toxcomp
RB750Gr3 temperature
Sun Feb 25, 2018 9:51 pm
Got myself two hex routers, RB750Gr3...they run the same config/software release, yet one is approaching 60 degrees C where another barely registers 31...
No idea what is wrong, CPU is barely used etc....
sebastia
Re: RB750Gr3 temperature
Mon Feb 26, 2018 3:23 pm
Mine is at 35-ish too. These are low power devices, should be quite cool.
Maybe the sink isn't sitting properly: viewtopic.php?t=113068
lambert
Long time Member
Long time Member
Mon Feb 26, 2018 8:08 pm
Same location? Not stacked? Same airflow opportunities?
If same location, swap positions. See if heat follows device or position.
p3rad0x
Long time Member
Long time Member
Wed Feb 28, 2018 11:18 am
Does if feel warmer to the touch?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
deanMKD1
Thu Mar 01, 2018 12:29 am
Mine idle on 20 celsius.
Users browsing this forum: psannz and 61 guests
