Deathlok
RB 850Gx2 Fan PINS
Fri Jun 24, 2016 2:21 pm
Hi all,
there is also a way to connect a 2pin fan to a 850Gx2 like there is on the 450G?
Thank You
InoX
Re: RB 850Gx2 Fan PINS
Sun Jun 26, 2016 12:27 am
Sure. FAN JP1
Cha0s
Forum Veteran
Forum Veteran
Sun Jun 26, 2016 2:46 pm
Sure. FAN JP1
JP1 is not populated http://img.routerboard.com/mimg/991_l.jpg
Are you suggesting manually soldering the 2 pins?
janisk
Tue Jul 12, 2016 12:35 pm
yes, JP1 is where FAN can be connected. That is 5V  MAX 0.15A. Make sure not to exceed MAX current.
Cha0s
Forum Veteran
Forum Veteran
Tue Jul 12, 2016 12:46 pm
I am asking again just to make sure. You mean manually soldering those two pins?
The pins header is not populated.
If yes, does that violate the warranty of the board?
janisk
Tue Jul 12, 2016 1:29 pm
any soldering will void warranty
Cha0s
Forum Veteran
Forum Veteran
Tue Jul 12, 2016 1:39 pm
So you cannot connect a fan to JP1.
On one post you say one thing, on other post you say another. :?
janisk
Tue Jul 12, 2016 1:44 pm
we cannot guarantee that user will not destroy the device by soldering. And then, the user cannot exceed the electrical limitations of the port or it can damage the circuit.
jarda
Re: RE: Re: RB 850Gx2 Fan PINS
Tue Jul 12, 2016 5:19 pm
Little drilled hole with tiny screw can hold a contact too. And without the soldering...
InoX
Wed Jul 13, 2016 12:50 am
I have about 5 mikrotik devices broken in about 10 years. Out of waranty. Who cares about mikrotik waranty if their devices doesn't brake?
blue
Wed Jul 13, 2016 12:04 pm
At my local supplier I found "Sunon Maglev MC17080V1". 5V, 17x17x8mm, but 160mA. Max allowed is 150mA, so could 10mA make some damage?
BR...
jarda
Wed Jul 13, 2016 12:10 pm
Anyway I am soldering in routerboards too if necessary. Never broke a piece by that.
JanezFord
Wed Jul 13, 2016 12:12 pm
Add a small resistor and you can use the 160mA fan safely ...
JF
jarda
Wed Jul 13, 2016 12:24 pm
How the resistor could multiply the current to run such powerful fan?
andriys
Wed Jul 13, 2016 12:48 pm
It can not multiply the current, but it can limit it. The fan will operate with somewhat reduced speed, but the board's circuits will be safe.
jarda
Wed Jul 13, 2016 12:53 pm
... Removed....
Zwodka
Wed Jul 13, 2016 10:07 pm
BR...
Look around here:
http://www.sunon.com/tw/products/pdf/maglev.pdf
Zorro
Long time Member
Long time Member
Sat Jul 30, 2016 4:07 am
Sunon Maglev MC17080V1 uses proprietary MagLev/VapoBearing, that supposed to be better in terms of resources, but not really time-tested.
so far i would sitck with ball bearings thus. eg "Sunon Maglev MC17080B1 model for example. also Maglev fans are "High Airflow" fans which would be kinda overkill for tiny/small devices.
for servers or say CCR it was more interesting thing.
zipvault
Fri Dec 30, 2016 5:28 am
The smallest fan i can find is pi-fan its .20A
Please advise
Its bloody hot here
Was 41 degrees celsius yesterday
And rb board is nearly hitting 60 degree
I believe with small fan i can get it down to 50 degrees
http://forum.mikrotik.com/viewtopic.php?f=13&t=116257
ZipVault
zipvault
Fri Dec 30, 2016 5:52 am
Can i use ether power to trigger fan
To turn on from temperature sys info threshold
Or trigger lan on and off by timmer for night and day
ZipVault
jarda
Fri Dec 30, 2016 8:40 am
No need to afraid. It was stated that mikrotik devices should be working as designed even in 60 degrees of ambient temperature.
daniel33333
Mon Oct 28, 2019 12:03 am
Has somebody actually got a fan running on the RB850Gx2? I have soldered a pin header to JP1 and attached a small fan (5V, max 0.05A) with square pad =GND, round pad = +5V. But the fan doesn't start. Also, I don't get any reading on a voltmeter attached to the pins. Do I have to do any ROS configuration for JP1 to start giving out voltage?
Users browsing this forum: No registered users and 44 guests
