reliance3g
Sxt lite 5 unable to make server Ap
Wed Mar 09, 2016 5:29 am
As client station unable to lock to available ap frqency after configuration.
Reverse if we make it as server AP fail to do it.
Do net install no luck yet is it's a problem of hardware is routeros?
But in CPE mode it able she available ap in air.
Pls help me out my ISP fail to do it.he says board is damaged
jarda
Wed Mar 09, 2016 8:42 am
Put the frequency into scan list in client mode and it will be fixed. For Ap mode you need at least level 4 licence.
reliance3g
Re: Sxt lite 5 unable to make server Ap
Wed Mar 09, 2016 10:07 am
Bro now my device tx -90 and rx-28 and ISP told device damaged.is that right
DmitryAVET
Wed Mar 09, 2016 10:59 am
SXT Lite 5 have License only Level 3. For AP mode you need Level 4.
"Server/AP mode" is for PTP Bridge (Point-to-Point) with only 1 client.
If you want connect to PtMP (WISP Base Station), use "CPE mode". In "Wireless" you need choise "station" (CPE-router) or "station wds" (transparent) mode. Type SSID, Frequency, channel width and protocol (of Base station) in Wireless config. Password hidden in "Security Profiles".
gtricho
Mon Jun 06, 2016 11:52 am
Hello Dmitry, your text here gives me hope! I was having 2 SXT Lite 5 routers working fine with PTP Bridge mode (at server side) and Station bridge mode from the client side. My problem started when I wanted to add a 2nd client creating PtMP connection. You think this setup could be done using 3 SXT Lite 5 routers? I will try the settings you proposed above anyway! Thank you so much.
reliance3g
Mon Jun 27, 2016 5:36 pm
I HAD TRIED AS PER UR PRESCRIBED METHOD BUT STILL NO LUCK WHAT TO DO
DmitryAVET
Thu Jun 30, 2016 12:52 am
What say your ISP? What you want to do?
1) If you connecting to Base Station:
Use CPE mode. You may scan frequencys, but best way is manual config.
Ask your ISP for:
1) SSID
2) frequency
3) channel width
4) wireless protocol
5) password
2) If you make Bridge between 2 SXT
Use PTP Bridge mode
First SXT is "Server AP"
Second SXT is "CPE/Client"
See manual:
http://lanmarket.ua/stats/sozdanie-besp ... ostupa-SXT
jarda
Thu Jun 30, 2016 7:32 am
Once again. You need license level 4 on Ap if more than one client should be connected to it. Isn't this your case?
kiko
Wed Dec 19, 2018 5:55 am
alguin que tenga un sxt lite5 ac que este muerto que me mande una copia de la epron porfabor
Users browsing this forum: No registered users and 3 guests
