aline2
AT&T LTE / wAP: "setting network mode failed"
Sat Jun 09, 2018 1:08 am
I cannot, for the life of me, get AT&T LTE to work reliably on the wAP. It works about 2% of the time - when it does, it's rock solid and fast until a reboot. I just updated to 6.42.3 and it seems worse (as in won't connect at all). When it does work, I never had to put an APN in. However, I've tried all the AT&T ones (broadband, phone, etc.).
Log just says:
lte1: setting network mode failed
SIM card seems OK - it has actually worked a couple times (some combination of reboots/power cycles). Please help!
uldis
Re: AT&T LTE / wAP: "setting network mode failed"
Mon Jun 11, 2018 4:56 pm
please contact support@mikrotik.com and include a support output file from your router.
When the module connects successful does it connect to the 3G or LTE band?
digitexwireless
Fri Jan 18, 2019 10:11 am
I am getting same results. Will only connect on 3g. I am using “broadband “ under APN. Any fix for this?
Users browsing this forum: No registered users and 11 guests
