nichky
Long time Member
Long time Member
RB433ah problem booting :( :(
Wed Jun 22, 2016 11:51 am
Just i want to as you about my RB. I've got a problem with my router, the problem is my RB doing just one TIT without duble TIT, i was trying to reset and also with netinstal, but...i didn't fix it. any advise?
Thanks a lot
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
!) Safe Mode is your friend;
normis
Re: RB433ah problem booting :( :(
Wed Jun 22, 2016 11:56 am
This model has a serial port. You should find a serial cable + usb/serial adapter, and see what it says when booting.
nichky
Long time Member
Long time Member
Thu Nov 03, 2016 12:43 pm
im trying to fix my bord via RS232, i've got that situacion:
(that post i found on net. i've got same things)
RouterBOOT-2.6
What do you want to configure?
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
r - reset configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
t - do memory testing
x - exit setup
your choice:
RouterBOOT booter 2.6
RouterBoard 112
CPU frequency: 175 MHz
Memory size: 16 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp
protocol...........................................................
................................................................ failed
kernel loading failed
RouterBoard 112
Memory size: 16 MB
kernel not found
trying bootp
RouterBOOT-2.6
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice: g - upgrade firmware
Upgrade firmware options:
e - upgrade firmware over ethernet
s - upgrade firmware over serial port
your choice: s - upgrade firmware over serial port
xmodem receiver ready, waiting for data...
press <Ctrl>+X several times to cancel transfer
press any key to continue...
file transfer ok
writing new firmware.......... OK
please reboot to run new booter
your choice:
RouterBOOT booter 2.14
RouterBoard 112
Memory size: 16 MB
kernel not found
trying bootp
RouterBoard 112
Memory size: 16 MB
RouterBOOT-2.14
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
r - reset booter configuration
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice: i - board info
Board Info:
Board type: 112
Serial number: 0F4D01D6DFB5
Firmware version: 2.14
Memory size: 16 MB
eth1 MAC address: 00:0C:42:0B:87:02
RouterBOOT-2.14
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice: o - boot device
Select boot device:
e - boot over Ethernet
* n - boot from NAND, if fail then Ethernet
1 - boot Ethernet once, then NAND
o - boot from NAND only
b - boot chosen device
your choice: n - boot from NAND, if fail then Ethernet
RouterBOOT-2.14
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
e - format nand
i - board info
p - boot protocol
x - exit setup
your choice:
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Rudios
Forum Veteran
Forum Veteran
Thu Nov 03, 2016 3:46 pm
It looks like your installation is broken (unable to start from internal storage)
RouterBoard will try to start from netinstall.
I would setup netinstall on your PC, hook it up to port 1 of the routerboard and see if it boots.
If so, install a proper RouterOS version via netinstall.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
nichky
Long time Member
Long time Member
Thu Nov 03, 2016 10:14 pm
i've been trying...same thing
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
roswitina
Mon Dec 05, 2016 5:40 pm
I had the same problem with my Mikrotik https://routerboard.com/RB2011UiAS-2HnD-IN
I finally did it with the following steps:
1. I have used the program Tera Term Web 3.1 http://wiki.meconet.de/doku.php/mikroti ... ll_updaten
2. I have used another notebook (computer) with Netinstall. This finally recognized the device ......
I believe that the virus scanner or a firewall can cause problems.
Rosi
nichky
Long time Member
Long time Member
Tue Dec 06, 2016 7:16 am
is it? let me have a look, and i will let you know.
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Rudios
Forum Veteran
Forum Veteran
Tue Dec 06, 2016 8:09 am
For sure that your firewall could have some negative impact on your tries.
Just temporarily disable your firewall completely on your PC.
nichky
Long time Member
Long time Member
Tue Dec 13, 2016 12:50 pm
would you like to help me, this is on German my german is terrible, so i've got problem with this one, how can i do?btw im using rb433ah
Download des aktuellen RouterBOOTs für Ihre Hardware
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
BartoszP
Tue Dec 13, 2016 1:50 pm
Check this: http://wiki.mikrotik.com/wiki/Manual:Netinstall
It is quite simple job.
Real admins use real keyboards.
nichky
Long time Member
Long time Member
Thu Dec 15, 2016 10:09 pm
BartoszP is not going. I've been fixed so many MT via netinstal, but one of them is't going :) Did you see up of the topic what kind of message i had?
Nikola Suminoski
MikroTik Consultan
MTCRE l MTCWE
Users browsing this forum: MSN [Bot] and 14 guests
