MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
Netboot
Fri Jan 05, 2007 1:30 am
Hello
I am tring to use netinstall and also upgrade the bioson rb100
I set the rb to boot from ether but no matter how hard I try the board will not get an IP address.
Is there a trick to this?
Seems simple but did not work
GotNet
Fri Jan 05, 2007 2:50 am
Works - I do it a lot. Instructions are somewhat clear. :)
Cable direct to RB from PC?
IP in netinstall same subnet as PC?
Equis
Forum Veteran
Forum Veteran
Fri Jan 05, 2007 3:02 am
Yea, thats what I thought easy
I have done that but it just hangs when its trying to get an IP address.
Can is fine, I can winbox into it if it boots from nand
I have the serial console open, don't think that would make a difference
set to boot from ether and bootp (also tried dhcp) it wont get an IP address.
I just read the changelog, its said something about fix to make etherboot work reliably, perhaps thats related?
sergejs
Fri Jan 05, 2007 12:38 pm
1) Make sure that you have downloaded correct version of Netinstall.
There are two different netinstall, one for RB100/500 and second for other routers supporting EtherBOOT.
2) Check that you have correct Netinstall configuration,
http://www.mikrotik.com/testdocs/ros/2. ... 6657223797
Equis
Forum Veteran
Forum Veteran
Sat Jan 06, 2007 1:21 am
Yes I have teh correct one, thanks for the link tho
I'll try on a different PC
GotNet
Sat Jan 06, 2007 3:06 am
Just a thought - If I run netinstall on a notebook with two interfaces, it won't work. I need to disable the active wireless card then the eth port seems to get noticed.
Equis
Forum Veteran
Forum Veteran
Sat Jan 06, 2007 3:22 am
That could be it, this pc has 2 nics
smatsak
Re:
Tue Jan 26, 2016 4:56 pm
fixed and really working, you need second launch of netboot after reboot windows 7
First pass: follow instruction to use netboot (result - MAC address is absent)
Second pass: reboot Windows 7 and start netboot again (result - MAC address is present )
enjoy
Users browsing this forum: No registered users and 35 guests
