irghost
RB2011UiAS-2HnD - DC Power
Wed Feb 01, 2017 9:56 am
what can i do with this 2 options
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
msatter
Re: RB2011UiAS-2HnD - DC Power
Wed Feb 01, 2017 10:34 am
Looking at the symbols I see a 12V or 24V battery on the left (J1) and right from that there is a put power connector (J2) in. So you can solder two wires in or use a neat powerconnector in.
If it is safe to do this I really don't know.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
normis
Wed Feb 01, 2017 11:33 am
This device already has a power jack. This is a place for another one.
Zorro
Long time Member
Long time Member
Wed Feb 01, 2017 11:59 am
i guess its made for version for another enclosure(unified PCB save lot of time in production, generally).
right was for different power socket/jack.
left one i guess for backup battery of some kind.
aside generic, obvious uses, both are handy if you build dense, caseless RB setup(common in small-ish ISP datacenters).
irghost
Wed Feb 01, 2017 5:05 pm
place for battery?
irghost
Thu Feb 02, 2017 8:24 am
UP UP UP
Zorro
Long time Member
Long time Member
Wed Feb 08, 2017 8:27 pm
place for battery?
left likely for battery backup unit and right is looking for place to soldering power jack in different variant of PCB(for differen case or order?)
normis
Thu Feb 09, 2017 9:46 am
There is usually a reason why the connector is not loaded. It means it will not work. Or that you should not use it.
Users browsing this forum: No registered users and 18 guests
