The hAP Lite is old enough it is listed as accepting PoE 12-30v, less than what most PoE equipment is sending (48v, 54v).
Is it true that it doesn't accept the full POE voltage range? Will it go up in smoke? Will it simply reject PoE?
"Might", or it might run fine. There must be some people with a network such as this..If you feed it 48-54V over passive PoE, it might really burn as it can't refuse it or negotiate lower voltage.
I want to have some hetrogenous devices on my network. I want to use a 'modern' (e.g., higher-voltage standards-compliant) PoE switch and some devices that need that higher voltage level.Is there any specific reason behind your question? Maybe I just did not get what you ask for.
If this means 802.3af / 802.3at compilant switch (that is just my guess as it is most common standard), then it will not get burned but it will not work either. hAP Lite is not compatible with this IEEE standard, it will not request the power, therefore switch will not supply any power to your hAP. You will have to power your hAP by yourself. Either directly by adapter or with additional mikrotik-compatible passive PoE injector. Some managed PoE switches allow you to select, what type of PoE you want to use (e.g. Unifi switches, CRS with PoE..)I want to use a 'modern' (e.g., higher-voltage standards-compliant) PoE switch
I would not risk that at all but fortunately it should not be your caseIdeally, I'm hoping the magnetic transformer and PoE circuitry in the hAP Lite can operate at the higher voltage levels
That should be right.or at least don't ask for any power, which means I can still run it even if I need to supply power to the hAP Lite.
I believe this is cause of our misunderstanding. The "higher voltage" PoE is extremely broad description. There are many different types of PoE. Some are standardized by IEEE, some are proprietary but compatible across several manufacturers, some are proprietary and totally not compatible with anything else. Many of them share same voltage, despite being incompatible. Therefore you cannot identify type of PoE just by voltage.I assume there are people using "higher voltage" PoE
Thanks Nathan.I have access both to these devices as well as to hAP ac lite routers, so just a few minutes ago, I plugged a hAP ac lite into a 3af switch (Dell 3548P) with one of these Ubiquiti in-line adapters sitting in between, and it worked perfectly. hAP ac lite powered up just fine.
The main downside that I can think of is that I think these in-line adapters retail for roughly $20 or so. So your costs just went up by $20/port.
