nbctcp
RB951 Wifi slow but normal with cable
Thu Oct 04, 2018 6:00 am
DIAGRAM:
ISP < Mikrotik1 < Mikrotik2
PROBLEMS:
1.
speedtest.net to my ISP using wireless Mikrotik1 only got 5MB but if using cable got 18MB
2.
but if using wireless via Mikrotik2, I got normal 16MB
tq
[admin@MikroTik] > export
# oct/04/2018 09:28:09 by RouterOS 6.43.2
# software id = M40N-PGNH
# model = 951Ui-2HnD
# serial number = 643105AFCC07
add admin-mac=E4:8D:8C:41:CA:E4 auto-mac=no comment=defconf fast-forward=no \
name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
set [ find default-name=ether5 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] amsdu-limit=2048 band=2ghz-g/n country=taiwan \
disabled=no distance=indoors frequency=2452 frequency-mode=\
regulatory-domain hide-ssid=yes mode=ap-bridge ssid=id5 tx-power-mode=\
all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=id5 \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=password \
wpa2-pre-shared-key=password
add name=dhcp ranges=10.0.10.101-10.0.10.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=10.0.10.1/24 comment=defconf interface=ether2 network=10.0.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.0.10.0/24 comment=defconf dns-server=9.9.9.9 domain=ngtrain,com \
gateway=10.0.10.1 ntp-server=103.31.225.225
set allow-remote-requests=yes servers=9.9.9.9,4.2.2.2
/ip dns static
add address=10.0.10.1 name=router.lan
/ip firewall address-list
add address=10.0.10.0/24 list=LAN
add action=masquerade chain=srcnat comment="default configuration" \
out-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
/ip hotspot service-port
add distance=1 dst-address=10.0.20.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.30.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.40.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.50.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.60.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.80.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.90.0/24 gateway=10.0.10.211
add distance=1 dst-address=10.0.100.0/24 gateway=10.0.10.211
/ip service
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Jakarta
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
mkx
Re: RB951 Wifi slow but normal with cable
Thu Oct 04, 2018 12:16 pm
Are both of your mikrotiks same model? If yes, can you compare ouptut of
/interface wireless export
between both of them to check if thare are some differences in how WiFi is set-up on both.
One thing I'd change in your setup is tx-power-mode=all-rates-fixed ... this typically doesn't work great at higher speeds and I'd change it to
/interface wireless
set [ find default-name=wlan1 ] tx-power-mode=default
Another thing: 951Ui-2nD is no high-performance beast. What is CPU usage while you're testing wifi throughput when connected to Mikrotik1? WiFi consumes quite some CPU, routing (done by Mikrotik1) as well, so it could be that CPU is a bottleneck here. Observe output of commands /system resource monitor and /tool profile ...
BR,
Metod
nbctcp
Thu Oct 04, 2018 1:34 pm
1. RESULT: 4.5MB
/interface wireless
2. wireless export
Both same model and firmware
MIKROTIK1
# oct/04/2018 17:25:21 by RouterOS 6.43.2
/interface wireless
set [ find default-name=wlan1 ] amsdu-limit=2048 band=2ghz-g/n channel-width=20/40mhz-Ce country=taiwan disabled=no distance=\
indoors frequency=auto frequency-mode=regulatory-domain hide-ssid=yes mode=ap-bridge ssid=id5 wireless-protocol=802.11 \
wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm mode=dynamic-keys \
supplicant-identity=id5 unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=password wpa2-pre-shared-key=password
MIKROTIK2
# oct/04/2018 17:22:53 by RouterOS 6.43.2
# software id = 8EC1-0IGD
# serial number = 43CE02222B43
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country="united states" default-authentication=no \
disabled=no distance=indoors frequency=2447 frequency-mode=regulatory-domain hw-retries=2 \
mode=ap-bridge ssid=id3 tx-power=30 tx-power-mode=all-rates-fixed wireless-protocol=802.11 \
wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-nstreme=yes
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm \
/interface wireless access-list
add comment="aan hp*" disabled=yes mac-address=14:DD:A9:A5:B3:15 vlan-mode=no-tag
3./system resource monitor and /tool profile
MIKROTIK1
cpu-used: 9%
free-memory: 99856KiB
MIKROTIK2
cpu-used: 4%
free-memory: 97452KiB
/tool profile
only 3 devices connect to each mikrotik
MIKROTIK1
> /tool profile
NAME CPU USAGE
wireless 0.5%
ethernet 0.5%
console 0.5%
firewall 0.5%
networking 0.5%
winbox 1%
management 5%
routing 0%
dhcp 0%
telnet 0%
bridging 0%
unclassified 1.5%
total 10%
MIKROTIK2
> /tool profile
NAME CPU USAGE
wireless 1%
ethernet 0%
console 0.5%
firewall 0.5%
networking 1%
winbox 1%
management 2%
profiling 0%
telnet 0%
bridging 0%
unclassified 1%
total 7%
/interface wireless
mkx
Thu Oct 04, 2018 2:31 pm
How's intereference situation? Mikrotik2 has fixed channel while Mikrotik has it set to auto....
WiFi settings on both APs are completely different (some of them might actually affect transmitted power). So why don't you just copy settings from Mikrotik2 over to Mikrotik1? If signal from both APs overlaps, you have to change frequency on one of them.
BTW, combination of settings on Mikrotik2 (country="united states", frequency=2447 and tx-power=30) is not legal. It might be legal in your country (whatever it might be) if settings on Mikrotik1 (country=taiwan) are correct.
BR,
Metod
nbctcp
Fri Oct 05, 2018 4:32 am
already copied Mikrotik2 config to Mikrotik1
change SSID name, password, frequency
RESULT: still 4.5MB speedtest.net with Mikrotik1 va Wifi
Mikrotik1 to Mikrotik2 connected through cable
Wifi speedtest via Mikrotik2 speed is 10MB-15MB
Both Mikrotik same model and current firmware. Difference only factory fw which Mikrotik1 is newer than Mikrotik2
Any more idea?
tq
/interface wireless
set [ find default-name=wlan1 ] amsdu-limit=2048 band=2ghz-g/n country=taiwan default-authentication=no disabled=no distance=\
indoors frequency=2442 frequency-mode=regulatory-domain hide-ssid=yes mode=ap-bridge ssid=id5 tx-power=30 tx-power-mode=\
supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=password wpa2-pre-shared-key=\
password
nbctcp
Re: RB951 Wifi slow but normal with cable  [SOLVED]
Fri Oct 05, 2018 10:07 pm
CASE CLOSED:
SpeedTest Android App
Mikrotik1: 18MB
SpeedTest Windows App
Mikrotik1: 17MB
SpeedTest Windows Browser (Opera)
Mikrotik1: 4.5MB
SpeedTest website said to use windows app to get reliable connection.
When I tried that. I got similar result to Android app.
So I think. We should use SpeedTest app to get consistent result
tq
Users browsing this forum: No registered users and 3 guests
