AndreiIW
Compatibility SFP and SFP +
Tue Sep 18, 2018 11:59 am
Friends tell me, there is a router RB3011UiAS-RM and the switch Netis 3310GF. Both devices have a SFP connector. There are many direct SFP + cables on sale (for example, https://mikrotik.com/product/SplusDA0001) and there is not one such cable with SFP. However, in the description of the cable from the example, it is written that it is compatible with SFP.
Question: Will the cable with SFP + work with devices that have SFP?
eider
Re: Compatibility SFP and SFP +
Tue Sep 18, 2018 3:17 pm
Yes, DACs usually do support SFP as well as SFP+. The one you listed definitely does. Obviously keep in mind that you won't get 10Gbps over SFP.
Aron688
Thu Sep 20, 2018 1:21 pm
yes, 10G SFP+ cable is back compatible to 1g sfp. but it's best choice to use a sfp cable.
Aron688
Fri Sep 28, 2018 7:32 am
yes it will work, but ia suggest SFP cable for gagibit devices.
8cqv
Fri Sep 28, 2018 9:43 am
Users browsing this forum: No registered users and 7 guests
