marekm
Bridge split-horizon vs hw-offload
Sat Sep 22, 2018 3:42 pm
Some switch chips have a feature (also supported in SwOS - forwarding table) where for N ports there is matrix of NxN bits to allow forwarding between any combination of ingress/egress ports. Why isn't bridge split-horizon hw-offload implemented simply by grouping ports by the same nonzero horizon value and setting these bits in the switch chip appropriately for all such groups of ports? Seems simple to do, or am I missing something? Pseudo code:
for H in used nonzero horizon values
	for INGRESS in bridge ports where HORIZON==H
		for EGRESS in bridge ports where HORIZON==H
			set bit in switch chip to block forwarding from INGRESS to EGRESS
mkx
Re: Bridge split-horizon vs hw-offload
Sat Sep 22, 2018 10:16 pm
Some switch chips have a feature to deal with VLAN tags and VLAN-aware switching. Bridge vlan-filtering is not HW-offloaded simply by using this functionality ...
BR,
Metod
marekm
Sun Sep 23, 2018 12:08 am
I use bridge VLAN filtering, and hw-offload works fine here on CRS328-24P-4S+ with ROS 6.42.7 and now 6.43.2 - as long as I don't try to isolate ports by setting horizon.
mkx
Sun Sep 23, 2018 1:12 pm
CRS series 300 is AFAIK currently only HW that does HW offload non-trivial tasks. HW offload on all other device types is currently severely limited.
BR,
Metod
marekm
Mon Sep 24, 2018 6:36 pm
Good to know, I thought VLAN was something basic that should be hw-offloaded on all products (except mixing tagged and untagged on the same port - "hybrid ports" are not supported by some cheap "smart" switches, it could be that some switch chips really can't do it even though they can do VLANs).
mkx
Mon Sep 24, 2018 7:25 pm
...I thought VLAN was something basic that should be hw-offloaded on all products ...
So did I :wink:
BR,
Metod
Users browsing this forum: No registered users and 8 guests
