LittleMan
Best ports for WAN / ISP on RB1100AHx4
Wed Aug 09, 2017 11:10 am
I have two ISP uplinks that I would like to configure in a load balance configuration. Which ports are best to be used for the ISP uplinks, and which for the LAN configuration?
Thank you!
pukkita
Trainer
Trainer
Re: Best ports for WAN / ISP on RB1100AHx4
Wed Aug 09, 2017 11:27 am
Typically, ether11 and ether12, as they're out of the switch chips (better for LAN) and have direct CPU connection.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
vadimbn
Thu Aug 10, 2017 4:37 pm
RB1100AHx4 has other diagram. In this model all ethernet ports are plugged into a switches via transformers. So there is no difference in this case, all ports are equal...
Veni. Vidi. Feci.
RBSXTLTE3-7, CRS326-24G-2S+RM, RB850Gx2, RBMRTG, RB1100AHx4, RB750Gr3, RBD52G-5HacD2HnD-TC, Woobm-USB
pukkita
Trainer
Trainer
Re: Best ports for WAN / ISP on RB1100AHx4  [SOLVED]
Thu Aug 10, 2017 6:01 pm
Ouch... I'd swear I read RB1100AHx2... :D
Not exactly... In this case, optimal ports would be ether11-13 leaving one unocuppied if possible; rationale: they won't be sharing as many ports (5) into the 2,5Gb/s switch chip uplink towards the CPU as it happens with ether1-5 or ether6-10.
LittleMan
Fri Sep 01, 2017 11:59 am
Thank you for the answers. That's what I thought also. So I will configure ISP1 on ether11 and ISP2 on ether12, leaving ether13 empty, for service/diagnostics.
Users browsing this forum: No registered users and 22 guests
