Hello MikroTik Gurus,
Can anyone confirm if the NetMetal5 (https://routerboard.com/RB921UAGS-5SHPacD-NM) can be attached to the QuickMount Pro mount (https://routerboard.com/QMP)?
The info for the QuickMount Pro info says "You can use the quickMOUNT pro with any pole mountable device or MikroTik's small mounting clip with weight less than 1.5 kg." The NetMetal5 is pole mountable, but, as an owner of a NetMetal5, I don't see how the two can be attached based on the pictures I've found.
