Motorbreath
LHG 5
Mon Oct 10, 2016 5:27 pm
Does the LGH 5 support only 5Ghz signals or can it also support 2.4?
https://routerboard.com/RBLHG-5nD
blingblouw
Re: LHG 5
Mon Oct 10, 2016 6:23 pm
The LHG5? It supports only 5ghz
docmarius
Re: LHG 5
Mon Oct 10, 2016 7:13 pm
If it would support 2.4 GHz, it would be called LHG 2. Dual band would be like LHG 52.
Btw, don't expect an outdoor AP with a high performance panel antenna to be dual band.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
Motorbreath
Re: LHG 5
Mon Oct 10, 2016 10:23 pm
I just ordered two of LHG 5's :) 3.5km distance, should work nicely :)
docmarius
Re: LHG 5
Tue Oct 11, 2016 11:53 am
Please report back about your results :-)
InoX
Re: LHG 5
Tue Oct 11, 2016 8:13 pm
2xLHG5 , 10km, 120mbps
docmarius
Re: LHG 5
Wed Oct 12, 2016 7:32 pm
Thank you InoX!
Time to buy some :-)
InoX
Re: LHG 5
Wed Oct 12, 2016 11:05 pm
I've installed ~15 LHG in the same spots where AirGrids 23/27. All LHG have 10-30 dbi better signal than AirGrids.
Motorbreath
Re: LHG 5
Sat Oct 15, 2016 9:56 am
3.5km, two LHG5's 135 mbps :) , working perfectly, what a great cheap antenna+everything else you need :)
docmarius
Re: LHG 5
Sat Oct 15, 2016 10:28 am
Thank you, I really needed some real life results. Great.
pe1chl
Re: LHG 5
Sat Oct 15, 2016 11:36 am
We have some of them in our hamnet and they work well, but we are not after those high speeds.
(10 MHz bandwidth and plain 802.11)
Users browsing this forum: No registered users and 26 guests
