mode
RB3011 - SFP not working - hardware defect?
Sat Sep 01, 2018 11:16 am
i try to connect my RB3011 to a switch by cisco sfp fiber modules:
[admin@MikroTik] /interface ethernet> monitor
numbers: sfp1
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
              sfp-tx-fault: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: LC
      sfp-link-length-50um: 550m
      sfp-link-length-62um: 550m
           sfp-vendor-name: CISCO
    sfp-vendor-part-number: SFP-GE-SX
       sfp-vendor-revision: 1.0
         sfp-vendor-serial: 1134705697
    sfp-manufacturing-date: 13-11-28
            sfp-wavelength: 850nm
           sfp-temperature: 37C
        sfp-supply-voltage: 3.317V
       sfp-tx-bias-current: 6mA
              sfp-tx-power: -5.803dBm
              sfp-rx-power: -6.657dBm
           eeprom-checksum: good
                    eeprom: 0000: 03 04 07 00 00 00 01 00  00 00 00 01 0d 00 00 00  ........ ........
                            0010: 37 37 00 00 43 49 53 43  4f 20 20 20 20 20 20 20  77..CISC O
                            0020: 20 20 20 20 00 20 20 20  53 46 50 2d 47 45 2d 53      .    SFP-GE-S
                            0030: 58 20 20 20 20 20 20 20  31 2e 30 20 03 52 00 1a  X        1.0 .R..
                            0040: 00 1a 00 00 31 31 33 34  37 30 35 36 39 37 20 20  ....1134 705697
                            0050: 20 20 20 20 31 33 31 31  32 38 20 20 58 90 01 3e      1311 28  X..>
                            0060: 00 00 11 f7 8c d1 89 6b  d4 07 74 98 7d 16 12 b1  .......k ..t.}...
                            0070: 49 0f 4b 00 00 00 00 00  00 00 00 00 9f e6 6b 65  I.K..... ......ke
                            0080: 5f 00 ec 00 55 00 f6 00  8c a0 75 30 88 b8 79 18  _...U... ..u0..y.
                            0090: 1d 4c 00 00 13 88 01 f4  18 a5 03 e8 13 93 04 ea  .L...... ........
                            00a0: 1f 07 00 3f 13 93 00 64  00 00 00 00 00 00 00 00  ...?...d ........
                            00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00  ....?... ........
                            00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 9f  ........ ........
                            00e0: 25 c8 81 98 0c 60 0a 44  0b 4a 00 00 00 00 02 f8  %....`.D .J......
                            00f0: 01 40 00 00 05 40 00 00  00 00 00 00 00 00 00 00  .@...@.. ........
My switch shows link, the mikrotik not. Changed fibercable and sfp. nothing helps.
When i plug in the sfp the mikrotik becoms unreachable on all (not only switch 2) ethernet ports. then i have to reconnect the lan cables. Sometimes 10 times till i can access the switch again. Sometimes i have to reboot.
Confugration is default.
FW is 6.42.7
May i got an defective rb3011? i just ordered it.
BR
mode
ingdaka
Re: RB3011 - SFP not working - hardware defect?
Sat Sep 01, 2018 1:35 pm
Or you have to use Mikrotik SFP Module!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
mode
Sat Sep 01, 2018 6:12 pm
Do i have to?
flynno
Mon Sep 03, 2018 5:33 pm
Have you correct SFP modules for send and receive? normally blue and yellow bars on them
Steveocee
Mon Sep 03, 2018 6:16 pm
Blue and yellow is generally if you are using BiDi SFP's to denote which end you have used.
I use Cisco GLC-SX-MM with no issues on my RB3011 so there is some evidence they "may" work. Have you got another SFP which is known as working to test with? Does the SFP work in other devices?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
pe1chl
Mon Sep 03, 2018 10:16 pm
Do i have to?
No. There is always some chance you have a module that is incompatible, but it certainly isn't a must to have only MikroTik modules.
mode
Tue Sep 04, 2018 8:18 am
I have 6 SFP modules from various vendors and none of them work in rb3011. They work in all my other network equipment. i will try to replace the rb3011.
Steveocee
Tue Sep 04, 2018 11:42 am
Sorry to say that unless they are MikroTik modules you will not get much support. You should always use the correct module per device rather than in pairs though if that helps?
mode
Wed Sep 05, 2018 3:47 pm
When the replaced rb3011 has the same issues i will order a mikrotik sfp. i'll keep you updated.
Users browsing this forum: No registered users and 17 guests
