magnavox
CCR-1036 and SFP+ 10G perfomances
Thu Feb 08, 2018 6:37 pm
Hello to all.
I m testing in LAB a link between two CCR1036-8G-2S+ and SFP+ 10G (Mikrotik S+85DLC03DI)
BTEST not more 1GB in TCP and 2.5GB in UDP.
- ROS 6.41.1 (latest version)
- SFP+ autonegotation disabled and fixed to 10G
Where are wrong?
Best regards.
Best Regards...
Steveocee
Re: CCR-1036 and SFP+ 10G perfomances
Thu Feb 08, 2018 7:38 pm
You should not use the Mikrotik tool. It is inefficient and does not use multi cores.
Connect a machine either side and do a “real” throughout test.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
magnavox
Thu Feb 08, 2018 10:58 pm
I agree with you, the BTEST can be inefficient, but I also tried whit 3 CCR linked via 10G SPF+... CCR_01<>CCR_02<>CCR_03 same results.
Can you suggest some >1GB testing machine?
LINUX box + Iperf?
Tnx
Best Regards...
townet
Wed Oct 03, 2018 9:52 am
why have you S+85DLC03DI SFP+ modules ?
The correct PN is S+85DLC03D, whitout "I".
"I" version have less distance capacity and other shortcomings.
Regards
http://twidunode.com the best UPS PoE injector, solar, battery, 24/48, gigabit, canBUS, 1Wire. All together !!
magnavox
Wed Oct 03, 2018 2:58 pm
Regards
TNX!
Best Regards...
Guntis
Wed Oct 03, 2018 4:26 pm
LINUX box + Iperf?
Tnx
Iperf would work, another option is to use Traffic Generator.
Users browsing this forum: No registered users and 26 guests
