RK
Long time Member
Long time Member
Can't read Voltage via SNMP on CRS112-8P-4S
Sat Mar 31, 2018 4:27 am
Self explanatory:
[]> /system health print oid
active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
processor-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
current: .1.3.6.1.4.1.14988.1.1.3.13.0
fan-speed: .1.3.6.1.4.1.14988.1.1.3.17.0
fan-speed2: .1.3.6.1.4.1.14988.1.1.3.18.0
power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
# snmpget -v1 -c public x.x.x.x .1.3.6.1.4.1.14988.1.1.3.8.0
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.14988.1.1.3.8.0
RK
Long time Member
Long time Member
Re: Can't read Voltage via SNMP on CRS112-8P-4S
Thu Apr 05, 2018 8:14 pm
Mikrotik, are there plans to fix this software bug?
jarda
Thu Apr 05, 2018 8:32 pm
RK
Long time Member
Long time Member
Sat Apr 07, 2018 4:47 am
Thanks for confirming that I am doing everything correctly and that this is a software bug.
VasilisCY
Thu Sep 27, 2018 6:59 pm
Any updates on the issue ?
Working with version 6.43.2 and
[admin@MikroTik] > /system health print oid
only
but,
temperature: 43C
psu1-voltage: 25.6V
psu2-voltage: 0V
I will prefer snmp read instead of wring a script to telnet to the switch just to get a value.
jose
Mon Dec 03, 2018 7:15 pm
Any update with this problem?
Kampfwurst
Mon Dec 10, 2018 5:08 pm
same problem with the RB1100x4
jose
Wed Jan 09, 2019 8:57 pm
bump
scampbell
Trainer
Trainer
Wed Mar 06, 2019 7:27 am
bump please
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
mimbach
Wed Apr 17, 2019 7:49 am
Bump.
VasilisCY
Wed May 15, 2019 11:58 pm
Well ??
Is been a long time now. Any effort to resolve this ?
Running latest stable version(6.44.3) on CRS112-8P-4S
[admin@Switch] > /system health print oid
[admin@Switch] >
vecernik87
Forum Veteran
Forum Veteran
Thu May 16, 2019 3:28 am
Long time? Not even 10 years yet. You seem to be bit impatient, don't you think? :D
CJSA
Tue Jul 23, 2019 11:10 am
Hi Guys
Any Feedback on this?
As small as this issue may seem, this is a vital SNMP OID required for remote site monitoring, espescially for South African clients using the equipment on their highsites with all of the local Electricity supplier issues.
We have no way of monitoring PSU1 or PSU2 voltages directly via SNMP on our CRS units as the existent oid's has been removed and it would seem that the original issue has not been attended to and been parked for over a year now.
Please advise, sorting this issue out will be much appreciated.
PeS
Tue Oct 22, 2019 1:22 pm
Anoher time passed by and no change....while we are doing battery backup setups, this would help us lot to monitor such sites.
[admin@Obedovice - Switch] > /system health print
temperature: 41C
psu1-voltage: 23.6V
psu2-voltage: 0V
[admin@Obedovice - Switch] > /system health print oid
[admin@Obedovice - Switch] > /system routerboard print
routerboard: yes
model: CRS112-8P-4S
serial-number: 9B200A22E7B8
firmware-type: qca8513L
factory-firmware: 3.41
current-firmware: 6.45.6
upgrade-firmware: 6.45.6
joeg321
Wed Oct 23, 2019 6:35 pm
We are also in need of this bug to get fixed. Just moved to this switch from another Mikrotik switch and no SNMP voltage monitoring. Please fix asap.
KbzA
Tue Feb 18, 2020 6:15 pm
any news?
jose
Tue Feb 18, 2020 6:53 pm
There are some ways to get the volt besides SNMP.
You could get the voltaje through API and call through a script.
require('routeros_api.class.php');
function getVoltaje($request, $response, $args)
    $ip = $request->getAttribute('ip');
    $username = "XXXX";
    $pass = "YYYYYY";
    $API = new RouterosAPI();
    if ($API->connect($ip, $username, $pass)) {
        $ARRAY = $API->comm("/system/health/print", array(".proplist" => "psu1-voltage"));
        flush();
        $float = floatval($ARRAY[0]["psu1-voltage"]);
        echo ($float * 10);
        $API->disconnect();
    } else {
        print_r($API->connect($ip, $username, $pass));
        echo "no se pudo conectar al servidor:" . $ip . '\n';
        return false;
Remember to use the last routeros_api.class.php
scampbell
Trainer
Trainer
Sun Jun 21, 2020 7:19 am
Any progress on the SNMP Health moniroring please ? Still no Voltage OID's....... 2 years 3 months I reckon since this was first requested ???
[admin@CRS112] /system health> pr
temperature: 34C
psu1-voltage: 24.3V
psu2-voltage: 48.6V
[admin@CRS112] /system health> print oid
___________________
l0ft13
Tue Jul 21, 2020 2:19 am
if you use the dude to monitor then you can get this value using a function
round(ros_command(":put [/system health get psu1-voltage]"))/10
nje431
Fri Jul 24, 2020 4:44 am
Is there something else we need to do? In the Dude or in the router? I'm trying this with a RB1100AHx4 running 6.45.9, and it's not working. The "psu1-voltage" is one of the parameters shown when you do a "/system health print". When I place the command in the device appearance, I get back a 0 instead of the 24 I expect. If I remove the round function and the /10, I get nothing displayed.
nje431
Fri Jul 24, 2020 5:22 am
Found my problem. "Router OS" has to be enabled. But the Dude is flaky and doesn't always want to connect when you first check the box and apply. It has to wait until the next connect time, which by default is 24 hours. And rebooting the Dude doesn't connect on the first try either. Arrrr.
phendry
Fri Jul 24, 2020 5:34 am
Tried clicking the 'Reconnect' button in the dude?
nje431
Fri Jul 24, 2020 5:43 am
That works! Thanks!
Elans
Fri Jul 24, 2020 7:12 am
Starting from version 6.47beta19 / 6.47 there have been health improvements. More information can be found under "/system health gauges print" and if you are looking for oid "/system health gauges print oid".
scampbell
Trainer
Trainer
Fri Jul 24, 2020 7:33 am
Thank you Mikrotik !!
RoS 6.47.1
[admin@crs112-8p-test] /system health gauges> print oid
0 name=.1.3.6.1.4.1.14988.1.1.3.100.1.2.7201
value=.1.3.6.1.4.1.14988.1.1.3.100.1.3.7201
type=.1.3.6.1.4.1.14988.1.1.3.100.1.4.7201
1 name=.1.3.6.1.4.1.14988.1.1.3.100.1.2.7202
value=.1.3.6.1.4.1.14988.1.1.3.100.1.3.7202
type=.1.3.6.1.4.1.14988.1.1.3.100.1.4.7202
Name/OID: .1.3.6.1.4.1.14988.1.1.3.100.1.3.7201; Value (Gauge): 287
Name/OID: .1.3.6.1.4.1.14988.1.1.3.100.1.3.7202; Value (Gauge): 486
___________________
nje431
Fri Jul 24, 2020 3:49 pm
Too bad that ARM devices (1100x4) randomly lock up and reboot on anything later than 6.43.16.
Egate
Long time Member
Long time Member
Thu Nov 19, 2020 1:36 pm
RoS 6.47.1
I am guessing the value would be 28.7 Volt and not 287. Any way to manipulate this in Dude to show 28.7 instead of 287, or is this only Mikrotik that can fix this?
Happy days. :-)
nje431
Fri Nov 20, 2020 4:53 am
Yay! It works on the RB1100AHx4 now too.
As far as the Dude, I do custom functions to get the OID values and divide that by 10. Then another to create the display which you then place on the device appearance label (One of several functions I've replaced the defaults on the label with. The others include average CPU percentage, ROS version, and Uptime).
Function name=PSU1_Get_ROS
if(string_size(oid_raw("1.3.6.1.4.1.14988.1.1.3.100.1.3.7201",5,5)),oid_raw(1.3.6.1.4.1.14988.1.1.3.100.1.3.7201",5,5)/10,-1)
Function name=PSU2_Get_ROS
if(string_size(oid_raw("1.3.6.1.4.1.14988.1.1.3.100.1.3.7202",5,5)),oid_raw(1.3.6.1.4.1.14988.1.1.3.100.1.3.7202",5,5)/10,-1)
Function name=PSU_Display_ROS
concatenate(if(PSU_Get_ROS()=-1,"----",concatenate(PSU1_Get_ROS(),"vdc"))," / ",if(PSU2_Get_ROS()=-1,"----",concatenate(PSU2_Get_ROS(),"vdc")))
Appearance Label
[PSU_Display_ROS()]
Egate
Long time Member
Long time Member
Fri Nov 20, 2020 7:42 am
Great, thanks. Much appreciated.
Happy days. :-)
Users browsing this forum: No registered users and 24 guests
