Hi - just discovered you guys while investigating possible router placements and have seen MikroTik mentioned on Ubnt forums. I am looking to replace a Cisco ASA 5505 being used as a router/FW at home. It has been running reliably for the past 7 years and I hope to get the same out of my next purchase.
Use-case:
- 10 VLANS for WAN, LAN, WIFI, "management interfaces" and 5 or so lab VLAN's
- ACL's on all VLAN's
- QOS for bufferbloat & to limit guest wifi
- R/STP for L3 switch (Cisco SG300-10 used for lab)
- VPN for remote access
- POE (UAP‑AC‑LITE)
- SNMP, SSH, syslog etc.
- 5+ ports since I use 7 of the Cisco ASA ports currently
Wish-list
- Looking for a device that will receive updates for the next 5-7 years
- Supports 1G internet using features above (hw-accel seems to be big discussion point) [current internet is <100Mbit but that will change in time]
I have been eyeing the RB3011UiAS-RM but have a few concerns;
- It has been out a few years now and wonder if it will be replaced anytime soon.
- The RM3011 has a problem connecting 100Mbit devices which is what my DOCSIS modem connects at (found a flapping thread that does not seem to be resolved).
- I am new to MikroTik and do not know how long products are supported
- There may be other options I do not know about
Can you help fill in the blanks?
Andy
