edinorog
0_о
Thu Jun 07, 2018 4:39 pm
samsung172
Re: 0_о
Fri Jun 08, 2018 11:24 pm
... whst is your q?
BMena
Re: 0_о
Fri Jun 08, 2018 11:30 pm
He quick set 20mhz.
But it applied 20/40mhz XX
samsung172
Re: 0_о
Fri Jun 08, 2018 11:34 pm
maybe a bug....... but still its 20 mhz.... and 40....:)
Kliwer
Re: 0_о
Sat Jun 09, 2018 8:14 pm
Keep in mind that "Width" is in blue on Quick set so it was not applied yet. I see nothing wrong on the screenshot.
jebz
Re: 0_о
Sun Jun 10, 2018 2:31 am
Be very careful with Quickset after you have made advanced changes with the conventional menus.
Quickset is only designed for the initial setup. After customizing with the advanced menu options don't return to Quickset to make further changes as often they are out of sync.
samsung172
Re: 0_о
Mon Jun 11, 2018 12:07 am
dont use quickset :)
Users browsing this forum: No registered users and 91 guests
