maxspeed
i`m searching a old firmware for a CCR-1009
Mon Mar 21, 2016 5:54 pm
I have a weird problem, maybe internal hardware from my CCR-1009 or the lastest versions (6.3x)
give that problem. The CCR stop working after 1 or 2 days (with PPPOE connection to ISP), no choice
to do a power off and on !
Someone have a old version of FW like 6.2x i would like to downgrade
Thank you for your help
proximus
Re: i`m searching a old firmware for a CCR-1009
Mon Mar 21, 2016 6:10 pm
Previous versions are all here: http://www.mikrotik.com/download/archive
MrNewbie
Mon Mar 21, 2016 6:22 pm
You can setup a scheduler to disable the pppoe interface every day at a time to pick, and you can add another scheduler to enable it after 10 seconds.
Learning patience.
maxspeed
Tue Mar 22, 2016 12:03 am
I will downgrade and see if i can find the bug
Thank you for your reply ...
Users browsing this forum: No registered users and 28 guests
