pixoft
hEX PoE WAN to LAN NAT Speed
Fri Aug 11, 2017 9:06 am
Hi everyone!
I'm thinking about purchasing a hEX PoE (RB960PGS), but i am unsure if it will be able to handle my 1 Gb/s internet connection. I'm not going to do anything fancy, no VLAN, no special firewall rules, no DMZ, probably no QoS. I'd basically just use it like any consumer home router with NAT and SPI firewall turned on.
Can anyone confirm that i'll be able to achieve something close to 950 Mbit/s with NAT (and Fasttrack) turned on?
There are some posts out there that suggest it should work, other that say it doesn't (mostly older posts), that i'd need at least an CCR1009, which is way too much for my use.
hturkan
Re: hEX PoE WAN to LAN NAT Speed
Fri Aug 11, 2017 12:13 pm
Yes RB 2011 Fasttrack enable bandwidth 900Mbit CPU %60
RB 2011 CPU 600 MHz
RB960PGS CPU 800 MHz
Not extend memory Ip routing
Yes RB960 1GBİT RATE
pixoft
Sun Aug 13, 2017 8:21 pm
Thanks for the info. I thought they were different CPU, i didn't know Qualcomm bought Atheros.
mistry7
Sun Aug 13, 2017 10:08 pm
Users browsing this forum: No registered users and 18 guests
