aa007
HAP AC faulty seriers - very poor LAN performance? (switch problem)
Thu Mar 24, 2016 2:26 pm
we got 6 RB962UiGS-5HacT2HnT but the performance in our network is horrible. So we tried to play with it a little bit and compared it to Ruckus which has steady results around 150 Mbit/sec. We tried the default settings with 6.34.3 and we got following results on iperf:
0.00-10.00 sec 48.0 MBytes 40.3 Mbits/sec sender
which is not really good. So we played with it a lot ..
today, we tried 6.35 RC41 with wireless-rep and latest firmware
The results were following:
0.00-10.00 sec 3.50 MBytes 2.94 Mbits/sec sender
Which is really horrible.
But then, desperatelly clicking around we disabled under IP settings to uncheck Allow Fast Path and uncheck Allow Fast Path under Bridge Settings... then we got this result:
0.00-10.00 sec 119 MBytes 99.6 Mbits/sec sender
Which is useful, on receiving side we got around 200Mbit/sec even after reboot
So I want to ask what can be wrong? Why is fast path doing this? We tried to uncheck this on 6.34.3, but it had effect until the device was rebooted and then no matter what you check its doing crappy.
The config that was loaded on that worst result is following:
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
add admin-mac=E4:8D:8C:49:1E:94 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-491E9A \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=\
    MikroTik-491E99 wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys wpa2-pre-shared-key=PASS
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="defconf: accept ICMP" protocol=icmp
add chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" \
    in-interface=ether1
add chain=forward comment="defconf: accept established,related" \
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
    out-interface=ether1
/system leds
set 1 interface=wlan2
/system routerboard settings
set cpu-frequency=720MHz protected-routerboot=disabled
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
I know my firend is having the same AP, with 6.34.2 with much better performance in almost default config. So I think this series might be faulty? Should we return all of them? The iperf is showing over 800Mbit/s when we try this over one of the ethernet ports on HAP AC (EDIT: just one way as we found out later on). LAN is connected to ether1.
Naurislv
Re: HAP AC faulty seriers - very poor wireless performance?
Thu Mar 24, 2016 2:48 pm
Thank you for report.
This definitely is not ok and we'd like help you to resolve this issue. Please write to support@mikrotik.com and add this forum link as reference and attach supout file of hAP ac board.
aa007
Tue Mar 29, 2016 4:19 pm
So after some more testing we decided to get SFP S-RJ01 - and guess what - everything is running very smooth and fast - over 500Mbit/s with wireless-rep symetric
So we tested some more and we suspect that the switch might be the source of problems, because when we tested on wired connection with SFP for WAN and ETHER1 for LAN we get following: When we run iperf with -R option, we get 838 Mbits/sec but, without -R option we get only 68.5 Mbits/sec!
When we switch from SFP to ETHER1 for WAN and ETHER2 for LAN we get 34.8 Mbits/sec upload and 18.5 Mbits/sec download with iperf.
Just to be sure, we tried older RB951G - we wiped all settings, then we just briged ether1 and ether2 and ran iperf - it was around 900Mbit/s both ways.
So ... changing wireless package to wireless-rep fixes part of the problem, but it seems the switch is source of the problem also - is anybody else experiencing this? I tested two HAP AC with the same result. Both have qca-8337 switch installed, RB951G has Atheros 8327
Unfortunately we need PoE to run the APs, so its unusable like this for us. So I guess we should return all of them...
aa007
Re: HAP AC faulty seriers - very poor LAN performance? (switch problem)
Tue Mar 29, 2016 6:35 pm
So we got one more HAP AC and it is working correctly. So its definitely a faulty series.
The one that is OK has SN: 6737055FAF54
Two APs tested today, that have this poor result have SN:
6737051BD37F
673705E06641
I will test the rest tomorrow.
Too bad, that support is not responding at all - so I guess there is no other choice than to return all of them. Really disappointing - I would recommend to all customers who want to buy HAP AC to wait some time until this is somehow resolved or to choose different product.
normis
Wed Mar 30, 2016 9:14 am
Did you email support? What is your ticket number (you got one in the auto reply)?
aa007
Wed Mar 30, 2016 11:29 am
Hi, so we have found the source of the problem - its temperature. We cooled down the unit to 15°C and started testing.
The results were following with iperf and System/Health temp:
15 °C
0.00-10.00 sec 924 MBytes 776 Mbits/sec sender
0.00-10.00 sec 848 MBytes 711 Mbits/sec receiver
23 °C
0.00-10.00 sec 796 MBytes 668 Mbits/sec sender
0.00-10.00 sec 675 MBytes 566 Mbits/sec receiver
26 °C
0.00-10.00 sec 592 MBytes 497 Mbits/sec sender
0.00-10.00 sec 495 MBytes 415 Mbits/sec receiver
30 °C
0.00-10.00 sec 243 MBytes 204 Mbits/sec sender
0.00-10.00 sec 324 MBytes 272 Mbits/sec receiver
34 °C
0.00-10.00 sec 140 MBytes 118 Mbits/sec sender
0.00-10.00 sec 82.4 MBytes 69.1 Mbits/sec receiver
36 °C
0.00-10.00 sec 50.1 MBytes 42.0 Mbits/sec sender
0.00-10.00 sec 48.2 MBytes 40.5 Mbits/sec receiver
43 °C
0.00-10.00 sec 10.9 MBytes 9.12 Mbits/sec sender
0.00-10.00 sec 8.75 MBytes 7.34 Mbits/sec receiver
The ticket number is 2016032466000618 and it seems there is already more people having this issue with HAP AC: http://forum.mikrotik.com/viewtopic.php?f=13&t=105764
littlebill
Fri Apr 01, 2016 12:03 am
is this repeatable across all 6 routers?
normis
Fri Apr 01, 2016 11:36 am
Please send the units for warranty repair, so we can inspect them and run the same tests.
aa007
Fri Apr 01, 2016 1:10 pm
It is reproducible on 2 units. For the rest it was enough to use wireless-rep package with 6.35RC ROS - problem was occurring with some Intel wireless cards (eg. Intel Dual Band Wireless-AC 8260 in Lenovo Yoga 900), but using wireless-rep is fixing that.
So after we get some kind of replacement for those heat affected units we will send those back to you.
DanielJB
Wed Apr 06, 2016 5:17 am
I have been experiencing the same issue on the excellent hAP ac and have found:
- the low bandwith (17-57Mb/s) varies with temperature
- it occurs with certain ethernet phys and not others
- when it occurs, I see receive issues, suggesting the root cause is the transmit from the QCA8337 switch chip
- the temperature of the heatsinks on the QCA8337 are fine, suggesting there is sufficient PCB thermal coupling (ie there isn't an PCB error with thermal relief for soldering)
This all points to an issue with QCA8337 phy programming, so is highly likely fixable in software; this makes sense since it is newly introduced and has new mac and phy power-saving features which may cause compatibility issues with some equipment.
I can't reproduce the issue against Intel ethernet macs and phys, but I can with an Asix AX88179 USB3 to ethernet adapter, which shows a low rate of receive errors. The QCA8337 side shows no errors in the stats.
@Mikrotik, let me know if you need more data/info/testing. I can hook up my 200MHz scope if needed.
Daniel
- Daniel J Blueman
brosky
Thu Apr 07, 2016 8:41 pm
hah, it seems that I have the same problem.
SN: 673705914040 / 603
After unboxing I tested and got constant 250mbps in AC in the first day but afterwards I can't get over 30Mbps , even at close distance.
I can post videos of this, hopefully we'll get a fix for this.
DanielJB
Fri Apr 15, 2016 9:20 am
Using another USB to Ethernet adapter with the Realtek RTL8153 chip (Dell "USB-C to Ethernet adapter"), I see wire-speed in both directions.
This correlates that the issue is a phy setup/programming issue.
- Daniel J Blueman
pcunite
Sat Apr 16, 2016 2:13 am
Good news.
TaurusThree
Tue Apr 19, 2016 8:14 pm
I also have a weird problem with ethernet performance of HAP AC (6.35). Here is the summary:
The good:
1. The Speedtest.net over both wireless (ac) and ethernet gives the same result on the same server;
2. Ethernet performance in local network is also good. Copied a file from one PC to another, almost got a gigabit.
The bad:
1. The actual internet speed on ethernet is awful. On wireless it's ok (so it's not an ISP issue). I get normal speeds when downloading a file over wireless and I get very poor performance on wired. So speedtest.net is ok, every other thing I try is not ok. For example on whatbox.ca/speedtest over wireless I get > 5 MiB/s and over wired I get < 300 KiB/s!
UPDATE. Seems that speed drop over ethernet appears only when downloading files from relatively distant servers. Again, the wireless is good.
UPDATE2. I bought the HAP AC as a replacement to RB951G-2HnD and the latter works as expected.
gotsprings
Wed Apr 20, 2016 1:00 am
The one I am testing has horrible wlan performance. Pings are long. Downloads seem to top out around 11-15Megs on 2.4. 56 on 5 gig.
I unplugged it and put the 951G back in and get closer to 65 on 2.4. Pings are much faster too.
Tried hard wiring into the unit and got the full bandwidth from my isp of 122.
So this is fully a wireless issue on my bench.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
TaurusThree
Wed Apr 20, 2016 7:27 am
I think I had a similar issue with 2.4 band. It seems there is a bug in current software and the workaround for me was setting the 2.4 wireless channel to auto. Any other value was drastically dropping the 2.4 wireless speeds. If this doesn't work, try to reset the configuration.
gotsprings
Wed Apr 20, 2016 7:51 pm
I am running it off CapsMan if that makes any difference.
But let us not forget that the 5G Speeds Suck Too.
Mark Twain
TaurusThree
Thu Apr 21, 2016 5:44 pm
The good:
The bad:
UPDATE3. I've done some additional testing, plugged off the router from power source, after an hour plugged in. Guess what? Speeds were ok, this means that the other guys here are right: temperature is what causes the speed drop. After some playing the speeds went down again. Quick re-plugging didn't help. However when touching the device in normal use (when speeds are low) I don't feel like it's too hot.
TaurusThree
Sun Apr 24, 2016 9:08 pm
UPDATE4. Indeed, cooling down the router in a refrigerator a bit fixes all the symptoms.
UPDATE5.
The customer support has suggested a test: to put the ethernet interfaces into a bridge (after setting master-port=none). I think, the intention of this was to check whether the problem comes from the switch chip. I was pretty sure it was... Because the wireless works, and wireless is in a bridge mode. However, the symptoms were the same even after putting all the ports into a bridge.
To sum up:
- Wireless seems to work normal in every condition;
- Wired works normal when in a local network (gigabit download/ upload); when the download server is near (e.g. in same country); when testing through Speedtest.net (regardless of the server location - this is the strangest part)...;
- Wired works terrible when the download server is relatively far from you. However, this also doesn't happen when the router is cool. In normal working temperatures (system-health) of 55C I get less than 2Mbps (yes, megabits). It seems that the speed drop (e.g. 2Mbps when the temperature is 55C) occurs on every single connection: when using torrents I get the same speed drop on each connection; the total download speed may still be high;
- The good-old 951G seems to work ok on the same ISP;
- Bridging the ethernet ports doesn't improve anything: this may suggest that the problem is not in the switch chip itself;
- Support says that they never had a faulty HAP AC unit of this kind: this means either 1. there is only a batch of faulty HAP AC's; 2. all the HAP AC's are the same: there are conditions, which were not been covered by Mikrotik's testing, at which the problems appear.
In my opinion there is no faulty batch of these units. I think the issue we experience appears as a coincidence of a software (maybe driver) bug in RouterOS somehow related to temperature (kind of cpu throttling) + some ISP's non-standard infrastructure configuration. This can explain why:
1. Only fraction of users experience this kind of problems on HAP AC: those may have ISP's with different infrastructure;
2. Mikrotik testing didn't detect anything: in local networks + in local area (like in same region) these units work fine. Also Speedtest.net globally works fine. Also maybe (?) their ISP (ISPs) have "normal" infrastructure.
3. The older boards work fine for us: those are cooler. Those don't have 2 different wireless chips, POE output...
What I'm going to do is checking my old 951G router speed correlation with the temperature. Maybe I just wasn't noticing that (because it was cooler, thus faster). Unfortunately this is not going to be in near days: I've already spent to much time with these things...
Doesn't anybody from Mikrotik want to respond here?
kenyloveg
Tue Apr 26, 2016 4:24 am
Thanks @TaurusThree for your test.
Can anybody else own a HAP AC confirm this issue?
How long would it take Mikrotik guys to confirm this and release a firmware/software fix? I'm holding to buy some HAP AC while this faulty is not acceptable for me.
littlebill
Tue Apr 26, 2016 10:12 pm
this sucks, i bought one of these as well, is there a way to force the issue for testing?
pcunite
Wed Apr 27, 2016 4:21 pm
Point a blow dryer at it and make sure it only goes up to 55C (/system health print).
To the OP, please try down-clocking the CPU to 600Mhz (/system routerboard settings print)
marekm
Thu Apr 28, 2016 10:29 am
Low speeds from distant servers can be explained by packet loss.
See the formula for throughput of a TCP connection:
http://en.wikipedia.org/wiki/TCP_tuning#Packet_loss
Even small packet loss like 0.1%, combined with typical RTT over the Internet, is significant. TCP just works that way, remember it was invented when speeds were much lower than they are today. Multiple parallel TCP connections will give better results.
TaurusThree
Thu Apr 28, 2016 10:31 am
But why it is correlated with Mikrotik's temperature? When it's relatively cool, I have 0 problem. When it's relatively hot I have problems only with distant servers. EDIT. ok, silly question. The unit itself may be the packet loss source. Esp. when the temperature is high.
But, how does the Speedtest.net show better results even with distant servers in that case? EDIT. another silly question: Speedtest.net uses multiple connections.
Well... This sucks!
marekm
Thu Apr 28, 2016 12:40 pm
Packet loss increasing with temperature looks very much like a hardware issue - marginal Ethernet PHY, not likely to be fixable by software. Could be bad chips, bad capacitors (more likely ceramic ones, as electrolytics are worse when cold) etc. See if you could get more stable throughput by changing from 1G to 100M link.
TaurusThree
Thu Apr 28, 2016 3:26 pm
What rate of packet loss is considered as acceptable? From the router's terminal I've done ping test to the server of my ISP and got approx 0.05% packet loss (out of 25000 packets of size 1460 Bytes; the average ping was 1ms; the board temperature was 54C).
The average ping to European servers (I have an FTP server in Netherlands; and I am from Armenia) is 68ms.
After entering these values (MSS 1460; RTT 68; Loss 0.05%) in this calculator (http://www.switch.ch/network/tools/tcp_throughput/) I get network limit: 7.68 Mbit/sec. Which more or less matches with the speed drop I get at that temperature.
So the question is: is this a warranty case?
Also, do the previous boards also suffer from this? Probably less emphasized because those were little bit cooler?
marekm
Fri Apr 29, 2016 12:34 pm
Ethernet, if done properly and not congested, should have practically zero packet loss (OK, nothing is perfect so let's say 0.0001% or one in a million). The square root in the formula means for 10 times more speed, you need 100 times lower loss. Yes, I'd suggest to RMA it. I'll have to test my own hAP-ac too to see if it's affected. Temperatures in this range should have no effect on properly working electronics, something is seriously wrong with just these boards.
I've just found an interesting article about one possible cause (which may or may not be the case here, it's just an example of possible caveats that can affect any modern electronic devices):
http://www.edn.com/design/analog/440204 ... -capacitor
R1CH
Forum Veteran
Forum Veteran
Fri Apr 29, 2016 6:36 pm
Just to clarify, does this only affect ethernet <-> ethernet connectivity? Eg if using the hAP AC solely as an access point bridged onto ether1, there won't be any issues?
littlebill
Tue May 03, 2016 5:22 am
received my unit, its a EU model, i changed nothing outside of the default config, short of wireless width settings and ssid names,
upgrade to 6.35.1 3.31 with no issue
ran iperf with timer for 600 seconds with 11 parallel streams started at 44C ambient temp. eth port3,4 in switch mode. test ran at 940mbit for the duration of the test, while reaching a total temperature of 58C with 0 issues
then i ran it again over wireless 7260 intel card 2x2 866 link, and it was stable around 250mbit/32MB for the entire test as well all the way up to 57C with no loss.
outside of my voltage indicating 16v when in reality its 23, and a changing color led for wireless. i don't seem to be affected
if there is anything else to test lmk
shovon
Fri May 06, 2016 8:24 am
* connect through any ethernet port using Winbox, see if it disconnects you in every few minutes.
littlebill
Fri May 06, 2016 6:05 pm
i do not have winbox disconnect problems, winbox has been open well over a hour with 0 issues, its generally all i use for configuration
NathanA
Forum Veteran
Forum Veteran
Wed May 11, 2016 3:34 pm
This is what it is sounding like to me, which probably means it is an issue just with transmitting on ethernet port, not receiving. RX from WAN -> TX to WLAN == good speed, RX from WAN -> TX to LAN == bad speed.
If this is the case, then it could also be that download from the internet is very fast, but upload is being constrained. But you might not notice a problem unless you have a very fast symmetric internet connection from your provider.
I just got my hAP and have not gone through testing yet, but you can be sure that I will try to be very thorough after reading through this thread...
-- Nathan
normis
Wed May 11, 2016 3:55 pm
If you experience this kind of problem, please return the unit to the seller for RMA processing. We are looking into this issue and it would help if we could have some of these devices back for more testing.
vortex
Thu May 12, 2016 11:01 pm
I think this might explain the low stock levels. I was hoping for an upcoming flash upgrade.
R1CH
Forum Veteran
Forum Veteran
Mon May 30, 2016 6:53 pm
Any news on this? Was this a problem batch or a manufacturing defect or something else? I'm hoping to deploy more hAP ACs very soon and some of the environments can get quite warm in the summer.
Quindor
Mon May 30, 2016 8:46 pm
I was just thinking about this problem.
Could people whom are seeing this problem try to turn on flow-control on all ports (Auto should be enough). I wondering if that makes a difference. I always turn flow-control on to auto on all ports per default, so that might change something?
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
LSV
Thu Jun 16, 2016 2:48 am
Is there any news on fixing of this problem?. I am planning to WiFi cover a building with 65 APs for different uses connecting Internet users, corporate connections and machine conections. I have been successfully using RB951G for this kind of projects but for new investments now  AC is a must and natural evolution should be hAP ac. These performance problems mixed with the supply shortage make me doubt if these is a stable product. I could not find any reference of successful deployments around Spain.
I would thank you to provide information on current stability, successful projects deployed and/or plans to evolve the product to a more stable release.
pateutz
Thu Jun 16, 2016 10:55 am
Hi LSV,
why not thinking to use  wAP AC ( http://routerboard.com/RBwAPG-5HacT2HnD) instead of hAP AC ?
The wAP AC It's more suitable for APs.
Best Regards,
Daniel
LSV
Thu Jun 16, 2016 7:04 pm
Hi pateutz
I just ordered one to make some tests.
pateutz
Tue Jun 21, 2016 2:25 pm
Hi LSV,
so have you test the product ? It's ok ?
Best Regards,
Daniel
davidbakerjr
Wed Jun 22, 2016 1:05 am
Is there any updates on this or do I need to RMA all 5 of these HAP AC?
LSV
Wed Jun 22, 2016 5:29 pm
Hi LSV,
Best Regards,
Daniel
We received it yesterday installed installed it on our network and seems to work fine for our use in both bands.
We didn't stress it or do further tests yet.
Laurens
Wed Jul 06, 2016 11:25 am
I'm suffering from the same problems; WAN to WLAN is okay, WAN to LAN is terrible. Tried newest rc routeros didn't fix it. Putting interfaces on 100Mbit didn't fix it, disabling fast path on bridge and ip-settings didn't fix it. Cooling it down helps for a bit but is no usable solution.
I guess the only thing to do is to return the unit so Mikrotik has some test material... too bad, need to postpone client delivery now. Still hoping for software fix of some kind!
aa007
Fri Jul 08, 2016 3:50 pm
We have RMA-ed all of the units - two different shops. One of them gave us a new unit, the other one returned the unit with statement, that upgrading fixed the problem - I tested it today ... and guess what - it didn't - so even we would like to send those units back for inspection to Mikrotik, we have to somehow "force" the seller to do it.
Luckily we have replaced all of our Mikrotik devices with Ubiquiti equipment and the difference is amazing. I hope the next generation of Mikrotik devices will get closer to 21st century.
TaurusThree
Fri Jul 08, 2016 3:53 pm
I've also RMA-ed mine. The seller sent a new one from a newer batch. Going to receive it today. Will test in next few days...
TaurusThree
Fri Jul 08, 2016 10:26 pm
The replacement unit - S/N 673706478C5D seems good!
deanMKD1
Sat Jul 09, 2016 1:35 am
WAN to WLAN ok ?
WAN to LAN ok ?
No droping of speed?
Faulty series have this SN:
673705 1BD37F
673705 E06641
673705 914040
your looks that is from newer series
673706 478C5D
you see last 5 in faulty series, and you have 6 on last number position.
TaurusThree
Sat Jul 09, 2016 1:50 am
Yeah no speed drop in all scenarios regardless of temperature.
Laurens
Sat Jul 09, 2016 3:23 pm
Hmz that would make sense. Our faulty returned unit also has a 5 in the s/n: 673705 0CB2D3.
NathanA
Forum Veteran
Forum Veteran
Thu Jul 14, 2016 3:42 am
So I commented on this thread earlier before I had tested, and had not taken the time to come back and report on any findings.  I am happy to report that I have been unable to reproduce this problem at all on my unit, for which I am thankful, because given the past (and ongoing) relative scarcity of hAP AC units in the supply chain here in the US, I imported my single unit, and I wasn't looking forward to organizing an international return...
In my tests, I let the unit stand for several hours.  It felt quite warm to the touch.  I ran throughput tests immediately after booting it up and also after letting it remain powered on for a while, and the numbers did not change.  I was able to easily pull and sustain ~500Mbit/s of a single-stream TCP session through it, from the WAN to one of the LAN ports.  This was with a bone-stock-default configuration, running the software that it shipped with (which I believe was 6.33.5; I later upgraded to 6.35.4 in order to use wireless-rep so that I could solve some throughput problems on the wireless side to an Intel 11ac WiFi client, and the change to wireless-rep did indeed fix the problems I was seeing).
My serial # also starts with 673705, so it would seem not all units were affected.
Was it ever revealed what the exact problem was, and how many units were affected?  Am I missing anything in my testing, or misunderstanding the problem and not testing the correct thing/hitting the exact edge-case that everybody else experiencing the problem was hitting?
-- Nathan
ka4opi4a
Sun Jul 17, 2016 9:19 am
The serial number of mine HAP AC is: 673705...
I have 200 Mbit/s speed over fiber optic.
The device reach the speed in WAN-LAN and WAN-WLAN
LAN-WLAN wsing 80mhz I reach around 350-400 Mbit/s.
Using 6.35 ROS, 3.31 firmware and woreless-rep
My device is configured like AP - it's not running nat, firewall, or any other.
Fats path is active in the bridge.
NathanA
Forum Veteran
Forum Veteran
Tue Jul 19, 2016 5:50 pm
I don't think anybody -- even those with the problem -- have reported issues with the SFP port.  The problem has only manifested itself between copper WAN and LAN.
-- Nathan
ChrisVanMeer
Tue Jul 19, 2016 8:27 pm
I've just wrote to support, same issue here.
WIFI great performance, but ethernet connection speeds are 40Mbps max.
When I disable Fast Path in bridge, I get better speeds within the switch (lets say from device on port 2 to device on port 3).
But LAN to WAN is same slow speed. Serial number 6764056F9ADA.
Zorro
Long time Member
Long time Member
Wed Jul 20, 2016 8:09 am
for 200Mbps its relatively simple/cheap/weak device i think.
fastrack/fastpath combo can save you from some pain, but bring new ones instead.
CPU isn't powerful enough generally, but thats kinda common for SOHO networking.
todays we're had WiFi routers with advertises speeds with up to 1900 or 3200 Mbps, but majority of subscribers - had under 25Mbps plans( 60-100Mbps in bit more developed countries) and quite few - picked 100-300Mbps plans, yet), which is look kinda ridiculous from both side of that picture to me.
ChrisVanMeer
Wed Jul 20, 2016 6:04 pm
Had brief contact with Mikrotik support and they adviced me to contact my reseller for warranty.
They will ship me a new unit at the end of this week, which I can try out and then send back the old one.
Great service so far, I hope the replacement unit will clear up the issue. I will let you know the results.
ChrisVanMeer
Fri Jul 29, 2016 5:03 pm
Hi, received my new unit today. Serial number 6737063D345F, but whatever I try, inter-switch connections are fast, from switch to uplink (all connected with gigabit cable) throughput remains 30-40Mbps.... So it didn't solve my problem.
JanezFord
Thu Sep 22, 2016 12:51 pm
Any update on this? I have 3 units that suffer from this issue ... it also seems that reboot makes them work fine for a while, but shortly after speeds drop terribly.
JF
NathanA
Forum Veteran
Forum Veteran
Mon Oct 03, 2016 1:30 pm
It sounds like this is a limited hardware defect in some of the early shipping units. Others who had this problem apparently managed to swap their routers for working ones via their distributor. Can you not try this as well?
-- Nathan
fantasticfears
Tue Nov 15, 2016 10:46 pm
Is there any confirmation about whether this is a hardware issue? I am regretting not testing properly when I got the hAP ac. I'm in Sweden now. Somehow it's nearly impossible to send it back for RMA. That's indeed a frustrated experience.
VaNSqL
Thu Jan 05, 2017 12:22 pm
Problem. There are new MikroTik hAP AC. The provider gives 1 gigabit Internet. When connected directly to the computer network card speed is 750-800 Mbps when connecting to the router, the speed drops to 250-300 Mbps. (wan2lan).
serial number : 673706A48473
current firmware : 3.34
OS : 6.38
normis
Thu Jan 05, 2017 12:28 pm
if you have default config
open new terminal in winbox, paste this rule:
/ip firewall filter add chain=forward action=fasttrack-connection connection-state=established,related
/ip firewall filter add chain=forward action=accept connection-state=established,related
Check and report differences.
VaNSqL
Thu Jan 05, 2017 12:45 pm
No change. Forgot to say that when you connect to the first port and failed to raise the connection with the provider by auto negotiation to 1 gigabit. At the port №2 everything is OK. I can give access to webfig.
normis
Thu Jan 05, 2017 12:54 pm
please post output of "/export"
VaNSqL
Thu Jan 05, 2017 12:58 pm
# jan/05/2017 12:54:54 by RouterOS 6.38
# software id = TTGC-0AJH
add admin-mac=6C:3B:6B:19:AA:D9 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=1000M-half,1000M-full name=WAN \
    rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether3 ] mac-address=6C:3B:6B:19:AA:D8 name=WANNEW
set [ find default-name=ether5 ] disabled=yes master-port=ether2-master
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
    country=ukraine disabled=no distance=indoors frequency=auto mode=ap-bridge \
    ssid=MT-2 tx-power=10 tx-power-mode=all-rates-fixed wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
    ssid=MT-5 tx-power=10 tx-power-mode=all-rates-fixed wireless-protocol=\
    802.11
set WAN discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys wpa-pre-shared-key=1234567890q wpa2-pre-shared-key=\
    1234567890q
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add add-arp=yes address-pool=dhcp authoritative=yes disabled=no interface=\
    bridge name=defconf
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=WANNEW
/ip dhcp-server lease
add address=192.168.1.11 always-broadcast=yes client-id=1:74:4:2b:e3:d0:ff \
    comment="Vibe P1" mac-address=74:04:2B:E3:D0:FF server=defconf
add address=192.168.1.111 comment="EXSI 6" mac-address=68:05:CA:46:48:B8 \
    server=defconf
add address=192.168.1.112 comment=WinServ mac-address=00:0C:29:F7:A1:E4 server=\
    defconf
add address=192.168.1.113 comment=CentOS7 mac-address=00:0C:29:FF:78:E7 server=\
    defconf
add address=192.168.1.10 client-id=1:8:ed:b9:28:eb:ab comment=Notebook \
    mac-address=08:ED:B9:28:EB:AB server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
/ip dns static
add address=192.168.1.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=accept chain=forward connection-state=established,related
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    WANNEW
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    connection-state=new in-interface=WANNEW
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
    WANNEW
add action=netmap chain=dstnat comment=web dst-port=80 in-interface=WANNEW \
    protocol=tcp to-addresses=192.168.1.1 to-ports=80
add action=netmap chain=dstnat comment=1c dst-port=90 in-interface=WANNEW \
    protocol=tcp to-addresses=192.168.1.112 to-ports=80
add action=netmap chain=dstnat comment=RDP dst-port=10 in-interface=WANNEW \
    protocol=tcp to-addresses=192.168.1.112 to-ports=3389
add action=netmap chain=dstnat comment=MyChat dst-port=2004 in-interface=WANNEW \
    protocol=tcp to-addresses=192.168.1.112 to-ports=2004
add action=netmap chain=dstnat dst-port=81 in-interface=WANNEW protocol=tcp \
    to-addresses=192.168.1.112 to-ports=81
add action=netmap chain=dstnat comment=IPSmanager dst-port=21 in-interface=\
    WANNEW protocol=tcp to-addresses=192.168.1.113 to-ports=1500
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Kiev
/system package update
set channel=release-candidate
/tool mac-server
strods
Thu Jan 05, 2017 1:21 pm
VaNSqL - Please try:
1) interface bridge set bridge mtu=1500
2) interface bridge set bridge protocol-mode=none
normis
Thu Jan 05, 2017 1:28 pm
This is from my hAP ac with 100% defalt config out of the box:
Sometimes I get more than 700, this depends on the speedtest server.
VaNSqL
Thu Jan 05, 2017 1:47 pm
Working!!! Thanks normis and strods for your help!
Problem solving.
strods
Thu Jan 05, 2017 1:55 pm
VaNSqL - Which of both commands did help?
VaNSqL
Thu Jan 05, 2017 2:06 pm
When I changed the MTU have been no changes.
When I change the protocol to none, the speed increased.
When I changed the protocol for stp, the rate is the same as in none.
When changing to rstp, internet speed is reduced.
pcunite
Sat Feb 04, 2017 3:58 am
rOS 6.37.4 seems to work well on the hAP AC. Try that as well.
evilworm
Wed Feb 15, 2017 6:09 pm
Accidentally came across this topic. I have the hAP AC and I can totally repeat the issues with the unit by having different room temperatures. I have exactly the same issues as TaurusThree - speedtest.net shows excellent speeds. But when downloading something from a distant server then the speeds are terrible. Cooled down the unit and the throughput increased significantly. I'm located in Riga so I can bring the unit in for testing if you need...
normis
Thu Feb 16, 2017 12:29 pm
A few devices in the first production batch could have an issue in high temperatures. This is fixed by warranty repair, if you still have that. If not, try to keep it cool enough.
evilworm
Thu Feb 16, 2017 12:51 pm
I bought it from www.omg.de. It's about half year old, still under warranty. Can I RMA it in Latvia or do I need to send it to Germany for replacement?
normis
Thu Feb 16, 2017 1:07 pm
I bought it from http://www.omg.de. It's about half year old, still under warranty. Can I RMA it in Latvia or do I need to send it to Germany for replacement?
Distributor covers the warranty. They sometimes even have their own repair center.
Always buy locally for this reason :)
evilworm
Thu Feb 16, 2017 1:14 pm
It was out of stock locally when I bought it... guess I will need to return it to the omg.de then...
freshmeat123
Tue Feb 21, 2017 11:51 pm
So, what the normal temperature for hap ac? I carefully read this thread and seems i have same issue with bad speed (<200-300Mbit/s) (not finished all tests althought).
My hap ac now:
[admin@MikroTik] /system health> print
voltage: 24V
temperature: 53C
OKNET
Mon Mar 13, 2017 6:54 pm
How can I run LAN performance ?
Is btest software or /tool bandwidth-test enough ?
deanMKD1
Sun Dec 10, 2017 5:25 pm
How is performances with new production batch ? still issues WAN to LAN speeds? How is temperatures? Still high ?
Users browsing this forum: Ahrefs [Bot], Alantisav and 8 guests
