kenyloveg
PPPoE performance issue on RB750Gr3/RB951G/RB962...
Sun Nov 27, 2016 8:00 am
Hi, I'm reporting this cuz i've already tried same configuration on RB750Gr3, RB951G, HAP AC and get same fail results.
[admin@MikroTik] > export hide-sensitive
# nov/27/2016 13:21:11 by RouterOS 6.38rc37
# software id = XXXX-XXXX
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] loop-protect=off name=ether3-wan
set [ find default-name=ether4 ] loop-protect=off name=ether4-lan
set [ find default-name=ether5 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether3-wan name=pppoe-out1 use-peer-dns=yes user=adxxxxxxxx@vip1 password=xxxxxxx
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add add-arp=yes address-pool=dhcp_pool1 disabled=no interface=ether4-lan name=dhcp1
add address=192.168.100.1/24 interface=ether4-lan network=192.168.100.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-server config
set store-leases-disk=never
add address=192.168.100.0/24 gateway=192.168.100.1
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Shanghai
/system routerboard settings
# Warning: memory overclocked
set memory-frequency=1200DDR protected-routerboot=disabled
/tool bandwidth-server
set enabled=no
As you can see, i've enabled fasttrack and the counter in /ip settings goes up.
While the results is around 94Mbps/24Mbps over 200Mbps/20Mbps filber cable. CPU rate never goes over 30%.
After I removed those fasttrack rules, only fastpath works, The results are 135Mbps/24Mbps, and CPU rate is around 35%-40%.
Duplicated this problem on RB951G, HAP AC, about the same results. Directly route by DHCP client (get from my fiber modem, no PPPoE client dialup), the NAT can reach up at 200Mbps/20Mbps.
At last i have to hook up my old netgear R7000, run speedtest again, and it always hit 200Mbps/20Mbps without any problem.
I would like someone to beat my suspicion about pppoe client performance issue by any proof.
Excuse for my bad english, thanks.
kenyloveg
Re: PPPoE performance issue on RB750Gr3/RB951G/RB962...
Sun Nov 27, 2016 8:02 am
By the way, I've check MSS with my laptop dialup, exact the 1414+28=1442, MRU is 1480.
2 ethernet cable speed are all 1Gbs (lan and wan ether)
kenyloveg
Tue Mar 07, 2017 2:48 pm
After upgrading RB750Gr3 to 6.39rc41,finally speedtest results hit 228Mbps, CPU load is about 38%-40%.
Now I'm going to seeding 500 more torrents for about 1 week see if the device can handle, then go to upgrade HAP AC/RB951G to check the same.
Thanks mikrotik for fixing this issue.
mmv
Trainer
Trainer
Mon Feb 04, 2019 11:27 pm
Sorry for excavation.
Try use fast-track feature https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
It can give much more performance. (But simple queues and queue tree with parent=global stop working properly. And some other features)
Mikhail Moskalev
Users browsing this forum: No registered users and 30 guests
