jetelina
New product request CRS125-24G-1S-RM with PoE + integrated power supply
Sat Jan 23, 2016 12:49 pm
I like your switch "CRS125-24G-1S-RM", but I would like it to have all 24 giga ports with Pover over Ethernet. So that I can power up IP phones and video cams. Also it would be good to have it with integrated power supply and 220V power socket IEC C14 - to use normal power cord from UPS.
Is there any plan to make thing like this?
Mikrotik RB750GL - RouterOS 6.41.4
scampbell
Trainer
Trainer
Thu Jan 28, 2016 6:37 pm
+1 for passive or 802.3af/at
nz_monkey
Re: New product request CRS125-24G-1S-RM with PoE + integrated power supply
Fri Jan 29, 2016 9:33 am
+1
802.3af would make this product useful for us.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
djdrastic
Fri Jan 29, 2016 11:49 am
There have been numerous requests for this on this forum.
Not sure how you make a 24 Port switch and don't make a POE variant.
Haven't used non POE switches on the access side for yonks now.
Łukasz
Mon Feb 01, 2016 12:42 am
+1
I also waiting for device like this.
VoicehostSupport
Fri Feb 05, 2016 2:13 pm
We are a major Hosted Telecoms supplier in the UK, and if you made this you could corner the market.
There is no all in one unit that anyone currently sells, except the Cisco ISR solution.
If you want the Cisco ISR solution its £10000+, so not really practical.
Is this unit even in Beta??
VoicehostSupport
Fri Feb 05, 2016 2:17 pm
Is this product even in beta yet?
Users browsing this forum: No registered users and 12 guests
