Those other devices operate at a different frequency where the atmospheric attenuation is not so big as it is on 60 GHz.Any idea what could be the maximum distance for this devices? I am using Ubnt Airfiber 24 at 15.3km link, and ubnt is declaring 13+ km. This is 1.5+ km! Could it reach 2km, and how will it behave at heavy rain?
Using 24 GHz at this distance gives very low reliability with rain. Guess pe1chl has a good backup connection or live in a desert.Those other devices operate at a different frequency where the atmospheric attenuation is not so big as it is on 60 GHz.Any idea what could be the maximum distance for this devices? I am using Ubnt Airfiber 24 at 15.3km link, and ubnt is declaring 13+ km. This is 1.5+ km! Could it reach 2km, and how will it behave at heavy rain?
The max distance and behaviour is not determined by the manufacturer, but by physics.
Need some to replace these Ignitenets. A replaced link again causes trouble. Very low quality of components. Hopefully LHG 60 works from the beginning.All my Dealers say begin of June
could you please tell me where can you disable the beamforming, and with what ros version?Hi,
we deployed LHG60 on link with distance 1,05 km. RSSI is -52/-52. In last firmware there is opportunity disable beamforming - we use it for perform adjustment. The link has capacity 1 Gbit FD, meassured by traffic generator.
[admin@MikroTik] > interface w60g monitor 0
connected: yes
frequency: 58320
remote-address: 30:07:4D:43:06:E9
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -53
tx-sector: 20
tx-sector-info: right 0.2 degrees, down 0.6 degrees
rx-sector: 96
Very nice product
There is something on the way...Need some to replace these Ignitenets. A replaced link again causes trouble. Very low quality of components. Hopefully LHG 60 works from the beginning.All my Dealers say begin of June
Got 2 links . Happy testing.LHG60 is on my desk
I have a short link around 200m to make some test I'd like to know the default tx power of the LHG 60?
Thank you in advance
/interface w60g> monitor 0
connected: yes
frequency: 64800
remote-address: 04:D6:AA:AE:CA:DF
mcs: 8
phy-rate: 2.3Gbps
signal: 80
rssi: -68
tx-sector: 6
tx-sector-info: right 1 degrees, down 1.4 degrees
rx-sector: 96
distance: 759.08m
Have on installed at 759m with the past few weeks, very impressed but went down a few times in very heavy rain the other day, no problems with light rain, fog or mist.
I do notice that if change frequencies on it the the alignment can move around.
Man O Man it took some fiddling around to get it line up
Code: Select all/interface w60g> monitor 0 connected: yes frequency: 64800 remote-address: 04:D6:AA:AE:CA:DF mcs: 8 phy-rate: 2.3Gbps signal: 80 rssi: -68 tx-sector: 6 tx-sector-info: right 1 degrees, down 1.4 degrees rx-sector: 96 distance: 759.08m
