mafiosa
100mbps sfp support for Routerboards! Finally a ray of hope.
Thu Jul 06, 2017 10:08 am
So finally after days and months of looking for a 100mbps sfp module for mikrotik routerboards! Finally I have found a "special type" of sfp that does fiber at 100mbps but makes connection to board at 1G as per previous post.Its called SGMII sfps.
http://www.eoptolink.com/products/sgmii-sfp
Please check out the above link.Now can anyone from Mikrotik confirm me if routerboard supports SGMII?
w177f
Re: 100mbps sfp support for Routerboards! Finally a ray of hope.
Thu Jul 06, 2017 11:01 am
While it depends on the switch chip, I believe all do.
What Mikrotik to you have?
Cheers,
Will
MTCNA | MTCRE
mafiosa
Thu Jul 06, 2017 11:15 am
Rb3011uias rm
w177f
Thu Jul 06, 2017 12:01 pm
You should be good to go - the 3011 has the IPQ-8064, which supports SGMII.
Cheers,
Will
MTCNA | MTCRE
msatter
Thu Jul 06, 2017 3:16 pm
Have you seen this thread: viewtopic.php?f=2&t=122298#p606404
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta58 / Winbox 3.27 64bits / MikroTik APP 1.3.15
mafiosa
Fri Jul 07, 2017 12:04 pm
How is it relevant to sgmii sfp?
mafiosa
Fri Jul 07, 2017 12:06 pm
Now I can't find Bidi sgmii sfps! Most are out of stock.If you can find then please tell me.1550tx/1310rx single mode single fiber
Users browsing this forum: almeiras, ArtisM, pipomolo42 and 59 guests
