saintofinternet
Forum Veteran
Forum Veteran
Please give a remote hard reset option!!!
Fri Aug 24, 2018 3:47 pm
hi,
i would request Mikrotik team to work on something where we can get a remote reset option. something which will work just like the "Reset" button on Routerboard but without getting near the device.
the need for this arises when we are having hardware on towers where the height is anywhere from 30 meters to 80 meters.
in case the outside weather and conditions are not favorable it becomes difficult to retrieve the device just for a reset and then mount it again on the tower so all that time can be saved with a remote "reset" option.
i am currently facing a situation where the device needs to be reset but the rains and winds are too strong to climb the tower and the client has his entire production machines cutoff from the server as the PTP link is down.
by professionals, for professionals....
Don't forget to give KARMA!!!
Steveocee
Re: Please give a remote hard reset option!!!
Fri Aug 24, 2018 4:06 pm
Do you mean kind of like the reset button you get on UBNT PoE?
That would be a pretty amazing idea.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
normis
Fri Aug 24, 2018 4:24 pm
Also dangerous in a lot of situations.
ErfanDL
Fri Aug 24, 2018 4:35 pm
hi,
using a servo motor with an IoT application for pushing the reset button remotely. I do it for the solution.
Sent from my C6833 using Tapatalk
nickshore
Fri Aug 24, 2018 5:03 pm
And you can't just mac-telnet in ?
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
Steveocee
Fri Aug 24, 2018 6:07 pm
That's why there is also a software option to turn it off.
ingdaka
Fri Aug 24, 2018 6:41 pm
Hard Reset mean that you need to get in touch with device!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
AlainCasault
Trainer
Trainer
Thu Aug 30, 2018 8:02 pm
How about just connecting your router to a relay. Press a button while at ground level and power it's cut off. Hard reset! :)
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
AlainCasault
Trainer
Trainer
Thu Aug 30, 2018 8:03 pm
Extra: as long as you only meant hard reboot and not factory reset. ;)
Sent from Tapatalk
Edit:
2 relays. With proper cabling / soldering (one for power, one for reset button leads), one could launch a Netinstall from ground level.
Hey, I never said it would be practical ;)
Alain Casault, Eng.
mistry7
Thu Aug 30, 2018 10:31 pm
We have more then 80 PTP links with MT I never need the Hard reset,
And we use MT for 8 years now
saintofinternet
Forum Veteran
Forum Veteran
Sun Sep 09, 2018 10:52 am
No.. it does get disconnected....
r00t
Sun Sep 09, 2018 4:20 pm
For such places it's useful to add ESP01 with esp-link firmware on UART/serial port. That way you can access the bootloader remotely over wifi. It's same as WOOBM, but allows you to access bootloader menu. Similar would be adding one of these cheap HC-05 bluetooth modules, but they are less secure - I prefer long WPA2 password over number-only BT password.
Main problem is that new mikrotik hardware that doesn't have RS232 ports and even worse, doesn't even have any bootloader menu in a first place!
There are UART pins on the board you can connect to, but they are pretty much useless. No BIOS menu and ROS will not even start console on it by default (but you can enable it manually... but that's not going to help when ROS can't boot properly).
It's OK to be reluctant to add hardware remote reset, even though I haven't had any issues with Ubiquity POE reset being triggered accidentally.
But PLEASE at least provide simple UART menu on all models, where you can change boot source to BOOTP.
Yes, using internal UART will void your warranty, but when installed 40m high it's a small price to pay for remote recovery...
Users browsing this forum: No registered users and 21 guests
