ti1promotion
CCR 1036 stuck on Starting Kernel
Fri Jul 27, 2018 2:08 pm
HI everyone, i have ccr1036 12g 4s em, and last night mu ups has ben over and restarting my router every 3 second in the morning i change the Ups, but ccr not starting stuck in starting kernel, i send to repair to one company in my Contry they said procesor is damage everything its ok, i try tu reset but stuck on loading kernel from nand , i try with netinstall i reset, connect ether to ether 1 and ether 12 but is not detected, can you help me
Thank You
pukkita
Trainer
Trainer
Re: CCR 1036 stuck on Starting Kernel
Fri Jul 27, 2018 2:29 pm
Get a serial cable (see Wiki) and connect to the console.
Try a netinstall using ether1 to latest bugfix version.
To rule out the reset pressing time lottery, you can set that via the serial console (set the boot device to ether boot) having access to the console will be really useful to troubleshoot.
When you tried to netinstall, did you kept the reset pressed until the router appears on netinstall?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Users browsing this forum: No registered users and 9 guests
