anuser
CRS317-1G-16S+RM: CWDM/DWDM SFP+ optics?
Fri Aug 11, 2017 5:30 pm
can I use any CWDM/DWDM SFP+ optics with the CRS317-1G-16S+RM? Which one would you recommend for 10km?
Regards
pukkita
Trainer
Trainer
Re: CRS317-1G-16S+RM: CWDM/DWDM SFP+ optics?
Fri Aug 11, 2017 6:13 pm
It depends, for non Mikrotik hardware, see supported hardware.
S+31DLC10D is the Mikrotik product for 10G - 10Km (single mode).
CRS317 hasn't been included yet on Mikrotik SFP Compatibility Matrix, but being both Mikrotik products I bet it will support it.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
tgrand
Long time Member
Long time Member
Fri Aug 11, 2017 9:32 pm
Most sfp manufacturers and distributors provide samples.
Request a sample and test.
I have personally not come across any that do not work....
Andrewyi12
Mon Aug 21, 2017 11:02 am
yeah, CWDM/DWDM SFP+ optics would not work for CRS317-1G-16S+RM. But you can use S+2332LC10D for 10G network connection. Bidirectional SFP+ 10G module kit. Kit contains two SFP+ modules that can be used as pair to achieve operating data rate up to 10Gbps for distances up to 10km on single optical cable.
skylark
Re: CRS317-1G-16S+RM: CWDM/DWDM SFP+ optics?  [SOLVED]
Mon Aug 21, 2017 11:27 am
As long as SFP/SFP+ modules are made for right standard and comply with SFP MSA they should be usable in our hardware. Please read product manual about compatibility with other manufacturer devices. CWDM/DWDM SFP+ optics should work in CRS317-1G-16S+RM.
anuser
Mon Aug 21, 2017 11:16 pm
Thank you!
chechito
Tue Jul 17, 2018 4:42 am
mikrotik its aware of CDWM importance
CyB3RMX
Fri Jul 20, 2018 1:55 am
Where do you get this updates ?
Thanks in advance!
Have a great day!
Certified: MTCNA - MTCWE - MTCRE
psannz
Fri Jul 20, 2018 10:31 am
Thanks in advance!
CWDM-MUX8A: https://mikrotik.com/product/cwdm_mux8a
doneware
Trainer
Trainer
Fri Jul 20, 2018 3:12 pm
i have DWDM ER SFP+ working in there, but it also works with DWDM ZR optics:
[me@myswitch] /interface ethernet>   monitor 16 once
                    status: link-ok
          auto-negotiation: done
                      rate: 10Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
              sfp-tx-fault: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: LC
       sfp-link-length-9um: 40000m
           sfp-vendor-name: RMC TEL
    sfp-vendor-part-number: SFP+-DWDM-ER-C31
       sfp-vendor-revision: A
         sfp-vendor-serial: 1552.52-ERG3P011
    sfp-manufacturing-date: 16-03-30
            sfp-wavelength: 1552.52nm
           sfp-temperature: 39C
        sfp-supply-voltage: 3.29V
       sfp-tx-bias-current: 54mA
              sfp-tx-power: 1.828dBm
              sfp-rx-power: -12.609dBm
           eeprom-checksum: good
                    eeprom: 0000: 03 04 07 20 00 00 00 00  00 00 00 06 67 00 28 ff  ... .... ....g.(.
                            0010: 00 00 00 41 52 4d 43 20  54 45 4c 20 20 20 20 20  ...ARMC  TEL
                            0020: 20 20 20 20 00 00 00 00  53 46 50 2b 2d 44 57 44      .... SFP+-DWD
                            0030: 4d 2d 45 52 2d 43 33 31  41 20 20 20 06 10 34 fa  M-ER-C31 A   ..4.
                            0040: 00 1a 00 00 31 35 35 32  2e 35 32 2d 45 52 47 33  ....1552 .52-ERG3
                            0050: 50 30 31 31 31 36 30 33  33 30 20 20 68 f0 03 64  P0111603 30  h..d
                            0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0080: 5a 00 f1 00 55 00 f6 00  8c a0 75 30 88 b8 77 24  Z...U... ..u0..w$
                            0090: ea 60 3a 98 d6 d8 44 5c  c3 c7 13 94 9b 83 18 a6  .`:...D\ ........
                            00a0: 27 10 01 3c 18 a6 01 f5  3a 00 17 00 38 00 19 00  '..<.... :...8...
                            00b0: 27 10 d8 f0 27 10 d8 f0  00 00 00 00 00 00 00 00  '...'... ........
                            00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00  ....?... ........
                            00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 44  ........ .......D
                            00e0: 27 4f 80 8d 6a 7a 3b 85  02 de 2d 48 00 07 00 00  'O..jz;. ..-H....
                            00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
#TR0359
MattRichards
Mon Jul 23, 2018 5:27 am
Regards
Looks like Mikrotik now sell CWDM SFP/SFP+ - https://mikrotik.com/product/s_c47dlc10d
The FS.com 1310's are listed as working on the wiki page, so I can't see why the CWDM versions of those wouldn't also work.
doneware
Trainer
Trainer
Fri Jul 27, 2018 7:58 pm
there would have been issues prior 6.31 to be honest. normal (gray) SFPs have different unit code than C/DWDM ones. so mikrotik devices couldn't even detect them.
https://www.finisar.com/sites/default/f ... Rev_E2.pdf - see page 5
regular SFP/SFP+ is 03h, whereas DWDM SFP is 0Bh.
i asked for this and the guys @ mikrotik nailed it in 2 weeks. v6.31rc16 was the 1st version to support them. then in the next rebuild they added full ddmi support to it.
and i talk about DWDM ones with 50 or 100GHz grid, not BiDir ones, that are commonly referred as "WDM" but in general are just 1310/1490 (or 1550)nm gray bidirectional xceivers.
#TR0359
doneware
Trainer
Trainer
Fri Jul 27, 2018 8:03 pm
well, you can also use OADMs, and just a single optical cable, so you can drop/add wavelengths on each pop. that is the fiber topology will be just a line or a ring, but you can have each node (or more) connected as star or dual-star logical topology. we do this since years, but we do it with DWDM, as you can get much more channels into it, say 40 instead of 8 or 12. but in general it is pretty much the same, full passive optical stuff. and everything is dirt cheap. and it is speed independent: you can have 1G/10G/(later 25 or 50G)/100G if you wish. albeit with 10G chromatic dispersion becomes a problem on 30+km distances.
#TR0359
Users browsing this forum: No registered users and 26 guests
