nordex
Mikrotik QRT VS DynaDish
Sun Dec 03, 2017 8:08 pm
can someone please write differences between QRT 5ac and DynaDish 5ac.
What are practical differences between them (ignoring license, mounting and size).
What are practical advantages/diferences of one over other one.
Why is qrt more expensive ?
Does it have better antenna for PtMP ? back side radiation is lower ?
I've been using both (+10 pcs of each, <5km links, mostly PtP) but I have not found noticable performance differences.
mistry7
Re: Mikrotik QRT VS DynaDish
Sun Dec 03, 2017 8:52 pm
the Antenna Pattern are the difference, and the device shielding to the back.
QRT works better in noisy environment.
But both Antennas has big side lobes, and asymetric pattern.
we are waiting for this one, because of small side lobes an high antenna gain in hole spectrum:
https://www.rfelements.com/assets/Uploa ... TP-400.pdf
https://www.rfelements.com/assets/Uploa ... TP-550.pdf
Another advantage, we need not to change antenna in error case.
And it will be easy to go with wave 2 and 802.11ax with the same Antenna.
And Mikrotik M11G is nice board with high Cpu power.
I Hope we will see support for this:
https://www.compex.com.sg/product/wle1216v5-20/
https://www.compex.com.sg/product/wle650v5-25/
mistry7
nordex
Sun Dec 03, 2017 9:07 pm
So QRT is better in noise area. ok.
Have you tried to test qrt/dyna vs netmetal+other anntena in same conditions ?
Does rf elements antenna show noticeable performance upgrade vs qrt/dyna.
mistry7
Sun Dec 03, 2017 10:02 pm
no test yet.
They are brand new and il waiting for receive my preorder from distribution.
they are anounced for Q2-2017 and we still wait for it......
Then i will test it as exchange for Dynadish an QRT and mant30
We just love the changeable board in this quick removeable twist port adapter.
We have loved this feature on Horn Antennas.
One Spare fit for all needs.
If you want to upgrade board or exchange one with error, antenna stays Mounted and alligned.....
just a job for 5 minutes, and with minimum down time.
On high masts without any tools.
No pigtails with water...
nordex
Sun Dec 03, 2017 10:13 pm
what RF elements antenna model would you recommend for ptp ?
except this one which is yet to come.
and which mikrotik board.
mistry7
Sun Dec 03, 2017 10:18 pm
distance?
nordex
Sun Dec 03, 2017 11:16 pm
4-5 km urban area
mistry7
Sun Dec 03, 2017 11:56 pm
Hi nordex,
with 30dBm in EU TP-400 is enough you will stay about -65db received signal,
that is good if you have enough space for TP-550 it will even better.
2x TP 400 / 550
2x Routerboard Adapter V2
2x M11g
2x R11e-5HacD
(could be replaced with wave 2 or 802.11ax later, cheap upgrade...)
mistry7
Matess
Sat Mar 23, 2019 11:13 pm
mistry7
any update for Compex WLE1216V5-20 support?
mistry7
Sat Mar 23, 2019 11:19 pm
mistry7
No
Users browsing this forum: No registered users and 4 guests
