amity2kare
750Gr3 goes dead after removing packages
Sat Apr 15, 2017 3:43 pm
This has happened with two routers I have purchased this month.
The router came with 6.36.1 and I upgraded it to 6.38.5 which is the current version and uploaded dude.npk for this specific version. I upgraded by uploading specific packages to the router, not the routeros file. The packages I uploaded were
system
security
advanced-tools
dhcp
dude
I rebooted the router and it went completely dead. No startup beep, nothing. This is the second router I have faced this with and don't see anyone else facing a similar issue yet. Could you tell me what I seem to be doing wrong?
msatter
Re: 750Gr3 goes dead after removing packages
Sat Apr 15, 2017 5:32 pm
Did you had a look at this page to see if you can revive your RB750Gr3?
https://wiki.mikrotik.com/wiki/RouterBOARD_hardware
As last resort you can use Netinstall.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
dadoremix
Sat Apr 15, 2017 6:09 pm
Netinstall is always working
Sent from my iPhone using Tapatalk Pro
pe1chl
Sat Apr 15, 2017 9:08 pm
This is not the proper way to do updates.
When you don't want to go into detail, just cliock "check for updates" and when there is
an update click "download and install". It will automatically install the correct packages.
Users browsing this forum: No registered users and 20 guests
