we are concentrating on now is to get a VDSL SFP supported and hopefully sold by MikroTik.
So any router with SFP, like hEX PoE, hAP ac, RB2011, RB3011, CCR can get optional VDSL.
Hi there , just a quick question about using Draytek 130 units in bridge mode for NBN connections using MT's : do you know if they work for NBN providers that use 802.1q VLAN ID 100 settings for their NBN FTTN services ?Now that the Abbott/Turnbull government has decimated the NBN here in 'Srayamate and turned it into last century's VDSL2+ (with Vectoring) network, having a MikroTik-compatible (and preferably MikroTik-provided) VDSL2+ GBIC module would be awesome for our Not Broadband Network deployments here. It will save us buying Draytek 130 units for every site, running them in Bridge Mode and then having a suitable MikroTik router behind them.
Just the thing I was looking for myself. Need to connect 2x VDSL 50/10 connections to my CCR1016-12S-S1+Just found this at Allnet, but can only be ordered by resellers:
https://shop.allnet.de/detail/index/sAr ... egory/1986
Yes, I had to create a VLAN on the SFP interface and authenticate with PPPoE before I got any traffic running. This is standard with most VDSL connections here.Great!!
I presume you further created a VLAN interface on top of the SFP, and a PPPoE interface attached to that VLAN?
(or maybe DHCP client when that provider does not use PPPoE)
Is there any way to access the connection info from the router or from a machine behind the router?
(to see the line mode, actual/attainable connection rate, SNR, number of re-trains, etc)
I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules. I have tested the units with an RB2011 and CCR1009 but we have received reports that the RB3011 does not work with the modules at the moment. We are working with Proscend/Metanoia on this. So far, they have not found any issues with synchronization or throughput as long as the SFP interface is manually set.Versatek have them in stock. https://www.versatek.com/product/vx-160 ... ems-co-rt/
I hear Allnet (allnet.de) are investigating them too and might have something in Q4 2017.
I can counter the RB3011 comment because I have actually made it work with one of those (RB3011 + 180-T).I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules. I have tested the units with an RB2011 and CCR1009 but we have received reports that the RB3011 does not work with the modules at the moment. We are working with Proscend/Metanoia on this. So far, they have not found any issues with synchronization or throughput as long as the SFP interface is manually set.Versatek have them in stock. https://www.versatek.com/product/vx-160 ... ems-co-rt/
I posted screenshots on page 2:Milotop, can you share a screenshot of the SFP interface? We received one report of a "Rx Lose" status. Wondering if you experienced that as well.
Thanks! Wasn't sure which router board you were using. I'll be doing more tests with these against Broadcom, Metanoia, Ikanos and Infineon based VDSL2 DSLAMs. Line stats will be posted shortly with various distances once I get back to the office if anyone is interested. We have also sent 2 units direct to Mikrotik today. Not sure if they will be testing these as well.I posted screenshots on page 2:Milotop, can you share a screenshot of the SFP interface? We received one report of a "Rx Lose" status. Wondering if you experienced that as well.
viewtopic.php?f=3&t=104109&start=50#p600823
Versatek has the product "VX-160CE VDSL2 SFP Modem (Remote Telco Grade)".I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules.
pe1chl,Versatek has the product "VX-160CE VDSL2 SFP Modem (Remote Telco Grade)".I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules.
Is this originally a 180-R or 180-T? I need the 180-T that supports vectoring.
Prices I was quoted are:What are people paying for one of these SFP units? It would seem I need the T model to connect to an ADSL service and replace the provider leased modem correct?
I didn't see the RX Lose that you saw. I simply plugged it in, booted the RB3011 and changed the SFP module's speed to 1Gbit/s full duplex. I didn't need to do anything else. You might have received a broken SFP module or RB3011.I can counter the RB3011 comment because I have actually made it work with one of those (RB3011 + 180-T).I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules. I have tested the units with an RB2011 and CCR1009 but we have received reports that the RB3011 does not work with the modules at the moment. We are working with Proscend/Metanoia on this. So far, they have not found any issues with synchronization or throughput as long as the SFP interface is manually set.Versatek have them in stock. https://www.versatek.com/product/vx-160 ... ems-co-rt/
Milotop how did you get that to work on RB3011 ?
I have tried these Procend 180-T on a RB3011, but there it shows RX Lose. i Have 2 of these and both show RX Lose on RB3011.
On the RB962UiGS the same modules work fine.
For ADSL please see the picture I posted on page 2 specifying the supported ADSL modes.Thanks, can you confirm the tell version is the unit I'd want?
Interesting, I'll wait for news.Got the Procend 180-T ..[cut].. I will post some results..
Yeah, that would be very interesting. I am already in contact with Allnet but they mean that they can't ship before Q1/2018.Interesting, I'll wait for news.Got the Procend 180-T ..[cut].. I will post some results..
Have anyone links of EU/shops where these modules are available? thanks..
Proscend endorses Versatek for US distribution:Yeah, that would be very interesting. I am already in contact with Allnet but they mean that they can't ship before Q1/2018.Interesting, I'll wait for news.Got the Procend 180-T ..[cut].. I will post some results..
So i hope anybody got another reseller. US would also be fine.
Thanks!
Gesendet von meinem HUAWEI GRA-L09 mit Tapatalk
I must check if they ship to EU, thank you anyway..Proscend endorses Versatek for US distribution:
https://www.versatek.com/product/vx-160 ... lco-grade/
They just restocked apparently.
They are a distributor, and they list a couple of resellers.I must check if they ship to EU, thank you anyway..
[admin@sw2] /interface dsl> set
Change properties of one or several items.
<numbers> -- List of item numbers
arp -- Address Resolution Protocol
arp-timeout --
comment -- Short description of the item
disabled -- Defines whether item is ignored or used
l2mtu --
mac-address --
mtu -- Maximum Transmit Unit
name -- Interface name
vci --
vpi --
Hopefully we willWill we see DSL modems soon?
Where did you find this?Will we see DSL modems soon?
Code: Select all[admin@sw2] /interface dsl> set Change properties of one or several items. <numbers> -- List of item numbers arp -- Address Resolution Protocol arp-timeout -- comment -- Short description of the item disabled -- Defines whether item is ignored or used l2mtu -- mac-address -- mtu -- Maximum Transmit Unit name -- Interface name vci -- vpi --
Doesn't show up on my RB960PGS on either 6.41rc20 or the latest 6.41rc/interface dsl on RB750GL / 6.41rc20
https://forums.whirlpool.net.au/forum-r ... ?t=2671952have tested the proscend 180-T here in australia (NBN FTTN 50mb/20mb service) and works fine (using hAP ac / RB962).
I am in de ordering process but I am stuck at the payment options...Ordered 2 to see, how they'll perform on VDSL in Ireland.
"Prepayment by Wire Transfer" is EURO bank transfer i reckon. It's a bank holiday in their region in Germany today, so they won't respond before tomorrow anyhow either way.I am in de ordering process but I am stuck at the payment options...Ordered 2 to see, how they'll perform on VDSL in Ireland.
Do you see an option to do a EURO bank transfer? They don't offer creditcard payment.
I did get a response today and it was just a normal EURO transfer (Germany operates in EUR). So shouldn't be an issue.Ok, I got an automatic mail message when registering and replied to it, but thanks for the info, I will wait and see what options they offer.
(wire transfers tend to be quite expensive when they are not completely standard IBAN EURO transfers so I'd like to make sure)
Thanks. It looks like mine is on the way... hopefully arrives later this week.I did get a response today and it was just a normal EURO transfer (Germany operates in EUR). So shouldn't be an issue.
Can you tell us what kind of speeds you're getting on it?Ok, the problem was in VLAN connection. Had to find out VLAN ID from ISP and add VLAN interface connected to SFP port and make PPPoE bound to VLAN interface. Now it works like a charm.
Thanks,
Regards,
Petr Sourek
Of course, you can even use them to join two switches over a copper pair without a router, that is the purpose they were invented for.I wonder if these SFP modules can be used in a switch and then a router instead of directly connected to a router.
The T-model probably not .. well, unless it's a Mikrotik switch running RouterOS .. then you can.I wonder if these SFP modules can be used in a switch and then a router instead of directly connected to a router.
Has anyone tried this scenario?
Since I have slow connection 8Mbit/1Mbit, the module is able to achieve them.Can you tell us what kind of speeds you're getting on it?
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 44870000 bps US Actual Rate : 17465000 bps
DS Attainable Rate : 45041488 bps US Attainable Rate : 17465000 bps
DS Actual Rate :103349000 bps US Actual Rate : 17465000 bps
DS Attainable Rate :106387120 bps US Attainable Rate : 38060000 bps
Grüß Gott, Klaus!Hello!
I´m located in Austria and I also got a Procend 180T this Friday.
Klaus
They are available shipped from Germany, see above.
Thanks, due to current reconstructions the new link is: http://www.mikrotik-shop.de/Interfaces/ ... :2192.htmlThey are available shipped from Germany, see above.
Does it work with German T-Com VDSL?Ok, you are too late! I received one...
No idea, I am not in Germany. Probably it will, but some more tweaking could be required, for me it does not work optimally.Does it work with German T-Com VDSL?
I am waiting for delivery and post results in about 10-14 days from now.Does it work with German T-Com VDSL?Ok, you are too late! I received one...
It didn't do that here. The first night after I plugged it in it resynced at about 04:00 but my ISP does that automatically when it sees that a new modem has been plugged in on a line and the rates are suboptimal. That way the modem often re-trains at a higher rate and the problem is fixed.I have been testing a 180-T but it seems to resync every 10-12 hours.
Has anyone else seen this sort of instability ?
I haven't been able to find a mini-PCI(e) VDSL interface at any price, never mind cheap.BTW, are there any cheap mini-PCI VDSL
Draytek VigorNIC 132F (from memory)I haven't been able to find a mini-PCI(e) VDSL interface at any price, never mind cheap.BTW, are there any cheap mini-PCI VDSL
Just realised my memory isn't quite right. The Draytek isn't mini-PCIe.Draytek VigorNIC 132F (from memory)I haven't been able to find a mini-PCI(e) VDSL interface at any price, never mind cheap.BTW, are there any cheap mini-PCI VDSL
In addition, in response to different network environments and different user needs, VigorNIC 132 series is not just a network card but also a router with DrayTek owned DrayOS software inside. The built-in DrayOS system allows users to set it to bridge mode or router mode based on different environment. It also provides an object firewall functions. With the high-speed PCI-e bus interface, VigorNIC 132 series can avoid congestion and packet delay. Besides, the PCI-e interface also offers power directly to save the power consideration and has the advantage of lightning or power surges protection. Moreover, the maximum power consumption of VigorNIC 132 series is only 6 watts.
Hey Nick,I have been testing a 180-T but it seems to resync every 10-12 hours.
It does sync at a high speed on my line, and latency is low when it is working, but drops twice a day.
Nick
180-T works ok in Poland Orange over VDSL alsoHey Nick,I have been testing a 180-T but it seems to resync every 10-12 hours.
Nick
Can't confirm that. For me here in austria the modul works absolutly perfect! Current PPPoe-Session Uptime is 3d.
Especually your Profil isn't correctly supported? Or your connection-mode?
Here we got G993.2 and Profil 17a.
Kind regards
Yes. You need to disable auto-neg, set 1Gb fixed and create an interface with VLAN ID 7.Does it work with German T-Com VDSL?
Hi, send me an DM if you want to buy my SFP.Can you recommend a (german) retailer that has this SFP in stock?
Why so? If that's when you get migrated to BNG, it should still work now on the old BRAS.But it does not work with Dt. Telekom (T-COM) VDSL connections. That should change during 2018.
On my Dutch (KPN) line it takes quite long to sync compared to the normal modem and after that it has negotiated a lower rate. I get linesync like you (above-100/around-40) on my Draytek or on a Fritzbox but on the SFP it is only around 40 download (cannot see exactly what happens due to the lack of status display).fyi: I’ve ordered and received a VersaTec vx160ce and put it my UniFi switch. It powered up fine and it is recognized by the switch somewhat. It does not sync on my German Telekom VDSL line (100/40) however.
The device powers up and blinks green slow and then a bit faster, which means it does not sync. I have had no problems with my Fritzbox which always syncs with 109/41 and a line capacity of 139/41. The line is flawless from a vectoring standpoint.
Try to reflash the Draytek with different modem versions (modem1..modem7 I think it was), also versions that are not listed as recommended for your ISP.I’ve tried to replace the fritzbox first with a Draytek Modem,but that failed as the connection speed and esp. the pings on the Draytek 130 were poor.
I still keep mine around hoping that MikroTik will add a command to display the status and maybe there will be new firmware for it... although I have no idea how that would have to be flashed.So now I tried with the sfp module and that did not sync - well it was not more than a long shot that failed so I’m sending that back as well except someone here wants to buy it.
I've tried this scenario with the Proscend 180-t in a Netgear GS110T switch and I can confirm that it works. The module acts as a bridge between the VDSL and SFP interface of the switch. I was able to add a trunk setup to the SFP port on my switch and send the two VLAN's (TV and Internet) out untagged on two separate ports to my router. I got both Internet and TV working without any significant problems.I wonder if these SFP modules can be used in a switch and then a router instead of directly connected to a router.
Thanks for the info!Hallo Mikrotik Fans,
sorry but i want to tell you the trougth. For the German Market and German ISP connections only ALLNET will be have the right Hardware who will working.
Alternatives for Bridge-Modem for German Connections
ADSL based on Lantiq = ALL0333CJ = https://shop.allnet.de/search?sSearch=all0333cj
ADSL & VDSL based on Broadcom including Vectoring = ALL-BM200VDSL2V https://shop.allnet.de/search?sSearch=all-bm200
VDSL2 based on Lantiq Vinax V3 including Vectoring "Best-Performance on VDSL2" = ALL-BM100VDSL2V = https://shop.allnet.de/search?sSearch=all-bm100
Thanks Gerhard Zerwes "Head of ALLNET Product-Brand"
They aren't. And if they were, this functionality would probably not (yet) be accessible from RouterOS.It would be great if the VPI/VCI settings were a little more flexible.
OK good to know, I understand the VLAN configuration to access the different settings - I think it's maybe too much of a niche product for us to pursue.They aren't. And if they were, this functionality would probably not (yet) be accessible from RouterOS.
I haven't been able to find any information about a management option from the DSL side of the device. Given its form-factor, I think it's very unlikely that this device offers such an option though. Since the device acts as a bridge between xDSL and SFP, any internet provider could certainly setup a management VLAN on the CPE but without special drivers, you would not be able to manage the internals of the module directly. An alternative would be TR069.Do you know if VDSL Vlan 835 is managed.
VPI/VCI is hardcoded into the module so you would have to contact the manufacturer to ensure that the modules you receive have the right values. VLAN is done after the packets exit the module so the standard VLAN config of the host device can be used. For instance, my VLAN config is done through the Mikrotik interface. No special software or drivers were required.How the couple adsl vp vc or vlan in vdsl is done ?
I'm afraid I don't know if all resellers sell the same product. I do believe it is very likely that they are all manufactured in the same factory.Ok Yes for VDSL we can configure Mikrotik for use VLAN.
For ADSL we need to chhose couple VPI/VCI which need, if we can configure it, to provide hard coded inside.
Do ypou know if all reseller sell modules form same manufacturer ?
Can I have to ask them ?
Hallo Alex,Thanks for the info!Hallo Mikrotik Fans,
Regarding the ALL-BM100VDSL2V, do you have a firmware update that irons out the problems described at
https://geizhals.de/allnet-all-bm100vds ... _ratings=1 (German)
Sorry for OT.
Cheers
Alex
Sent from Honor 8 using Tapatalk
Hallo Sub5,Will you also offer a Standalone CO-Module without the CPE-Module?
Hallo Loice,Hi all
We are interesting to test for french market.
We are network provider with adsl and vdsl.
So is there different manufacturer or all module described in this thread is from metanoia ?
Is allnet or mikrotik shop.de is the same ?
Best regards
This is not right, the CO Module works fine as DSLAM for Avm Firtzbox, Telekom Speedport, Zyxel VDSL Modem, INtec Argus DSL-Tester.Hallo Sub5,Will you also offer a Standalone CO-Module without the CPE-Module?
the the ALL4780 is a specific Bundle with Co and CPE inside the Box. Only Point-to-Point. Special Firmware who supporting max. 150MBPS. Only this CPE is working with the Slave CPE.
THe ALL4781 is Standard VDSL for German Market with Profile 17 etc.
Thanks Gerhard
I´ve tried this, but the needed Addresses are lockedMay be the parts can be reconfigured with USB SFP reader.
We're have these functions with our Fiber SFP optics manufacturer
Regards
That's exactly the scenario I want to use it for. So please: really offer a CO-only option, Gerhard!This is not right, the CO Module works fine as DSLAM for Avm Firtzbox, Telekom Speedport, Zyxel VDSL Modem, INtec Argus DSL-Tester.Hallo Sub5,Will you also offer a Standalone CO-Module without the CPE-Module?
Thanks Gerhard
I got mine from Versa Technology last year. I used an VX-160RT with an RB3011 to connect to an VDSL line (Austria, Annex A, 17a) just fine. Just in case the feedback helps still (yes, I know the post is a bit old).I am actually employed by Versa Technology and we have received quite a bit of inquiries and sales for the VDSL2 SFP modules. I have tested the units with an RB2011 and CCR1009 but we have received reports that the RB3011 does not work with the modules at the moment. We are working with Proscend/Metanoia on this. So far, they have not found any issues with synchronization or throughput as long as the SFP interface is manually set.
Hi Gerhard,
The 180C/R foir Point-to-Point over 2 Wire = ALL4780 = https://shop.allnet.de/detail/index/sAr ... h/all4780
The 180T "GERMAN VERSION" will be called = ALL4781 = https://shop.allnet.de/detail/index/sAr ... h/all4781
I don't suppose you've gotten anywhere with this? Or have any more info on it? Would be really nice to pull some info out of the SFP..As far as I understand to get stats I'd need to send an ethernet frame with an command/query to the SFP (with the SFP MAC as destination) and would get an response with the requested data back. Would be nice to get this working even if not directly on RouterOS but from an host connected to an routerboard (bridged with the SFP).
It is the topic of this thread. They should support those SFP modules in RouterOS or could even relabel them under the MikroTik brand.Why hasn't MT started making it's own VDSL2 SFP Module?
Is anyone using these on a production service? I'm seeing a weird issue (plugged into a CRS-109, on a VDSL2 connection), where it just stops passing data between the VDSL connection (which still has sync according to the status LED on the SFP), and the SFP interface. Power cycling the switch does not fix it (infact, I've not had much luck using the SFP at all if it is plugged in when the switch is powered on). - The SFP must be unplugged and re-plugged while the switch is powered, then it works fine. I'm getting about a week out of it, and then it needs to be removed and re-inserted.
Because of all of that I was thinking that the Proscend 180-T would work on my VDSL2 line. But it does not.Hello!
I´m located in Austria and I also got a Procend 180T this Friday. It´s working fine in a hAP ac and achieves full provided speed (80/15Mbit). The pppoe-Client is operating over Vlan´s on my CCR1009.
Klaus
I'm guessing I see a related issue here. I have a Proscend 180-T plugged into a hEX PoE, and the link works in principle. However, a simple reboot of the hEX will cause the link to stop working with the same symptoms you describe. Also, unplugging and replugging the SFP returns the link into a working state.I don't suppose you've gotten anywhere with this? Or have any more info on it? Would be really nice to pull some info out of the SFP..As far as I understand to get stats I'd need to send an ethernet frame with an command/query to the SFP (with the SFP MAC as destination) and would get an response with the requested data back. Would be nice to get this working even if not directly on RouterOS but from an host connected to an routerboard (bridged with the SFP).
Any updates on this?
Yep, I tried that. In fact, the DSL link won't even come up properly if auto-neg is not turned off.Have you tried, what I suggested above ?I'm guessing I see a related issue here. I have a Proscend 180-T plugged into a hEX PoE, and the link works in principle. However, a simple reboot of the hEX will cause the link to stop working with the same symptoms you describe. Also, unplugging and replugging the SFP returns the link into a working state.
Disable auto-negotiation and set the speed to 1 Gbit/s + FD manually. Then try rebooting etc.
I'm on 6.41.2 on a hEX PoE (960PGS).What version RouterOS are you on ?
So wanna try upgrading to 6.41.2?Ive got it running on a CCR1016 and a couple hAP ac all on 6.40.5.
No problems.
So wanna try upgrading to 6.41.2?(Don't even know whether that's available for CCR1016.)
No, not really unfortunately. I'll try to follow up with Metanoia.I don't suppose you've gotten anywhere with this? Or have any more info on it? Would be really nice to pull some info out of the SFP..As far as I understand to get stats I'd need to send an ethernet frame with an command/query to the SFP (with the SFP MAC as destination) and would get an response with the requested data back. Would be nice to get this working even if not directly on RouterOS but from an host connected to an routerboard (bridged with the SFP).
Sorry, no. I only tried it in an hAP AC and RB3011 . In both it seemed to be stable. The RB3011 was running on an VDSL in Austria for about 1.5 months without any issue. The hAP ac was on an point to point with the versatek bundle.Is anyone using these on a production service? I'm seeing a weird issue (plugged into a CRS-109, on a VDSL2 connection), where it just stops passing data between the VDSL connection (which still has sync according to the status LED on the SFP), and the SFP interface. Power cycling the switch does not fix it (infact, I've not had much luck using the SFP at all if it is plugged in when the switch is powered on). - The SFP must be unplugged and re-plugged while the switch is powered, then it works fine. I'm getting about a week out of it, and then it needs to be removed and re-inserted.
No, this thread is by users discussing what they have found on internet, bought themselves to experiment, and their findings.This is a very long thread now. Is there a summary in the Mikrotik documentation that describes the SFP dsl hardware that works with Mikrotik routers (with settings)?
Hi BigTrumpet,I can confirm that Proscend 180-T is working with RB2011 and italian VDSL2 (TIM).
We distribute the Metanoia V5311-T-R in New Zealand and are working on this with the manufacturers.I've recently purchased this to use with ADSL, but I can't seem to get it working. The LED is green which seems to indicate SHOWTIME.
I've set up an interface on my CPE as VLAN 6 (matching VCI/VPI 0/100 which is what I need) and used a PPPoE client, but it doesn't receive any packets on the interface nor an IP address. Is it correct that I need to tag packets with a VLAN tag in order to get it working?
Has anyone used it with ADSL successfully, who could share their configuration?
What method do you use to read back the connection parameters and values in the test environment?We distribute the Metanoia V5311-T-R in New Zealand and are working on this with the manufacturers.
We have the V5311-T-R working now on NZ EUBA ADSL in a test environment currently. Once all tests are done we will contact customers directly with the necessary updates.
Hi Stef84,Hello everybody.
In my country they are installing FTTC fiber optic from TIM and I would like to foresee an eventual upgrade.
I am looking for a VDSL2 modem to connect to my Mikrotik devices in my network and I have seen the Proscend 180-T product that I could connect to my RB2011's SFP port.
do you know if it could be compatible with Fibra TIM (O Fastweb or OpenFiber)?
Someone in Italy has carried out these tests?
Thanks in advance
Thanks for the reply. I thought this modem was better than the Technicolor and that it will reach higher speeds than the TIM modem.Hi Stef84,Hello everybody.
Thanks in advance
we have installed the 180-T with TIM FTTC many times, and all succesfully.
The speed is lower than Technicolor modem (especially if you are far from the DSLAM, example 40Mb vs 50Mb but if you are near DSLAM the speed is similar to the Technicolor modem), but it works perfectly.
Bye bye
A.
I think it very much depends on what vendor DSLAM you are connecting to.Thanks for the reply. I thought this modem was better than the Technicolor and that it will reach higher speeds than the TIM modem.
If you tell me so, I do not think it is convenient to buy, rather better to use the original modem in bridge mode and run pppoe authentication with mikrotik.
We built an L2 tunnel back to the factory and all the magic happened there so unfortunately we have no visibility.What method do you use to read back the connection parameters and values in the test environment?We distribute the Metanoia V5311-T-R in New Zealand and are working on this with the manufacturers.
Do you have any contact with MikroTik support about it? Is there any indication that they will add some feature to RouterOS to readout these values while the SFP is in the router?
Hi marlow,What Mikrotik device are you using ?
Do you have it in a SFP or a 1G/10G port ?
What version of RouterOS does your device have ?
It won't working in 10G ports and for some of the devices you may have to set 1G full-duplex and disable autonegotiation.
/M
Works fine even if it does not support profile 35b which is the one my provider gives me, so it connects at a much lower speed.
also in the logs of the mikrotik i spotted this: "fcs error on link" on the sfp interface... only 2 times but still doesn't sound good...
also this might be unrelated but on another interface i have in a bridge on the lan side i get this : bridge port received a packet with own address as source address, probably loop.
I don't know about Proscend, however when I got my Versatek bundle I was curious if it would work on a UK BT ADSL line. To my surprise it worked (note that the SFP isn't certified with BT requirements SIN346/SIN498 as far as I know).I contacted Proscend regarding the VPI/VCI settings for the 180-T and was told unequivocally that the device does not support ADSL. I found this very strange as the data sheet does have the ADSL2+ specifications, so I asked for clarification and was again told that they do not have any devices that support ADSL.
This was Proscend's "Marketing & Sales Director" so one would think he would be able to talk authoritatively about the capabilities of his products. My guess is that they have quietly withdrawn this feature. At any rate I'm not deploying CPE devices in a mode that isn't supported by the manufacturer so it looks like we're back to no options for ADSL.
What kind of magic happens there? Just monitoring or does it configure the SFPs too (or even allow firmware updates)?We built an L2 tunnel back to the factory and all the magic happened there so unfortunately we have no visibility.
There is an API available by subscription - it would be nice if MK directly integrated this but I suspect the cost is too high.
I've had the same issue with an ALLNET ALl4781 and a RB3011. The ISP side diagnostics and LEDS tell me that I've synced successfully but the MikroTik unit has yet to pick up on this and it still stuck in "Rx Lose" status. I've logged a support ticket, and we'll see what happens. This seems to be the same issue as someone is having with the 1000BASE-LX/LH (GLC-LH-SM) (viewtopic.php?t=122917) so I'm guessing it's an issue on the MikroTik side.Hello,
I just received one of the Proscend 180-T units from mikrotik-shop.de ...
the unit seems to be working fine, according to the leaflet the connection with the DSLAM works fine, solid orange and green leds, but in mikrotik i get an Rx Lose status and it doesn't work.
what could be the issue?
There is if you read the Metanoia patent (http://www.freepatentsonline.com/20160241293.pdf) something that they call the Ethernet Boot and Management protocol that you can use to change settings and read the status by exchanging inband ethernet packets with the device. There is in theory a piece of Windows software that can be used to interface with the device, but from what I have seen on the internet it does not work (see https://forum.turris.cz/t/vdsl-sfp-bridge-modem/1296/21). In theory if one could get that working it would be trivial to use Wireshark to snoop on the device and write some replacement software to get stats, status of the device, change settings etc. on Linux which would could then be added to RouterOS, or even Ubiquiti/pfSense if that is your poison.What kind of magic happens there? Just monitoring or does it configure the SFPs too (or even allow firmware updates)?We built an L2 tunnel back to the factory and all the magic happened there so unfortunately we have no visibility.
Do you have more details on the API? Any indication of cost, e.g. would be likely workable for an end user with a few of the SFPs?
Note that while the U.K. remains in the E.U. BT SIN498 is illegal, as it is in direct contravention of article three paragraph 1 of EU regulation 2015/2120, which states :-I don't know about Proscend, however when I got my Versatek bundle I was curious if it would work on a UK BT ADSL line. To my surprise it worked (note that the SFP isn't certified with BT requirements SIN346/SIN498 as far as I know).
Which exact device model did you buy? Previous posts suggest that ALLNET devices only work with ALLNET DSLAMs for example. Which UK ISP are you with? Huawei or ECI DSLAM?I have given one of these a go in the UK in an RB3011, however I don't seem to get sync. I just get the amber light and the light on the right flashing green.Tried turning off auto negotiation,rebooting ect. Any ideas? Anyone got these working in the UK?
The cab doesn't necessarily come with the DSLAM. Could be anything in there.I have a Versatek VX-160CE, however it shows up in the 3011 as a Proscend 180-T. The ISP is PlusNet. I don't know what DSLAM is in place, ill go and have a look at the cab as I think they are physically different?
That's interesting...I have a Versatek VX-160CE, however it shows up in the 3011 as a Proscend 180-T.
No, it would be a can of worms. Every country, every provider uses slightly different setups and wellknown DSLxDSL modem from Mikrotik would be great....
No. They have their own stickers on the SFPs, but they come up as Proscend 180-T in the SFP information in Mikrotik.That's interesting...I have a Versatek VX-160CE, however it shows up in the 3011 as a Proscend 180-T.
Marlow, you previously said you bought the device from mikrotik-shop.de - did that also show up as a Proscend 180-T or something else?
I'm trying to narrow down what might work when my nearby fibre cab goes live. Looks like my only ISP options will be BT or PlusNet.
It does look like meconet.de and mikrotik-shop.de might be the same company so I suspect it's the same device as smartdev but it would be helpful to confirm so I can place an order.
The factory supplied power supply is 24V 0.8A. Either way, I don't think you'll see any issues.Any known issues with power consumption using these in a CRS125? The supplied power supply is 12v 2.4 amps I believe. I have a CRS125-24G-1S so there's no WiFi.
In Germany DTAG (Telekom) started to sell "super vectoring" (G.993.2 Annex Q, profile 35b, DTAG requirements on page 62). Are there any experiences out there with modems discussed in this thread? How future proof are these devices? Could there be something like a firmware update to support new profiles or do we need new hardware then?
Interesting that the development goes on. Next would be a model that supports line bonding?
In the future??? Is DSL the future, I thing PON and SFP is the future!
Bonding is an option offered by the ISPs here (as part of their competition with cable and fiber which offer a lot higher rates) and it is not using MLPPP.Secondly, there are no problems running multiple in for example a CCR1016 and then either run MLPPP (If your provider allows you to establish multiple lines with the same credentials) or the way we use them is with bonded EoIP tunnels and baby jumbo frames, which works excellent for bonding, of you are in control of both ends.
The issue is not the equipment but the cables running to the homes. E.g. where I live there is fiber to streetcabinets that offer DSL to the homes, and I get 100/30 MbpsThere are lots of Telcos, that still build on their copper plant and are ignoring the migration to FTTH. Hey .. German Telekom is one of those, that still haven't got around to fiber
Of course it's expensive to replace existing copper infrastructure with fiber. No question there. And thats why DSL isn't dead.Wiring fiber to the individual homes, while being done all over the country, is expensive and not as easy as using the existing copper wiring infrastructure.
Usually it is only done with subsidy from the municipality or a housing council. The Telco/ISP by itself will not do it.
(of course you can get individual fiber but it has to be paid at cost of installation which is usually about 50 euro/meter of digging)
So do you have one you're willing to sell and ship to UK? Email me at dofrotest123@gmail.com as this board doesn't seem to support direct messaging?!However, I have abandoned the use of these things as there is apparently no support forthcoming from MikroTik to view the status and it is not acceptable to run connections "in the blind".
So external modems it will have to be...
/interface pppoe-client add add-default-route=yes disabled=no interface=ether5 keepalive-timeout=disabled max-mru=1500 max-mtu=1500 name=SSE password=PASSWORD profile=pppoe-client-default use-peer-dns=yes user=USERNAME@ISP
13:59:13 pppoe,ppp,info SSE: initializing...
13:59:13 pppoe,ppp,info SSE: connecting...
13:59:13 pppoe,debug,packet ether5: sent PADI to FF:FF:FF:FF:FF:FF
13:59:13 pppoe,debug,packet session-id=0x0000
13:59:13 pppoe,debug,packet host-uniq=0x15b0001
13:59:13 pppoe,debug,packet service-name=
13:59:13 pppoe,debug,packet ppp-max-payload=1500
13:59:13 pppoe,debug,packet ether5: rcvd PADO from 2A:8A:1C:EC:7C:29
13:59:13 pppoe,debug,packet ac-name=nge001.clc-re0
13:59:13 pppoe,debug,packet ac-cookie=1e 3f 7b 3c df 1e fe 44 ba 13 e9 34 fc 3e 7a 62
13:59:13 pppoe,debug,packet ether5: sent PADR to 2A:8A:1C:EC:7C:29
13:59:13 pppoe,debug,packet host-uniq=0x15b0002
13:59:13 pppoe,debug,packet ether5: rcvd PADS from 2A:8A:1C:EC:7C:29
13:59:13 pppoe,debug,packet session-id=0x015c
... then LCP, IPIP, etc.
/interface print where type="pppoe-out"
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R SSE pppoe-out 1480
/interface vlan add interface=ether5 mtu=1512 name=VDSL-vlan vlan-id=101 arp=disabled
/interface pppoe-client set [ find name=SSE ] interface=VDSL-vlan
19:17:12 pppoe,ppp,info SSE: initializing...
19:17:12 pppoe,ppp,info SSE: connecting...
19:17:12 pppoe,debug,packet VDSL-vlan: sent PADI to FF:FF:FF:FF:FF:FF
19:17:12 pppoe,debug,packet session-id=0x0000
19:17:12 pppoe,debug,packet host-uniq=0x13a0001
19:17:12 pppoe,debug,packet service-name=
19:17:12 pppoe,debug,packet ppp-max-payload=1500
19:17:13 pppoe,debug,packet VDSL-vlan: sent PADI to FF:FF:FF:FF:FF:FF
19:17:13 pppoe,debug,packet session-id=0x0000
19:17:13 pppoe,debug,packet host-uniq=0x13a0001
19:17:13 pppoe,debug,packet service-name=
19:17:13 pppoe,debug,packet ppp-max-payload=1500
/interface ethernet set [ find default-name=sfp1 ] speed=1Gbps arp=disabled auto-negotiation=no mtu=1512
/interface vlan set [ find name=VDSL-vlan ] set interface=sfp1
2) Whoever said turning off autonegotiate was the way to go with the SFP's gave you a bum steer. I've never had this work. The only way I can get the 180-T SFP's to work on my CRS-109's, is to power the CRS109 on, wait for it to boot, THEN insert the 180-T. If the 180T is installed when the Mikrotik boots, it will never pass traffic even after the sync light goes solid green.
O that is interesting, that must be some bug/feature introduced in RouterOS recently!If you turn OFF auto-negotiate then you will see the "R" running flag but no packets are ever received from the SFP interface.
If you turn ON auto-negotiate, and maybe set advertise=1000M-full as needed, then the next time you insert the modem into the SFP cage it will work!
Oh that could be - You had yours quite some time before I finally got mine, and I think I was on a newer RouterOS version than you at the time, and didn't want to roll back to test it.O that is interesting, that must be some bug/feature introduced in RouterOS recently!
When I first received my SFP, it worked fine with auto-negotiate off. I had 1500 byte MTU all working (same as how you wrote above) and the only problem was I did not get my expected line speed and there is no way to monitor why.
Recently I tried the SFP again and same problem as you write: nothing received. I feared I had damaged the SFP somehow and put it aside.
Now I will try again with what you describe.
any news from mikrotik support?O that is interesting, that must be some bug/feature introduced in RouterOS recently!If you turn OFF auto-negotiate then you will see the "R" running flag but no packets are ever received from the SFP interface.
Hi Milotop,Hi everyone,
these are the xDSL ATM settings of the modems mentioned above:
I just used VLAN10 as the ISP has recommended me and it works like charm.You cannot configure it. You can only select a VPI/VCI setting from the above list.
You do that by accessing the link via a VLAN as in the last column of the table.
So to use VPI/VCI setting 8/36 you use VLAN 7.
VPI/VCI setting not in the table? -> you cannot use this modem.
So it likely is VDSL, not ADSL, so you do not have ATM and no VPI/VCI settings.I just used VLAN10 as the ISP has recommended me and it works like charm.
Step 5: /Interfaces/Interface List => WAN => Switch to Interface SFP.I can recommend https://www.mikrotik-shop.de/Interfaces ... :2192.html
I got mine 2 days ago and it works great on a O2 VDSL 50/10 MBit connection.
With my O2 VDSL I got 49.7 MBit down and 9.4 MBit uplink.
1. After inserting the module, it was directly recognized (sfp1).
2. I switched off autonegotiation on the sfp device.
3. I created VLAN7 (vlan7) and connected it to the sfp device(sfp1).
4. Then I created a PPPoE Client, connected it to Interface vlan7 and configured the dial-out setting with my O2 credentials.
Then finally I switched off my FB.
That's it ... Really great stuff!
Swisscom has been offering 500 Mbps G.fast since 2016 and continues working with Huawei on 5 Gbps NG.fast since 2017, even if they keep on rolling out FTTH. Universal FTTP is a more distant future.In the future??? Is DSL the future, I thing PON and SFP is the future!
modems will be ready from broadcom soon:Not every country has cheap labour, and it is quicker to replace a box than laying FTTH. Very few people need 10 Gbps at home.
This "NG.fast" is made for up to 100 meters, so it would be mostly for FTTB (or right outside).
If the "NG.fast" project was supposed to result in a slower product, maybe it is now abandoned.modems will be ready from broadcom soon:
https://www.broadcom.com/company/news/p ... ases/52671
https://en.wikipedia.org/wiki/G.fast#G.mgfast_(XG-fast)
Then they should cut the old copper pair and drag an cheap fibre instead. Or at least to the basement of the apartment building. It's not about bandwidth, it's about getting rid of legacy technology. This solutions is like keeping the old phone wires on respirator.Not every country has cheap labour, and it is quicker to replace a box than laying FTTH. Very few people need 10 Gbps at home.
In countries with cheap labor, fiber can be laid to every house at little extra cost.Then they should cut the old copper pair and drag an cheap fibre instead. Or at least to the basement of the apartment building.
Why should they remove the copper if it's working well?Then they should cut the old copper pair and drag an cheap fibre instead. Or at least to the basement of the apartment building. It's not about bandwidth, it's about getting rid of legacy technology. This solutions is like keeping the old phone wires on respirator.Not every country has cheap labour, and it is quicker to replace a box than laying FTTH. Very few people need 10 Gbps at home.
It is not abandoned.. "NG.fast" and "XG.fast" will be named as "G.mgfast"..If the "NG.fast" project was supposed to result in a slower product, maybe it is now abandoned.
But the "NG.fast" prototype was only 5 Gbps. Maybe Swisscom would only be interested in 10 Gbps now.It is not abandoned.. "NG.fast" and "XG.fast" will be named as "G.mgfast"..
Why? FXS ports and DSL are totally unrelated.I imagine many times putting an SFP modem in Mikrotik would not be considered because of the lack of FXS ports in their routers.
Some phone companies shut down POTS already.Why? FXS ports and DSL are totally unrelated.
And so?Some phone companies shut down POTS already.Why? FXS ports and DSL are totally unrelated.
I see even LESS point in equipping every router with FXS ports that 99% of the time are completely useless.Many providers give a separate box for TV, including some that previously gave only one for everything. There's little point in replacing an ISP modem router with a VOIP box, which would also cost more than 2 FXS ports in Mikrotik. And you would also have to pay for the SFP, without really reducing clutter.
So what? They will not consider MikroTik for such markets anyway!An ISP could thus provide the usual 2 boxes with Mikrotik (plus an SFP) instead of 3. Or SFP plus TV box (I don't know any "pure" TV box with FXS ports). I doubt they will consider using Mikrotik if it does not have these ports.
Why should they throw away their AM radios or their record players?Why should people throw away their analog phones?
Well, of course this matters when a device is being designed. Today most people want WiFi. And high speeds. Not FXS ports.It does not matter if many people only use mobile phones.
Reading this got my hopes high and I plugged in a GPON ONU that I recently bought to play around with (I don't even have GPON hereWe only need support from MikroTik so that parameters of the line can be viewed and possibly tweaked when such a module is plugged into a MikroTik router.
Similar to what is now possible for fiber modules but with values as usual for DSL.
Don't most people that prefer a "real" router (Cisco, MikroTik, Ubiquiti, Juniper, ...) use a separate modem? The moment you switch the ISP's CPE into modem/bridge mode, the telephony capability of the box is usually lost anyway. So why not use a small SFP modem instead?But I would not replace my cable modem/router for SFP if I have to add an ATA box even if I could.
G.mgfast (multi-gigabit fast) will be supporting both 5Gbps and 10Gbps profiles.But the "NG.fast" prototype was only 5 Gbps. Maybe Swisscom would only be interested in 10 Gbps now.It is not abandoned.. "NG.fast" and "XG.fast" will be named as "G.mgfast"..
What do you mean with "VoIP liability"? I received the SIP credentials from my ISP, so I was able to use my own hardware for everything - DSL modem (DGA4132), router (Ubiquiti ER-X), SIP-Client-DECT-Combo (FritzBox).You may be allowed to replace their box but you have to accept a VOIP liability, so I would not.
