MUM Europe 2020
metron6
RB333
Fri Sep 21, 2018 4:29 pm
Hello all,
I cleaned my warehouse and between other ancient hardware, i found a RB333..
I connected it, power, ethernet and serial, as an idiot I managed to format nand, so i re-installed routeros and wrote a mail to MT support for a new key.
I also forgot it open for a few days, so the licence expired, but the strange is that it boots, starts services, stop services, reboots but no sign at the terminal.
As if serial port is not working.. For sure it worked. Sometimes, when i attach the power, a character is displayed on the terminal. Just this..
Of course i pressed the reset button while booting, I tried almost everything..
I need the serial to reformat nand and install new software..
Any suggestions ?
I tried misc power supplies from 12V to 24V. The serial cable is working for sure, i tried it with some RB133s i have.
Mikro-tickling since 2003...
http://twmn.net
BartoszP
Re: RB333
Fri Sep 21, 2018 4:48 pm
The only way is to ask support@mikrotik.com for help.
Real admins use real keyboards.
metron6
Re: RB333
Fri Sep 21, 2018 4:53 pm
I just did :)
http://twmn.net
npero
Re: RB333
Sat Sep 22, 2018 10:22 am
Use NetInstall to reinstall RouterOS they will give you another I thing 72h or 48h hours working time to enter licence. They counting time only when working.
For licence make supout.rif and send to support they will generate licence for that board without time limit.
Users browsing this forum: MrdotApple and 7 guests
