snoopy78
CRS210-8G-2S+IN PoE IN?
Fri Oct 13, 2017 12:38 pm
i just bougth a CRS210-8G-2S+IN.
according to spec sheet https://i.mt.lv/routerboard/files/CRS21 ... 150201.pdf it can be powered on ETH1 by PoE (Passive and IEEE 802.3af/at).
Howeverm when i connect the device on ETH1 to my 802.3af/at PoE switches i can't power the device.
Is there anything i should consider/change?
Other devices using the same switchport & cable can be powered up to 25W (class 4).
Thank you for your help.
BR
snoopy78
andriys
Re: CRS210-8G-2S+IN PoE IN?
Fri Oct 13, 2017 1:06 pm
A cross-over cable may be required. Please check the compatibility matrix out.
snoopy78
Fri Oct 13, 2017 1:46 pm
it is weired...
using old poe injector and same cable the device powers up
if using old dgs-1210-10P and same cable the device powers up
if using newer switches (d-link, netgear) the device doesn't power up at all
thank you for the link...i'll check it ^^
snoopy78
Tue Jan 01, 2019 3:13 pm
i found the cause.
when using CROSSOVER Cable i can power the device successfully by a DGS-1210-10P B Rev and DGS-1100-05PD
Users browsing this forum: No registered users and 8 guests
