mafiosa
Ethernet cable fault?
Sat Jun 10, 2017 12:14 pm
Is the cable faulty?
Cable test:
Status:NO LINK
normal / 0m
open / 93m
open / 95m
open / 91m
gustavomam
Trainer
Trainer
Re: Ethernet cable fault?
Sat Jun 10, 2017 4:27 pm
Looks like you have open circuit in 3 pairs.
Check the cable with a lan tester to confirm that.
Eng. Gustavo Angulo
Academy Xperts Spain
Mikrotik Certified Trainer
https://www.youtube.com/watch?v=Cbt2HVYwjYU
BartoszP
Sat Jun 10, 2017 5:25 pm
Trash it ... replace with new one.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
jarda
Tue Jun 13, 2017 6:34 pm
Maybe just connector needs to be replaced. Check the pins of the port if undamaged...
Users browsing this forum: TheUberGeek and 49 guests
