jevonearth
POE OUT not working on hAP ac / RB962UiGS-5HacT2HnT
Fri Jun 15, 2018 6:14 pm
I have a hAP ac (RB962UiGS-5HacT2HnT) device, running 6.42.3
I have ether5 poe out enabled, but when I connect a poe device, the device does not power up. I have tested by trying to power a SXT SA5 ac and also a Polycom voip phone. Neither power up.
When I have the devices connected, the poe monitor shows "poe-out-status: powered-on", if I disconnect the device, it reads "poe-out-status: waiting-for-load". See below. I don't see any log errors. The ehter5 led stays solid red.
 /interface ethernet poe monitor ether5
         poe-out: auto-on
Any advice appreciated.
LEA
Re: POE OUT not working on hAP ac / RB962UiGS-5HacT2HnT
Sun Sep 23, 2018 10:01 pm
Option 1
Try replacing the power supply with a new one for the RB962UiGS-5HacT2HnT
Option 2
Use the PoE injector to connect another device.
The options can be 2:
1. The problem is most likely in the hardware part of the PoE-out.
2. Connected device through PoE from not enough to power provide.
8cqv
Tue Sep 25, 2018 6:48 pm
Is SXT SA5 ac 48v or 24v? I am not in front of my hAP AC^2 but I seem to recall the PSU is 24v...
EDIT:
Powering
Details
PoE in 	802.3af/at
PoE in input Voltage 	12-57 V
Number of DC inputs 	1 (PoE-IN)
Max power consumption 	12
Max power consumption without attachments 	12W
https://mikrotik.com/product/RBSXTG-5HPacD-SAr2
12w sounds a lot, according to hAP page:
https://mikrotik.com/product/hap_ac2
Its up to 15w and comes with a 0.8A 24v PSU (19w), I think you could be short of power?
Users browsing this forum: No registered users and 6 guests
