PR120001
SXT Lite2 Pole Specification
Wed Feb 24, 2016 4:54 am
I would like to know what's the pole specifications for the mounting of SXT Lite2?
The metal brace got the inscribe text : 430SS 026 2 3/4 46-70mm
I do hope you can clear out what's the meaning of those number.
Thank You
PR120001
Re: SXT Lite2 Pole Specification
Wed Feb 24, 2016 5:51 am
Also how to implement the PPPoE with 20 meters length? I mean what device or cords?
Thank You
jarda
Wed Feb 24, 2016 7:21 am
You can mount it everywhere it just depends on your skills and not on those numbers. PPPoE is not influenced by the length.
Didn't you mean poe? If yes, normal cat5e cable is fine with that distance. Just use higher voltage power adapter, around 20v or more.
PR120001
Wed Feb 24, 2016 8:16 am
Well I do need a specific diameter for the pole with those label.
What do you mean by those numbers?
Oh yes I forgot I only need a network cable. lol
normis
Wed Feb 24, 2016 10:44 am
What is the question here? I got confused somewhere in the middle
PR120001
Wed Feb 24, 2016 11:34 am
These numbers are on the clamp :
What's the meaning of the numbers?
normis
Wed Feb 24, 2016 12:26 pm
Why is it important :D ?
430SS 026 = Material, Stainless Steel, manufacturer code
2 3/4 46-70mm Min and Max size (2 3/4 inches = 70mm)
PR120001
Fri Feb 26, 2016 7:37 am
Because I need the specification for the steel pole. Well I can't have a big diameter pole. lol
normis
Fri Feb 26, 2016 7:58 am
Yes, well .. just looking at it makes it pretty obvious that there is a limit :)
jarda
Fri Feb 26, 2016 8:16 am
This is not the only one thing that can be used for mounting the sxt...
normis
Re:
Fri Feb 26, 2016 8:19 am
Of course, but in the box, only this ring is inside. If the ring doesn't fit, it is possible to mount it using Duct Tape, piece of string, coat hanger or even Sugru.
But I also recommend checking out the new optional accessories:
http://routerboard.com/QME
http://routerboard.com/QMP
PR120001
Fri Feb 26, 2016 9:32 am
Yes indeed this isn't the only accessory to be use to mount it.
Thanks a lot for the clarification. Would the 2 1/2 diameter be enough to mount this taking in consideration the inside ring?
normis
Fri Feb 26, 2016 9:48 am
2 1/2 inches is the absolute maximum at which you can close the ring, but the diameter of the pole must be smaller. Including the included SXT mount, the given space is pretty small actually. I suggest getting a couple of plastic cable ties if you have a large pole:
dnyl
Sun Feb 28, 2016 12:25 am
You need to buy a bigger ring for bigger poles. This is the best method for use your sxt at a big pole.
In our country we can buy a bigger ring for ~0,2€.
Users browsing this forum: No registered users and 12 guests
