pawelkowalski
CRS 112-4G-8S: problem with packet loss and preformance
Mon Jul 25, 2016 12:50 pm
We have some CRS deployed in our network. One of them works unstable. After running for some days (sometimes a week, sometimes a few hours) it suddenly drops throughput rate to about 50%, and packet loss at about 10 - 40% depending on packet size.
Simple diagram: (all in layer 2, 802.1q tags, traffic volume = about 700 Mbit/s)
[ A ] === [ CRS ] === [ B ]
This packet loss can be observed between A and B, but  pinging CRS from A or from B works ok. There are no errors in log, cpu is at 3%, only reboot helps.
ROS v6.35.4 (already updated), firmware 3.23
Any ideas where to look for solution? Seems to be something wrong on the switch side, thus I have no idea how to diagnose it.
P.
rzirzi
Re: CRS 112-4G-8S: problem with packet loss and preformance
Sun Dec 01, 2019 7:29 pm
I have exactly the same problem. Now it is at ROS 6.45.6. Have You found where the problem was? Maybe other people using that hardware have similar problems?
haver
Sun Jan 17, 2021 3:22 pm
I have the same problem using 6.46.6 bugfix firmware. Did anyone have any solutions ?
mkx
Sun Jan 17, 2021 4:01 pm
Did you upgrade routerboot as well? (/system routerboard upgrade). And a decent (prolonged) power-off after that?
BR,
Metod
haver
Sun Jan 17, 2021 8:58 pm
yes
Users browsing this forum: No registered users and 28 guests
