esquirrel
Opening RB941 tower case without damaging it?
Mon Mar 12, 2018 2:24 am
I have the RB941 TC model. The sides of the case are curved upward so its kind of difficult to open. Likely pushing simultaneously on both tabs will get it open without breaking it but I just wanted to check here with others that indeed that is the correct way to open it before I damage it.
juliokato
Re: Opening RB941 tower case without damaging it?
Tue Mar 13, 2018 1:53 pm
drop the RB941 TC the table on the floor he dismounts alone. :?
It happened to me. :o
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
esquirrel
Tue Mar 13, 2018 9:57 pm
There are a number of free programs which might be helpful for you to check your grammar in other languages than your native one. (Several run under LibreOffice, so links to them can be found there.)
The problem of course is the meaning. Something may have altogether the wrong meaning but be grammatically correct.
Anyway, with difficulty I was able to open it up without damaging anything by pressing on the tabs with a screwdriver.
Thank you for the suggestion.
[quote=juliokato post_id=647721 time=1520942035 user_id=83983]
[/quote]
Users browsing this forum: No registered users and 26 guests
