Hi all,
I see that the WAP LTE Kit manual states that
"Attach the grey uFL connector to the MAIN antenna connector of the modem, attach the black cable to the other (or
AUX) connector. It is possible to use external antennas for the modem, two SMA mounting holes are provided next
to the reset button, or if you prefer to attach antennas to the case directly, SMA antennas can be mounted on the
bottom of the case if you remove the two plastic hole covers first."
So it sounds a bit hazy, yes there are mounting holes for SMA but am I right to assume there are no actual SMA connectors on the board at all? I'm in no way going to solder anything so without getting some kind of uFL -> SMA adapter (which will reduce the gain from my external antenna) how do I go about getting SMA ports on the WAP LTE?
Thanks in advance
