e2346437
RB532 Locks up on boot with APC UPS Attached
Sun Aug 27, 2006 3:05 am
I've seen a few posts that seem to be related to the same bug I'm trying to get around. It's getting cold up her in Northern Maine, and today I replaced a PC with a IDE flash module running Mikrotik with an RB532/A with 6-port daughtercard.
When I boot the unit with an APC SmartUPS 1500VA attached to COM1, the RB532/A refuses to boot. When I disconnect the serial cable and power-cycle the board, it boots fine. Then I attach the serial cable, and the RB532/A starts talking to the battery with no issues.
I couldn't leave the battery attached to the RB532/A, because after a power outage I would have to travel to the tower site to disconnect the serial connection. This leaves me with no remote battery monitoring.
Under system/console, I have deleted the console interface. Under ports, COM1 is shown in use by "UPS". When connected, system/UPS shows data from the battery.
I suspect what is happening is that on boot, the RB532/A is receiving data from the battery through the serial port and doesn't know what to do with it, so it locks up.
Does anyone else out there have the same problem? Is there a fix or a workaround? It almost seems like this needs to be solved in the RB532 hardware.
Thanks,
Eric
cibernet
Long time Member
Long time Member
Re: RB532 Locks up on boot with APC UPS Attached
Sun Aug 27, 2006 3:23 am
Thanks,
Eric
What version of MT are you using?
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
e2346437
Sun Aug 27, 2006 3:25 am
2.9.29 with the matching 2.9.29 UPS package.
Thanks,
Eric
cibernet
Long time Member
Long time Member
Sun Aug 27, 2006 3:31 am
Thanks,
Eric
Ummm... send support.rif to support@mikrotik.com
Best Regards
José Ignacio Acosta
Mikronet
changeip
Sun Aug 27, 2006 6:24 am
My buddy said that the upgrade from .27 to .28 left his UPS unusable, it would keep rebooting RouterOS every time it started... I asked him to send supouts for it - apc 1200 i think.
Sam
e2346437
Sun Aug 27, 2006 6:37 am
Sam
Thanks for the info. Can anybody else confirm this problem?
As much as I like Mikrotik products, I'm getting really frustrated with the features that don't work!
mstead
Sun Aug 27, 2006 3:31 pm
I can confirm that this problem exists. I have an RB532 that locked up with a UPS attached a couple of weeks ago. When the 532 boots the UPS beeps randomly which would indicate to me that the initial boot messages are confusing the system. In fact it took more than a simple reboot to recover the 532 - I ended up pressing the reset button several times.
I guess that the UPS is sending out data as well - confusing the 532 even further.
Malcolm
e2346437
Sun Aug 27, 2006 3:34 pm
Malcolm
What version are you on?
Thanks for the reply.
Eric
normis
Tue Aug 29, 2006 10:42 am
Try following:
/system routerboard settings set enter-setup-on=delete-key
The same setting can be changed from RouterBOOT itself as well.
changeip
Tue Aug 29, 2006 6:26 pm
I believe regular x86 pcs have problems with the ups package as well... I will see if I can get my buddy to upgrade back to .28 and poke around with it, problem was that he couldn't take a supout because it kept rebooting the instant it came back up.
Users browsing this forum: jenya and 52 guests
