xty
Mikrotik RB2011UiAS-RM vs MIKROTIK RB-2011UIAS-IN
Sun Sep 10, 2017 6:55 am
Hi guys,
I'm new to Mikrotik, So, sorry if I ask a sample question or sounds like a noob.
I want to start learning how to use Mikrotik and bought some books. To practice, I want to buy a Mikrotik router with level 5.
I prepare this to support my new school which have 3 computer lab and some user who have the privilege to use the intenet.
The total active user is no more than 200 users. But maybe need more in the future.
Because of the budget, I want to buy a Mikrotik with cheap price like Mikrotik RB2011UiAS-RM vs MIKROTIK RB-2011UIAS-IN.
Which one is more fit for me?
Please give me your advice.
nightcom
Re: Mikrotik RB2011UiAS-RM vs MIKROTIK RB-2011UIAS-IN
Sun Sep 10, 2017 12:14 pm
They are both the same, diference is that one can be mounted in rack and second can't and it's smaller. For 200 users I think minimum is RB3011UiAS it's not much more expensive and it's ARM 2 cores, 1GB RAM...but in this case better someone more experience will say something.
RB3011UiAS-RM / RB2011UiAS-in / RB750Gr3 + Dude / CRS326-24G-2S+RM
pe1chl
Sun Sep 10, 2017 12:39 pm
I agree that the RB3011 is the better choice, but when the budget is really a problem the RB750Gr3 is better than teh RB2011UiAS models.
(but check for the CORRECT model with Gr3)
irghost
Sun Sep 10, 2017 4:25 pm
RB750Gr3 Is much better than RB2011
But it has license level 4
and just 5Gig Ethernet
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
pe1chl
Sun Sep 10, 2017 4:50 pm
Ok maybe he has to be more careful in selecting a router then.
I never use this "usermanager" and "hotspot" stuff so for me the only license level difference is between level 3 (for wifi devices that are only usable point-to-point)
and higher levels (that can do anything I want). 4,5 or 6 does not matter to me.
Maybe for him it is important, also because "usermanager" is not available on all devices.
irghost
Sun Sep 10, 2017 5:12 pm
Not Just UserMan (which does not supported yet)
there is so many different between license 4-5-6
PPPoE,PPTP,L2TP,OpenVPN tunnels counts
Hotspot Active users
xty
Sun Sep 10, 2017 5:22 pm
Hi guys, thanks for the answer!
It is really help me to decide.
So, it is better for me to pick RB750Gr3 or RB3011 then?
The 3 computer lab and 4 special room already have Unify AP.
irghost
Sun Sep 10, 2017 5:24 pm
do you use PPPoE ,PPTP,L2TP ,........... ?
xty
Sun Sep 10, 2017 5:30 pm
It is PPPoE.
Users browsing this forum: No registered users and 23 guests
