i still cant get an answer to this, on the new: CRS112-8P-4S-IN
it has 2x DC plug inputs, so if you plug in a 24v DC in AND a 48v DC in, can you then *choose* Passive 24v POE on some ports, and 802.3at/af (active poe) on some ports?
ie like you can do on a UBNT EdgeSwitch POE ?
or is it all or nothing on the POE ports? (ie all are 24v passive POE, or all are AT / AF poe ?)
this thread seems to say each port "AUTO" selects AT/AF or passive POE (not what we want):
viewtopic.php?t=120219
In some spots we have to put 2x hex POE mt's right next to each other, as some eth runs need Passive POE, others need active AT/AF, (or we use 8 or 24 port UBNT EdgeSwitchs also). we would love to use the new CRS112-8P-4S-IN (or the new 24pt version!) IF IT ALLOWS the user to manually select POE type for each port.
thanks
