jajczak
CRS 317 support 802.1ad QinQ
Sun Aug 20, 2017 5:02 pm
Hello Everybody!
Its my first post on this forum, but I am with MT from 2.8.x version.
My question is:
Is QinQ vlans supported in CRS317-1G-16S+RM?
In specs is 801.Q only...
paulct
Re: CRS 317 support 802.1ad QinQ
Mon Aug 21, 2017 10:12 am
+1 - I would presume it supports it??
jajczak
Wed Aug 23, 2017 9:39 am
I have reply from support@mt: Does not support vlan-in-vlan.
normis
Wed Aug 23, 2017 1:23 pm
CRS317-1G-16S+RM currently does not support QinQ VLANs in switch chip (hardware support).
You can currently configure it through VLANs:
https://wiki.mikrotik.com/wiki/Manual:I ... LAN#Q-in-Q
802.1ad is a bridge standard so we must extend our bridge implementation to support it in hardware (though switch chip). We are working on it, it will be added in future versions.
paulct
Wed Aug 23, 2017 4:41 pm
So it does not support this? https://wiki.mikrotik.com/wiki/Manual:C ... 8Q-in-Q.29
marlow
Fri Nov 03, 2017 2:02 am
Doing QinQ in Software on a CRS317 is not very efficient though, when it comes to 10Gbit/s traffic. At 1-2 Gbit/s traffic, we'll be at CPU maximum.
Where are we with this supporting QinQ in the new configuration style ?
/M
Communication is the beginning of understanding
-- AT&T
stackflow
Fri Nov 03, 2017 7:36 am
/M
Aren't the QinQ a switch chip feature? I thought it was done by hardware, not involving the CPU.
marlow
Fri Nov 03, 2017 12:18 pm
Please read back in the thread and you'll realise, that Mikrotik stated, that the chip feature is not exposed to winbox yet and it has to be done in software until such time.
/M
-- AT&T
Moc
Mon Nov 13, 2017 9:46 pm
Is it still true that Q-in-Q is not supported with firmware 6.41rc5*
marlow
Mon Nov 13, 2017 9:55 pm
Only in software. (Meaning CPU)
Hardware is not configurable yet.
/M
Sent from my SM-G930F using Tapatalk
-- AT&T
hknet
Sat Mar 17, 2018 1:55 am
as we are approaching v6.42 is no-QinQ-in-hardware still the case with the upcoming release?
viteaglavan
Mon Mar 19, 2018 1:53 pm
Hi guys,
I'm new to this forum :)
Could you please explain how can I set TPID for vlan interface with 'use service tag' marked?
As far as I understood it uses the 0x88A8 for service tag, and 0x8100 for inner tag.
I need the ability to select service tag TPID values between 0x88A8 | 0x9100 | 0x8100
becs
Thu Mar 22, 2018 9:51 am
Hello, by default VLAN interface uses and accepts encapsulation with TPID 0x8100. If "use-service-tag" option is enabled, then VLAN interface uses TPID 0x88A8. TPID 0x9100 is not supported in VLAN interfaces.
mhugo
Sat Apr 28, 2018 8:12 pm
As other people wonder - Are we/Have we gotten hardware support for QinQ?
hknet
Tue May 01, 2018 5:56 am
Doesn't look like it, though the Marvell 98DX8216 is a metro chipset (marvell's words) which would suggest 802.1ad should be available at the HW level.
But my guess is we won't see this with this HW.
regards,
hk
guntis84
Thu Jul 12, 2018 9:54 pm
It is available sinc 6.43rc13
*) crs3xx - added initial Q-in-Q hardware offloading support (CLI only)
Users browsing this forum: slimmerwifi and 15 guests
