billjellis
HAP POE lite Power issues
Sun Aug 28, 2016 8:28 pm
Hi All,
I have hAP POE lite, current Firmware, that is powering 1 UAP AC lite and 1 NanoBeam AC 16. They will not auto-power on I have to force POE on. Any reason why this would happen.
UAP lite cable 10 - 20 meter
Nano beam 10 - 20 meters.
I can plug in a Pico with a standard patch cable and no problem.
Bill
pukkita
Trainer
Trainer
Re: HAP POE lite Power issues
Mon Aug 29, 2016 3:16 pm
Guess you mean Hex POE Lite.
Update ROS to 6.36.2, once upgraded check System > Routerboard, "Current" vs "Upgrade" firmware, and upgrade it if needed, Rebooting afterwards.
Then try setting different POE priority values (10 for the UAC, 20 for the NBE) on their Interface > Ethernet interface POE tab.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Users browsing this forum: krafg and 30 guests
