coylh
10G SFP+ and linux
Wed Jun 15, 2016 12:03 am
Has anyone tried using http://routerboard.com/Splus85DLC03D on Linux?  How is the driver support?
mpreissner
Re: 10G SFP+ and linux
Wed Jun 15, 2016 2:53 am
Not me, but I'm currently using http://routerboard.com/SplusDA0001 with a SolarFlare SFN5162.  I use both of these on a FreeNAS and a CentOS 6 KVM hypervisor hooked up to a CRS226.  iperf results got me about 9.8 Gbps between the two.
Michael Preissner
CISSP, CCSP, CEH, PMP
krisjanis
Wed Jun 15, 2016 8:27 am
That is just a transceiver for it alone there is no drivers needed. As long as SFP+ adapter in which you plan to use it has no SFP vendor lockin enabled it should be fine.
CyberDaeng
Mon Jun 29, 2020 6:46 am
Hi, I was found this post when searching the Internet. So Im adding Solarflare SFN5162F to my X86 mikrotik with HP DL360 G8. But unfortunately, it didnt recognize. Can you advice how do you add your Solarflare SFN5162F to Mikrotik?
wpeople
Mon Jun 29, 2020 4:21 pm
For your HP server, i highly recommend to have NC560 dual SFP+ NIC with Intel x520 chip.
Works very well with linux and natively supported by Mikrotik x86 version as well.
Users browsing this forum: No registered users and 32 guests
