efaden
Dead RB3011?
Fri Mar 24, 2017 6:34 pm
Hey All,
I have a RB3011 that I just attempted to upgrade. When it booted back up it got stuck at a white screen. Never goes any further. Won't netinstall or reset with the switch in the back.... literally just boots to the white screen and nothing else...
Already emailed mikrotik and the distributor... but it seems dead. Any ideas?
-Eric
kd6icz
Re: Dead RB3011?
Fri Mar 24, 2017 6:35 pm
What version did you attempt to update to?
Sent from my XT1650 using Tapatalk
efaden
Re: Dead RB3011?
Fri Mar 24, 2017 6:38 pm
Was on rc19, attempted to upgrade to latest RC. Had another one that did fine.
expert
Re: Dead RB3011?
Fri Mar 24, 2017 6:40 pm
And what's seen on serial console?
kd6icz
Re: Dead RB3011?
Ok. I'm currently on rc55 and I see rc58 is available. I hold off until we get an answer.
kd6icz
Re: Dead RB3011?
Fri Mar 24, 2017 6:55 pm
Well... I figured we won't know unless someone else tried and so I just installed rc58 and it rebooted fine.
efaden
Re: Dead RB3011?
Fri Mar 24, 2017 7:15 pm
Absolutely nothing.
efaden
Re: Dead RB3011?
Fri Mar 24, 2017 8:57 pm
Looks like this.... So far I have tried the reset button, serial port, powering via POE, .... nothing works. All of this from the upgrade. Both the blue and green light by the USB port are on....
Nothing else.
pe1chl
Re: Dead RB3011?
Sat Mar 25, 2017 12:47 pm
When you see nothing at all on the serial console during boot I think it has a hardware defect.
pukkita
Trainer
Trainer
Re: Dead RB3011?
Sat Mar 25, 2017 6:07 pm
Definitely, that's a bad sign, you'd better contact support.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
HA5MI
Re: Dead RB3011?
Sat Oct 27, 2018 3:36 pm
I have the same problem. Only white screen appears, the blue+green led is lit near USB port. Also tried everything. Measured serial TX & RX with oscilloscope, RX is snapped to 3,3V, but TX is stays at 0V. Can't see any hw failure on PCB, caps are in good condition (visual inspection only). Current reading is ~130mA @ 24V.
Please help, how can i save my board? (Warranty is off by now) :(
Users browsing this forum: No registered users and 15 guests
